Old Nov 08, 2012, 02:54 PM
emzet is offline
Find More Posts by emzet
Nowogard/Poland
Joined Jul 2010
Clouds - the reason... (3 min 53 sec)
emzet is offline Find More Posts by emzet
Old Nov 08, 2012, 06:04 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Maybe next week, I have been so crazy bizy.
Originally Posted by IMEIV View Post
Klique.. when will you open a new thread for the ZXL ?
klique is offline Find More Posts by klique
Old Nov 08, 2012, 11:36 PM
whosthebaddest is offline
Find More Posts by whosthebaddest
Joined Nov 2010
How do you prevent winglet damage/bending during landing?
Hey what is the best way to prevent the winglets from getting bent or damaged on landing once they are permanently attached with goop?
someone mentioned Zip ties but I'm not sure how that would work...? Or is very smooth landing the only way?
also is it ok if they get bent up a bit and become more flexable? Thanks for your help!!
Emzet:
Awesome video one of the best I've ever seen!!! If you don't mind me asking what was your battery/lipo configuration and how much does your zephyr weigh to get up that high? Thanks!!
whosthebaddest is offline Find More Posts by whosthebaddest
Old Nov 09, 2012, 12:13 AM
IMEIV is online now
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
IMEIV is online now Find More Posts by IMEIV
Old Nov 09, 2012, 03:04 AM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
if you are worried about the winglets you can add a vertical spar with a steel pushrod...
or just cut them off every few months and add new ones. mine have a vertical spar.
brosius85 is offline Find More Posts by brosius85
Old Nov 09, 2012, 03:10 AM
Joined Nov 2010
yeah I think you are right I will just cut them off if they need to be replaced.
They should last a while now that I'm starting to make much better landings
I'm already kind of heavy so I don't want to add any extra weight.
Thanks for your help Brosius!!
Old Nov 09, 2012, 03:28 AM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
Hey all,
I will finally be mounting my LRS into the Z2 and tomorrow and will finally be able to get some good air time.
I haven't weighed it yet - but what is the average? Mine is running 2x3300 3S
The_Mongrel is offline Find More Posts by The_Mongrel
Old Nov 09, 2012, 04:33 AM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
i run 2x 4s 3000 these days, i used to run 4x 3s 3300. (as 6s 6600) at 2.7kg.
as long as you are under 3kg you will handlaunch it ok, as long as you know what you are doing
Old Nov 09, 2012, 04:35 AM
Joined Dec 2007
Thanks man. I have flown it already! Took 2 failed launches, but then got it nailed. Flies nice too!! Once you get the technique, it basically flies out of your hand.
Soon - Ruby will take of it all.
I just had to stay close - But will have the LRS in tomorrow. I will have to weigh it and see where I am at.
Old Nov 09, 2012, 07:52 AM
IMEIV is online now
IMEIV's Avatar
Joined Apr 2009
Did you attach winglets with glue or screws ?
Old Nov 09, 2012, 10:38 AM
Panzlflyer is offline
Find More Posts by Panzlflyer
Tricopters Rule
United States, NC, Goldsboro
Joined Mar 2012
nice one emzet
Panzlflyer is offline Find More Posts by Panzlflyer
Old Nov 09, 2012, 11:16 AM
octane81 is online now
Find More Posts by octane81
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Heres some pics of my ZII build .. need to cut out battery bays and put skids on.
octane81 is online now Find More Posts by octane81
Old Nov 09, 2012, 11:55 AM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Those of you with the Mini Z.
If you are following my set up.
Make sure you get the motor as close to the fuse as possible.
If not you will find your CG off by an 1/2 inch!
I posted the two pictures below to show how mine is mounted!
Also I did use the Gobrushless.com motor mount.
http://www.gobrushless.com/shop/inde...=MDRITEWINGMNT
I had to drill it out and then shave mill off about .25 of an inch.
So the lenght is now .75 inch long.
Also the motor I am using can be runn on a 7x3 prop on 3S 1800.
http://www.hobbyking.com/hobbyking/s...208_2150_.html
But it has to be a High C setup. I got 325 watts running one. The motor got pretty warm. But not hot! Check your setup first before you go and bun it up!
Running a 6X4 Apc pusher prop got me 235 watts.
I was able to fly for 12 mins on a 1800 and mostly 3/4 to wot!
As with the 7 X 3 i only could fly for 8-9mins!
That is all!
DoctorAudio is offline Find More Posts by DoctorAudio
Old Nov 10, 2012, 07:03 AM
wazoo22 is offline
Find More Posts by wazoo22
wazoo22's Avatar
France, Bourgogne, Nevers
Joined Feb 2012
Hi , that would be wing end extensions , not winglet.
This would increase the wing span to 80'' by making the wings longer while maintaining the exact profile, just extending it.
Any idea when this 80 inch version will be available?
Have you tested it yet? Sounds like it would carry some weight, which is what I'm looking for.
Jim
wazoo22 is offline Find More Posts by wazoo22
Old Nov 10, 2012, 09:44 AM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
For you guys with bent, permanently attached winglets just glue another layer of coroplast to your existing winglets(trim to shape), works like a charm.
Kev.au is offline Find More Posts by Kev.au
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
