Old Sep 16, 2012, 04:44 AM
IMEIV is offline
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
Now I must choose between these servos:
Hitec HS-625MG - 5.5Kg / 0.18 sec @ 60deg - http://www.hitecrcd.com/products/ana.../hs-625mg.html
Hitec HS-645MG - 8Kg / 0.25 sec @ 60deg http://www.hitecrcd.com/products/ana.../hs-645mg.html
Blue Bird BMS-621MG - 6.4Kg / 0.13 sec @ 60deg - http://www.hobbyking.com/hobbyking/s...13sec_47g.html
Which servos do you use ? And which servos do you suggest ? thanks..
IMEIV is offline Find More Posts by IMEIV
Old Sep 16, 2012, 05:20 AM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
Blue Bird BMS-621MG here.
hefest is offline Find More Posts by hefest
Old Sep 16, 2012, 05:35 AM
mmbbb is offline
Find More Posts by mmbbb
Australia, TAS, Hobart
Joined Jun 2012
Originally Posted by hefest View Post
blue bird bms-621mg here.
+1.
mmbbb is offline Find More Posts by mmbbb
Old Sep 16, 2012, 05:38 AM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
Originally Posted by mmbbb View Post
+1.
Thanks. Do you think that not worth to buy hitec servos ?
Are Blue Bird reliable ?
Old Sep 16, 2012, 07:20 AM
Panzlflyer is offline
Find More Posts by Panzlflyer
Tricopters Rule
United States, NC, Goldsboro
Joined Mar 2012
Im sure I will get shouted down but on Giant scale the 645/625 were poor at centering, I am a Hitec servo fan but quit using those due to that fact, they make some others that have coreless motors that are better, I am not a fan of constant triming.
Buddy of mine ran Bluebirds on a heli ccpm that ran fine, but they are still only 3 pole motors so centering is not as good, but why pay more for the Hitec..
Panzlflyer is offline Find More Posts by Panzlflyer
Old Sep 16, 2012, 07:29 AM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
Ok so I think you would love Hitec HS-965MG (8Kg / o.13sec) with coreless motor... correct ? http://www.hitecrcd.com/products/ana.../hs-965mg.html
Old Sep 16, 2012, 08:37 AM
Tricopters Rule
Joined Mar 2012
Yep, good servo, my alltime favorite were 5955s and 7955s but they are overkill.
There are some 5 pole ones that are a bit better than 3 pole as well.
Old Sep 16, 2012, 08:53 AM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
Yes very good servos. But they are digital and I read many times that it's better to avoid digital servos for FPV.
Old Sep 16, 2012, 10:46 AM
Tricopters Rule
Joined Mar 2012
One manufacturer of lrs said that.................about a certain brand and the story spreads.
If I can use them on planes costing 10 times what a Zephry cost and on my 700 heli with flybarless controller whats wrong with them??
Power consumption you say??? Well the 645 pulls as much power as the 5945 which is its digital version.
The only downside I see is if you let your power drop below say 3.8v the analog will still work but go slow, the digital will quit until the power comes up.
Old Sep 16, 2012, 04:18 PM
dr_patso is offline
Find More Posts by dr_patso
N00b
Boise
Joined Mar 2009
My 3rd Zephyr is up and running finally! This thread is probably the reason my zephyr works, thanks to everyone and chris.
Low flying over water (3 min 35 sec)
dr_patso is offline Find More Posts by dr_patso
Old Sep 16, 2012, 05:51 PM
Tricopters Rule
Joined Mar 2012
Nice.
They are stronger than they look, mine hit the ground 3 times nose first due to the blasted ET Guardian setup, finally turned it off and got 2 good flights.
Old Sep 16, 2012, 05:54 PM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
Ok thanks. Now I think to order Hitec HS-965 servos with coreless motor..
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
http://www.youtube.com/watch?v=B9ovX...ature=youtu.be
Wow I love this video.
Old Sep 17, 2012, 12:22 AM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Trying to decide how to lay out my electronics... I would like to use the designated battery tray for the batteries, rather than digging out battery compartments on the leading edges. But I am having a tough time fitting all my electronics up top. I may keep the ICE on top of the wing in the wind.
RVOSD
Current Sensor
DL
ICE 100
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Dayum Fine Custom Pilot
Old Sep 17, 2012, 08:55 AM
mklinker is offline
Find More Posts by mklinker
mklinker's Avatar
Joined Jun 2011
Readymaderc is out of stock for these... my sky surfer is finally done so I would like to get another plane asap. Where can I buy a zephyr kit in the USA for less than $150?
mklinker is offline Find More Posts by mklinker
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
