Old Sep 18, 2012, 06:22 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
I am looking for a 950 kv -- 1000kv motor!
The bigger the prop the more air it moves!
I am at the end of my throttle range after 3/4.
I am spinning a 9" prop!
But, I am very happy with mine!
DoctorAudio is offline Find More Posts by DoctorAudio
Old Sep 18, 2012, 07:01 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Its 60 amp , on 4s dont go larger than a 9/7 , I would use a watt meter to check.
klique is offline Find More Posts by klique
Old Sep 19, 2012, 11:17 AM
Tonyatrre is offline
Find More Posts by Tonyatrre
United States, CA, Lake Forest
Joined Apr 2012
Anybody know the TX program sequence for the esc on the stock ritewing set up?
Tonyatrre is offline Find More Posts by Tonyatrre
Old Sep 19, 2012, 11:37 AM
klique is offline
Mum is the word!
Joined Jun 2003
No need its already programmed.
Or go to the first page here and see first post at the bottom.
http://fpvlab.com/forums/showthread....wing-Zephyr-II
Old Sep 19, 2012, 11:04 PM
Milwaukie , Oregon
Joined Feb 2003
All you guys having bobbing and flutter problems , can I ask you what servos are you using?
Old Sep 20, 2012, 05:22 PM
Milwaukie , Oregon
Joined Feb 2003
Here is something I remember hearing a long time ago!
Wing don't like fast servos. I was told buy a couple guys a long time ago!
I was looking for that info somewhere, to prove my point. But I can't find it anywhere.
The guys I got the info from have been flying wings for over 12 years and they do know thier stuff!
Old Sep 20, 2012, 09:16 PM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
I have flown a hundred wings; varying from snail slow to 100+mph. In every project I have done, the higher speed and higher torque servos are preferred- especially with heavier loads associated with fast speeds and large control surfaces.
It may simply be my personal preference, but test for yourself to see if you prefer faster or slower servos. You can do this without having to buy new servos, fly with a 4.8v receiver pack then switch to a 6v receiver pack. Using the same servos, they will be faster on 6v.
Report back what you think...
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: Dayum Fine Custom Pilot
Old Sep 20, 2012, 10:16 PM
Milwaukie , Oregon
Joined Feb 2003
I am not having no issues with mine or anything I ever built!
So, what do you think is the reason some are having this issue.
You may have more experience than I.
Would love to know, what you think.
Old Sep 20, 2012, 10:37 PM
USA, GA, Atlanta
Joined Nov 2008
sorry, I did not see your post 3335 and thought you were talking about your plane...
I have found that when the servos are up to spec, I usually start at the servo and start working my way back to the control surface. I have found on more than one occasion, a servo had come loose in a servo bay and was not full secure, often times a hinge might need to be retaped to get a better hinge line.... but really could be anything
Old Sep 21, 2012, 07:54 AM
Panzlflyer is offline
Find More Posts by Panzlflyer
Tricopters Rule
United States, NC, Goldsboro
Joined Mar 2012
There is one popular radio that has a tendency to bad pots, that jitters the inputs,you can see it move by itself in the servo monitor screen, another thing to look at.
A lot of people that have bad experience with digitals alo run marginal power systems.
Panzlflyer is offline Find More Posts by Panzlflyer
Old Sep 21, 2012, 08:15 AM
w4Rd3n is offline
Find More Posts by w4Rd3n
w4Rd3n's Avatar
Switzerland, VS, Oberems
Joined Apr 2010
ya i have flutter on my z2. servos are ritewing oem digital servos. but they have some play
http://www.youtube.com/watch?v=PESJ12XYbko
do you think this can be from this.
i don't know if it is the wind here or it is an issue on the z2
here is a recent video:
fpv or nothing (4 min 13 sec)
i have cut alot bad scenes but if i fly down the mountain you can still notice the flutter. also on the climb there was some flutter sometimes. i think this comes from the wind but if i look the videos from trappy, there looks all pretty smooth.
w4Rd3n is offline Find More Posts by w4Rd3n
Old Sep 21, 2012, 03:53 PM
Tricopters Rule
Joined Mar 2012
I see some yawing, flutter is a really fast flapping of the ailerons or control surface that will tear them off in the end, a high speed pass or dive and you would hear it as a buzzing, the end comes shortly after, if you dont slow down.
I would add some glue to that loose servo.
Old Sep 21, 2012, 03:55 PM
Milwaukie , Oregon
Joined Feb 2003
True dat!
Old Sep 21, 2012, 05:47 PM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
klique,have you ever had anyone try to fly a nex-5 type camera? there the mirrorless cameras all the multi rotor AP guys use on mid lift type rigs, high end 1080p 60fs like this
http://www.bhphotovideo.com/bnh/cont...=REG&A=details
there about 12 oz all ready to film,,,,,, if i stuff that as far back as possible and slide a couple 4s packs back,,,,, any ideas on stall speed or what i should use to power it? motor/prop/esc? it'd be a full fpv layout, vtx, lrs rc,board cam works.... the one i got now just like my next witha gopro and 6000 mah 4s stalls at 14mph.
Would i need a special way to get it launched? trials and errors are gonna be expensive to just "try"
Kloner is offline Find More Posts by Kloner
Old Sep 21, 2012, 05:55 PM
klique is offline
Mum is the word!
Joined Jun 2003
Just use a bungee , its a no brianer as long as it ballances.
I think if you jocky things around and change it to ballance it mite just haul the weight.
Maybe even change bat size to help.
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
