Old Oct 10, 2012, 11:33 AM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
A stroke of luck or pure genius, my first zeph build and my cg is spot on ready to fly. Nice wing chris, expect a second order in a few days lol now that ive got a feel for where to put things i can refine my next build.
Note, Ive gone to mount my prop, aeronaut folding cam 10x6. I dont have a spiner or whatever its called for the front. Ive got a prop stop, but if i fire this up itll chew up the plane. I put my graupner 10x5 on for now, where can I get a prop spinner for this guy? motor is the ritewing v2
Would my LHS have somethin?
elliott000 is offline Find More Posts by elliott000
Old Oct 10, 2012, 01:18 PM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
Originally Posted by geotete View Post
This one is GREAT!
http://www.ebay.com/itm/250954117473...84.m1423.l2649
Cheaper and with great efficiency.
Geotete
same thing as the dpcav for 90% off,,, great find
Kloner is offline Find More Posts by Kloner
Old Oct 10, 2012, 01:38 PM
IMEIV is offline
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
Whis is for you the most reliable of the Down Voltage Regulators ?
IMEIV is offline Find More Posts by IMEIV
Old Oct 10, 2012, 01:42 PM
Kloner is offline
Aerial DP
Joined Apr 2010
Out of 4 rigs with 3 different setups, the dpcav has been rock solid. my cores get hot,,,,, my DE doesn't have the filter and i can see it a little. it's still a great link, but that one and the filter is like watching cable tv
Old Oct 10, 2012, 01:50 PM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
Maybe this here can be a good choice ? http://www.ebay.it/itm/260775477112?...84.m1438.l2649
Old Oct 10, 2012, 03:56 PM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Originally Posted by Kloner View Post
be careful when you set that up,,,, the voltage under a load is totaly different than no load, make sure it's not cranked up when you start out the install and power up. not being contolled by anything but the screw, it's not self adjusting
Thanks. I set it to 12.4 volts. Exactly the same voltage as a fresh 3S pack. I fired it up and nothing went pop so I'm hoping it is good to go. I also taped over the adjustment screw to prevent accidents.
Gree is offline Find More Posts by Gree
Old Oct 10, 2012, 04:15 PM
Kloner is offline
Aerial DP
Joined Apr 2010
i'd make it lower so it can't dip and raise with voltage sag.... 11.5 would be better if this is powered with 3s. that way it's just at the end of a flight than through out..... you'll see shwag on the screen when its constantly shifting voltage like that....
this is the reg you wanted for the 3s setups
http://www.dpcav.com/xcart/Adjustabl...EPIC-Type.html
imeive, your the ebay super finder..... that's totaly it, with a heat sink under it.... mines buried into the wing and covered.... dunno if that'd help or not in my case.....
Old Oct 10, 2012, 06:22 PM
geotete is offline
Find More Posts by geotete
Joined Mar 2011
In my opinion you are paying a lot for Heatsink this one is the same but without the Heatsink, and if you want/need you can add a Heatsink for less.
The one that I suggest only gets warm in the bench after 45 minutes converting 4S to 11.5V @ 1.3A.
Geotete
geotete is offline Find More Posts by geotete
Old Oct 10, 2012, 08:59 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Zxl 81
klique is offline Find More Posts by klique
Old Oct 10, 2012, 09:13 PM
Kloner is offline
Aerial DP
Joined Apr 2010
all kinds of goodies on there....... sweet
Old Oct 10, 2012, 09:27 PM
klique is offline
Mum is the word!
Joined Jun 2003
Oh ya, it should fly tomo, the verts and vorts should make for some smooth flight.
Old Oct 10, 2012, 10:48 PM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
But which model of down voltage regulator did you burn ?
Geotete
I will try one..
Old Oct 10, 2012, 10:52 PM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
If the down voltage regulator burns the current flow through anyway (and you have the voltage of the battery) or the circuit is interrupted ? In the second case I will lost the plane..
Old Oct 11, 2012, 08:45 AM
pablojaime is offline
Find More Posts by pablojaime
pablojaime's Avatar
Israel, Ashdod
Joined Dec 2009
Originally Posted by klique View Post
Zxl 81
that's a ZII XL???
any guess on time of commercialization?
Pablo.
pablojaime is offline Find More Posts by pablojaime
Old Oct 11, 2012, 10:12 AM
klique is offline
Mum is the word!
Joined Jun 2003
In the next week or two , I will be test flying it today , I am dialing in the build process and sparring materials.
Originally Posted by pablojaime View Post
that's a ZII XL???
Pablo.
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
