Old Feb 01, 2013, 01:39 AM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
Heres kloners build thread on it,
http://www.multirotorforums.com/showthread.php?t=6952
elliott000 is offline Find More Posts by elliott000
Old Feb 01, 2013, 01:48 AM
Joined Feb 2012
Kloner, are you huckin it for launch or bungee?
Old Feb 01, 2013, 09:36 AM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
That is the ZXL nex5 build. I just posted pics of building it in this thread, looks like this
http://rchelicollective.com/zen/kloner/zxl/zxl%20nex-5/
When you power up holding it's nose, you just roll your arm over your head and let go. it has unlimited vertical, 6s power but not real fast. Think Jim @ uthere said 72mph, 4 kilo
Kloner is offline Find More Posts by Kloner
Old Feb 01, 2013, 09:46 AM
pablojaime is offline
Find More Posts by pablojaime
pablojaime's Avatar
Israel, Ashdod
Joined Dec 2009
Some Pictures of the Build advance..
Pablo.
pablojaime is offline Find More Posts by pablojaime
pablojaime's Avatar
Israel, Ashdod
Joined Dec 2009
Two More...
Pablo.
Old Feb 02, 2013, 12:14 PM
kefir is offline
Find More Posts by kefir
Poland Gdynia
Joined Feb 2009
How can I fix this damage?
kefir is offline Find More Posts by kefir
Old Feb 02, 2013, 01:46 PM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
Question for all those that have built one. Im looking at getting on myself just wondering what other cabeling are you using to extend the Vtx and Uhf rx in the wings? Are you making your own or buying and if so where from?
Im just trying to get everything together that i will need in order to start my own build.
I plan on running gopro with flite cam, 600 mw vtx, and ezuhf 8ch rx, with the tbs ezosd.
Thanks for any advise you can give me. Much appreciated.
Killab is offline Find More Posts by Killab
Old Feb 02, 2013, 02:43 PM
pablojaime's Avatar
Israel, Ashdod
Joined Dec 2009
Home made...
Pablo.
Old Feb 02, 2013, 05:03 PM
Hmerly is online now
Find More Posts by Hmerly
Hmerly's Avatar
United States, AL, Huntsville
Joined May 2012
Peal back the crumpled lam and cut off. Pour some boiling hot water over the crumpled foam and it should go back to it's original shape, Use some gorilla glue and glue the tears back together. Make sure you get the glue into the tear, and not just on the surface. Clean up, laminate again and you should be good to go.
Hmerly is online now Find More Posts by Hmerly
Old Feb 02, 2013, 05:22 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
Originally Posted by pablojaime View Post
Home made...
Pablo.
That's what I thought, thanks
Old Feb 02, 2013, 06:41 PM
bakon is offline
Find More Posts by bakon
I Toast Planes
bakon's Avatar
Joined Jul 2010
Pablo.
The soldering rig you set up, what kind of wire did you use? It's a pretty genius idea
bakon is offline Find More Posts by bakon
Old Feb 03, 2013, 02:26 AM
pablojaime's Avatar
Israel, Ashdod
Joined Dec 2009
I must say it's not "my" idea , but it's 1.5mm or 2mm copper wire. the wire don't need to be too much rigid, important is the heat that the soldering can produce, if you have good heat, the copper will cut the foam like butter.. and the copper wire will not bend during work.
Pablo.
Old Feb 03, 2013, 08:44 AM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Pablo.
Mine is a 150 watt soldering iron and works great.
DoctorAudio is offline Find More Posts by DoctorAudio
Old Feb 03, 2013, 09:16 AM
ronrob61 is offline
Find More Posts by ronrob61
United States, AZ, Gilbert
Joined Nov 2011
You can use servo lead to extend all the wires, just pick up a couple of 24" servo extensions and you good to go.
ronrob61 is offline Find More Posts by ronrob61
Old Feb 03, 2013, 01:32 PM
Milwaukie , Oregon
Joined Feb 2003
Don't forget the ferrite cores.
More than 12" long I use two!
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 06:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 09:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 05:37 PM
