Old Nov 10, 2012, 10:19 AM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Send me an email , ritewing@hotmail.com
Originally Posted by wazoo22 View Post
Any idea when this 80 inch version will be available?
Have you tested it yet? Sounds like it would carry some weight, which is what I'm looking for.
Jim
klique is offline Find More Posts by klique
Old Nov 10, 2012, 10:59 AM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by DoctorAudio View Post
Those of you with the Mini Z.
If you are following my set up.
Make sure you get the motor as close to the fuse as possible.
If not you will find your CG off by an 1/2 inch!
I posted the two pictures below to show how mine is mounted!
Also I did use the Gobrushless.com motor mount.
http://www.gobrushless.com/shop/inde...=MDRITEWINGMNT
I had to drill it out and then shave mill off about .25 of an inch.
So the lenght is now .75 inch long.
Also the motor I am using can be runn on a 7x3 prop on 3S 1800.
http://www.hobbyking.com/hobbyking/s...208_2150_.html
But it has to be a High C setup. I got 325 watts running one. The motor got pretty warm. But not hot! Check your setup first before you go and bun it up!
Running a 6X4 Apc pusher prop got me 235 watts.
I was able to fly for 12 mins on a 1800 and mostly 3/4 to wot!
As with the 7 X 3 i only could fly for 8-9mins!
That is all!
Man that is pretty tight. Did you consider smoothing the edges on the motor mount in case the motor gets bumped to the side. Looks like is would shave off a few mg which could make it unbalanced.
Eagle202 is offline Find More Posts by Eagle202
Old Nov 10, 2012, 03:02 PM
deTonaTor_NZ is offline
Find More Posts by deTonaTor_NZ
Religion= suffering/wars
deTonaTor_NZ's Avatar
Joined Jan 2006
Originally Posted by IMEIV View Post
Are you sure that you can use RVOSD so turned ? You can use it only turned in the direction of the two arrows.
No it can't be used in this orientation as I learned! lol. I have some other pics about to be posted of current config...
deTonaTor_NZ is offline Find More Posts by deTonaTor_NZ
Old Nov 10, 2012, 03:55 PM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
Did you attach winglets with glue or screws ?
i have tried both ways. at the moment i have them glued
brosius85 is offline Find More Posts by brosius85
Old Nov 10, 2012, 03:56 PM
pavn is offline
Find More Posts by pavn
pavn's Avatar
Czech Republic, Olomouc
Joined Sep 2010
Question
Could somebody explain why the servos are not placed in wing type of airplanes such as zephyr or maxi swift in the middle of each aileron? But near the one side? Would not be better to place them rather in the middle of each aileron?
Thanks for opinions and clarifications.
pavn is offline Find More Posts by pavn
Old Nov 10, 2012, 05:56 PM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
typically flying wings are hard to get CG without adding lead, having servos as far forward as possible helps with that. also you will have to add extensions to the leads if you move them outboard.
the balsa CK ships it plenty stiff enough to have the horn on one end of the elevon. if you had foam elevons you would want it in the middle lol
i think those are the main reasons.
Old Nov 10, 2012, 08:10 PM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
she likes the weight in towards the middle
Kloner is offline Find More Posts by Kloner
Old Nov 10, 2012, 09:50 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
Originally Posted by deTonaTor_NZ View Post
Updated pics of my Zeph II
holy slingshot batman.
Actually that is one sweet looking launcher you have there. You said you designed and built it? How much for the material and time to do that?
Old Nov 10, 2012, 10:13 PM
Joined Jan 2006
Originally Posted by Eagle202 View Post
holly slingshot batman.
Well hard to say, I never really monitored the time I spent drawing, programming and cnc work....
Old Nov 11, 2012, 07:55 AM
Kloner is offline
Aerial DP
Joined Apr 2010
things worth more than all our planes combigned..... cnc launcher,,, sick
Does it push on your ailerons or just inside that?
Old Nov 11, 2012, 10:21 AM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
Sweet launcher but I wouldnt be able to haul that up to the top of Cypress lol. Yard launcher
elliott000 is offline Find More Posts by elliott000
Old Nov 11, 2012, 11:09 AM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
Looks like a lot of it is milled out aluminum. Really nice clean lines.
Do you have a video of it in use?
Old Nov 11, 2012, 12:16 PM
Joined Jan 2006
The AL tongues are modified now from what's in the photo. The top part of them are shorter and the load is pushing on the the back of the wing on launch.
Old Nov 11, 2012, 12:17 PM
Joined Jan 2006
Actually it all breaks down into a carry bag.
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
