Old Oct 09, 2012, 09:42 AM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
Gree, what are you using for a voltage regulator. Ive been trying to find a decent 12v regulator so i can eliminate my 1000mah 3s for video gear.
Nice plane
elliott000 is offline Find More Posts by elliott000
Old Oct 09, 2012, 10:15 AM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Hey guys when mounting the motor inboard using the motor shaft side to mount your prop, make sure you use the c clip support thrust collar between you prop adaptor and c clip to suport the clip, or it will fail !!!
klique is offline Find More Posts by klique
Old Oct 09, 2012, 01:23 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
My C clip kept sliding off!
So, this fixed it!
http://shop.dubro.com/products/produ...=141/101.0.1.1
DoctorAudio is offline Find More Posts by DoctorAudio
Old Oct 09, 2012, 04:16 PM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Nice plane
Thanks. I used this voltage regulator after a recommendation by a friend. You'll need a multimeter to set the output voltage.
http://hobbywireless.com/index.php?m...roducts_id=692
Thanks for the tip Chris! I didn't know this. That would have been bad...
Gree is offline Find More Posts by Gree
Old Oct 09, 2012, 04:21 PM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
i used the one gree linked in a small rig, but if you want some clean power to take you out a ways, look into one of these
http://www.dpcav.com/xcart/Power-Sup...-L-C-Type.html
after one of these
http://www.dpcav.com/xcart/Adjustabl...Step-Down.html
It has a ton of power, stays cooler than my cores
Kloner is offline Find More Posts by Kloner
Old Oct 09, 2012, 04:42 PM
Macattaka is offline
Find More Posts by Macattaka
Beyond the BlackStump
Macattaka's Avatar
Australia, SA, Adelaide
Joined Mar 2006
Nice plane
I use a 2S input regulator coming off one of the main battery balance taps
Macattaka is offline Find More Posts by Macattaka
Old Oct 09, 2012, 06:59 PM
neale is offline
Find More Posts by neale
Australia, QLD, Beaudesert
Joined Jul 2008
I have had to skip a lot of this thread at the moment, but am wondering what the goss is on running with gearboxes, whats available and or what works ,
Neal
Ps I would be looking for around 100/120 MPH, would like to run threes, as I have some good 5000 3s
If that wont work I am open to suggestions!
neale is offline Find More Posts by neale
Old Oct 09, 2012, 07:12 PM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
the original setup CK ran with the gearbox failed. if you are still keen make sure you get something really high quality (mega). and make sure you run a separate RX battery pack just in case it dies and takes the ESC with it.
brosius85 is offline Find More Posts by brosius85
Old Oct 09, 2012, 08:26 PM
neale is offline
Joined Jul 2008
Thanks for that, mmmm sounds like gear boxes may be a bit delicate unless you know what your up do, and I dont.
I think I will just stick with direct,
So is 100/110 mark not asking too much, any thought /recomendations, what sort of speeds are you guys getting with stock set-ups, I am a total noob to Zll, just organizing with CK for order
Neal
Old Oct 10, 2012, 12:38 AM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Sorry for being dumb, but what does the c clip support thrust collar look like?
marhar is offline Find More Posts by marhar
Old Oct 10, 2012, 12:51 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
I hoping it is the metal collar that fits on the shaft with the grub screw, the one that came in the packet of motor accessories. At least that's what I take it be...
Old Oct 10, 2012, 12:54 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
after one of these
Awwww man does this mean I'll get interference in my video from what I have used?
Old Oct 10, 2012, 01:58 AM
klique is offline
Mum is the word!
Joined Jun 2003
Its this collar , accept in the pic its not all the way against the c clip, but it up to the clip when you do it.
Old Oct 10, 2012, 08:16 AM
Kloner is offline
Aerial DP
Joined Apr 2010
no it's pretty much the same thing but no filter behind it. Same screw driver to change voltage....
the DE one is smaller and more output power,,,, more than you need. the dpcav one is bigger, less power, but still more than enough. I run 1 watt lawmate 2.4, pixim cam and it idles at .7 amp,,,,,, that's just video gear and servos doing nothing.
I started with dragonlink and got blown out of the water to the point i had to build another model just to get it to work with gobs of seperation so i got freaked out by any over powered on anything. My video works better on the dpcav with filter than the DE or the CORE from tbs
be careful when you set that up,,,, the voltage under a load is totaly different than no load, make sure it's not cranked up when you start out the install and power up. not being contolled by anything but the screw, it's not self adjusting
Old Oct 10, 2012, 11:14 AM
geotete is offline
Find More Posts by geotete
Joined Mar 2011
after one of these
This one is GREAT!
http://www.ebay.com/itm/250954117473...84.m1423.l2649
Cheaper and with great efficiency.
Geotete
geotete is offline Find More Posts by geotete
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
