Old Sep 17, 2012, 09:01 AM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
From me , ritewingrc.com
klique is offline Find More Posts by klique
Old Sep 17, 2012, 10:04 AM
rc_fpv is offline
Find More Posts by rc_fpv
Joined Jul 2012
They all should be the same price contact ck at ritewing.com
rc_fpv is offline Find More Posts by rc_fpv
Reply With Quote  (Disabled)
Old Sep 17, 2012, 10:05 AM
rc_fpv is offline
Joined Jul 2012
Haha what he said...
Old Sep 17, 2012, 10:20 AM
DoctorAudio is online now
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
You should get the 5mil film and then put your colors on!
I didn't do the 5mil and I did add a couple pieces of CF in the kit!
Really I used two 450 helicopter blades spilt apart.
Two pieces went in the front section of the battery bays, standing vertical.
The other was layed in the battery bay.
I made them so when layed down horizontal across the battey bay.
This make the bay section a little stronger. But I think the next thing I did really strengthen the center section.
I layed vertically three 6 mm X 2mm CF flat rods.
One behind the radio try.
One in the middle of the radio and battey trays.
The last section i placed one is, In the front of the battery bay right behind the front wall.
I have seen this section buckle and start to flex.
I did a couple silly things I did on the 2nd, 3rd, 4th, and 5th launch!
So I had to repair the damage.
May I say each one was like wot into the ground from 10 feet up!
So don't worry about the kit.
I flew mine prefectly with out any mods. Ask me if the mods made a difference?
Yes, which I would have never needed is I didn't donk it in 5 to 6 times.
Below is a two pictures of my ZII with the new Ride on Rail skids mounted and tested.
I made a couple extra and then mounted them on the wing. very easy mod to do. but you have to get the angle right.
It should be on the same angle and the wing tips!
Works perfectly!
DoctorAudio is online now Find More Posts by DoctorAudio
Old Sep 17, 2012, 11:05 AM
w4Rd3n is offline
Find More Posts by w4Rd3n
w4Rd3n's Avatar
Switzerland, VS, Oberems
Joined Apr 2010
guys, how does your z2 perform in wind?
i still have flutter at higher speeds and on windy days. just installed the tbs z2 bay but it did not help a lot
i also nearly have no flex on my wings. a bit on the middle part.
i have attached a picture how the spars are installed. this is on the bottom side.
on the top it is reinforced with the z2 tbs bay.
i think the problem is the weight in the middle section. there is a lot of force. if i would install the lipos further out. (like on the v1 zephyr) this would be a lot better.
are you guys getting better results ?
mb reinforce with glass fiber rods on the top also ?
http://www.youtube.com/watch?v=zdZf7vj-rHQ
w4Rd3n is offline Find More Posts by w4Rd3n
Old Sep 17, 2012, 11:19 AM
Milwaukie , Oregon
Joined Feb 2003
I have tried everything I know, to stopp this on a buddies. I have gotten it to be less visable but it is still there.
I don't know. But he may give me the one he has now and I am going to stripe it clean and rebuild it!
Old Sep 17, 2012, 01:46 PM
klique is offline
Mum is the word!
Joined Jun 2003
How tite is you elevon hinging and controll linckages?
Old Sep 17, 2012, 02:06 PM
w4Rd3n is offline
w4Rd3n's Avatar
Joined Apr 2010
https://www.youtube.com/watch?v=PESJ12XYbko
just the servo play.
Old Sep 17, 2012, 02:14 PM
klique is offline
Mum is the word!
Joined Jun 2003
I did not see any flutter in you video, I did see you over controlling it like you are flying with thumbs, I did see it really windy.
The plane was never left alone it was over controlled almost the whole flight.
Maybe fly it fpv.
Old Sep 17, 2012, 02:21 PM
SENTRY 62 is offline
Find More Posts by SENTRY 62
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
Z2 generally has better low speed handling than that. (as a sidenote... I see that your servo is moving under the lam a bit as well - keep an eye on that).
Can you show a video of full left/neutral/then full right defletion (AILE) - also the same for ELE.
Also - how much does it weigh?
PS: Easy on the thumbs sir - too much input.
I also feel that you are trying to describe yaw wobble instead of flutter?
SENTRY 62 is offline Find More Posts by SENTRY 62
Old Sep 17, 2012, 02:29 PM
w4Rd3n is offline
w4Rd3n's Avatar
Joined Apr 2010
yes it was windy and the throws were pretty high. ill test it again in no winds.
would be nice to see someone else flying the z2 on a windy day. the problem is that we always have some wind here.
Old Sep 17, 2012, 02:35 PM
klique is offline
Mum is the word!
Joined Jun 2003
You will always have some rolling wind between mountains, but the ZII tracks awesome once dialed , and pilot is dialed
Old Sep 17, 2012, 02:44 PM
w4Rd3n is offline
w4Rd3n's Avatar
Joined Apr 2010
ok thank you
Z2
how do you mean that. only on one elevon the throws? or view from behind on the wing?
Z2
2.2 kg
Z2
no if i fly fast i see it flutter. but yaw woble is also noticable. i think i can not get rid of that ? it is better in calm days.
Old Sep 17, 2012, 05:00 PM
klique is offline
Mum is the word!
Joined Jun 2003
How fas are you going when you get the flutter?
Old Sep 17, 2012, 05:12 PM
w4Rd3n is offline
w4Rd3n's Avatar
Joined Apr 2010
i have also flown slowly and it happened. bit only if i fly with headwind
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
