Old Dec 03, 2012, 01:09 AM
S0YL3NT is offline
Find More Posts by S0YL3NT
United States, CO
Joined Oct 2012
Maiden success but need some help
Hi, here are some pics of my finished Z2. Maiden flight was great, first throw and it was off pretty smooth. After landing and changing batteries the next two attempts failed and I had to go home with broken props. First launch had 11x5.5 APC prop and a bit of a headwind. Next attempt, no headwind and same prop. Then last attempt no headwind again and a 10x5 prop. I thew the Z2 and had a friend who is a better test pilot on the sticks since I wasnt sure I could do both at once. I attached a vid of my launch attempts in case anyone can see what I did wrong. I thought I had picked a high thrust option for 5400ft ASL and a 3s setup with stock ritewing motor and esc. Any ideas would be greatly appreciated.
1outof3 (0 min 52 sec)
finished build pics on the way have to edit file size...
S0YL3NT is offline Find More Posts by S0YL3NT
Old Dec 03, 2012, 01:29 AM
S0YL3NT is offline
United States, CO
Joined Oct 2012
the pics...
Old Dec 03, 2012, 01:53 AM
IMEIV is offline
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
Originally Posted by S0YL3NT View Post
the pics...
Fantastic
IMEIV is offline Find More Posts by IMEIV
Old Dec 03, 2012, 03:03 AM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
impressive
brosius85 is offline Find More Posts by brosius85
Old Dec 03, 2012, 03:21 AM
pablojaime is offline
Find More Posts by pablojaime
pablojaime's Avatar
Israel, Ashdod
Joined Dec 2009
the next two attempts failed and I had to go home with broken props. First launch had 11x5.5 APC prop and a bit of a headwind. Next attempt, no headwind and same prop. Then last attempt no headwind again and a 10x5 prop. I attached a vid of my launch attempts in case anyone can see what I did wrong.
Do you put a few clicks of Up throw on your launches?
in Youtube there is a video of Chris explaining how much throw and how to launch the ZII.
Found it!!!
Ritewing ZII Launch (6 min 39 sec)
Hope that help you..
Pablo.
pablojaime is offline Find More Posts by pablojaime
Old Dec 03, 2012, 04:23 AM
w4Rd3n is offline
Find More Posts by w4Rd3n
w4Rd3n's Avatar
Switzerland, VS, Oberems
Joined Apr 2010
i always throw mine with motor off.
without headwind its quite hard and i prefer to launch it from a hill
w4Rd3n is offline Find More Posts by w4Rd3n
Old Dec 03, 2012, 06:12 AM
tty044 is offline
Find More Posts by tty044
tty044's Avatar
Joined Aug 2008
@S0YL3NT So you have changed the batteries and after that you had problems with launch?
Would it be possible to measure the difference in weight between battery set you have during your first flight and batteries you changed afterwards to?
My first guess they are not equal in weight and this changed your CG to nose heavy slightly.
Regards
Michal
tty044 is offline Find More Posts by tty044
Old Dec 03, 2012, 10:28 AM
mburross is offline
Find More Posts by mburross
United States, TX, Fort Worth
Joined Nov 2012
Which motor and esc for Zii
I'm purchasing a Zii and want to know if I should go with the standard rite wing motor and esc or should I spend the extra money and get the Castle Creations Ice 75 ecs and the motor I'm looking at is the OS 3820-1200 kV, It's the one team black sheep uses on their birds.
Also if anyone could direct me to where to find some good push rods I would appreciate it.
Any input would be greatly appreciated?
mburross is offline Find More Posts by mburross
Old Dec 03, 2012, 12:00 PM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
the pics...
Nice plane man, did u monocote chrome over lam on top or the vinyl?
elliott000 is offline Find More Posts by elliott000
Old Dec 03, 2012, 12:39 PM
S0YL3NT is offline
United States, CO
Joined Oct 2012
@pablojaime
Ya i followed the instructions on that video. i also had triple rates set up, one with more throws and one with less. but they werent needed it flew almost perfect on Chris's recommendation.
@tty044
the batteries are an identical pair so weight should be the same. good point tho, i should hook up a battery tester and see if something is wrong with the second set.
I think headwind definately helped. its hard to tell from the video but im wondering if i threw too steep. i am also wondering if my prop choice is correct. my friends i fly with say i can push the pitch higher at this altitute but ecalc and motocalc say the prop will stall over 11x7. motocalc also says anything over 11x5 will be difficult to hand launch. not sure what to change.
@elliot000
thanks, the top is monokote over lam, bottom is vinyl over lam. the monokote was difficult, i used windex method to keep the bubbles out but to do it over i might try the same loctite adhesive way of putting the lam on.
Old Dec 03, 2012, 02:10 PM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
to me it looks like not enough prop
this is 10x6
zII @ Daves (7 min 59 sec)
Kloner is offline Find More Posts by Kloner
Old Dec 03, 2012, 02:12 PM
Joined Feb 2012
What are the suggested throws up and down? I have possibly too much lol still flts tho
Old Dec 03, 2012, 02:37 PM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
start with 10mm (1/4 inch) each way on each stick, aileron can be 15mm if you like fast rolls
Old Dec 03, 2012, 03:33 PM
Joined Feb 2012
Last question then Ill walk away happy lol. Sloyvent where do u get the air cowls... I cut a plastic spoon on my first but the second zeph has to look better lol
Old Dec 03, 2012, 04:52 PM
BldrFlyr is offline
Find More Posts by BldrFlyr
BldrFlyr's Avatar
United States, CO, Boulder
Joined Nov 2012
FPV Zephyr II with Ruby - Devils Thumb
Zephyr FPV - Devils Thumb (6 min 31 sec)
BldrFlyr is offline Find More Posts by BldrFlyr
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
