Old Sep 10, 2012, 04:10 PM
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
Try motor calc
http://www.ecalc.ch/motorcalc_e.htm?ecalc
Khaled
khaled_abobakr is offline Find More Posts by khaled_abobakr
Old Sep 10, 2012, 04:55 PM
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Okay I went for a smaller motor. More of a lighter one.
The Mega 22/30/3 weighs in at 223 grams. WOW! Over 7 oz.
Pulled a brand new CSRC E25-12 1200kv motor.
Here is the data sheet.
Top speed should be the same.
because looks like I am removing 3 oz from the nose and 2 and a half off the back.
Should make a difference.
Heck I am only loseing about 200 watts.
But this motor weigh in at 150 grams!
DoctorAudio is offline Find More Posts by DoctorAudio
Latest blog entry: Composite 200 mm micro quad!
Old Sep 11, 2012, 12:44 AM
United States, AZ, Gilbert
Joined Nov 2011
Originally Posted by Eagle202 View Post
That makes sense to have something that won't crush when you are securing it.
What is the diameter of your clear rod guides so I know what size collars to get?
Dont know the exact diameter but at the hobby shop they are called the "Guide Tubes for 256 and 440 rod" The collars on the end are 3/16" wheel stops
ronrob61 is offline Find More Posts by ronrob61
Old Sep 11, 2012, 12:51 AM
Joined Nov 2011
Originally Posted by Kloner View Post
are you guys using that as a gimble or just way to keep your case on?
I actually did use it as a gimble. Through a servo behind it and attached it to the box. It worked and tilted the cam about 25degrees down. But the servo was heavy and deff wasnt the best set up. If I do it again Ill move the servo back and bury the rod. I ended up adding a piece of coro to the back of the gopro box as well that protruded out and had the FPV cam attached as well. It was cool, they both tilted together. Ill deff rework this a bit better into another build.
Old Sep 11, 2012, 02:48 AM
Mt Tamborine, Queensland, Australia
Joined May 2008
Originally Posted by khaled_abobakr View Post
rcadvisor.com also has a free online calculator. You have to create an acct (which is also free).
tobermei is offline Find More Posts by tobermei
Old Sep 11, 2012, 09:08 AM
Money Shot
United States, CA, Lakeside
Joined Apr 2010
ron, do you have any video out of it? Needs a gyro attached to it, get rid of the fisheye bit on the gopro
Kloner is offline Find More Posts by Kloner
Old Sep 11, 2012, 12:26 PM
Milwaukie , Oregon
Joined Feb 2003
Okay guys, I need your help.
Really who has the longest distance flight with a ZII?
Me I am not looking for the distance, I am looking for the time aloft.
I would like to go up and fly as long as I do with my old raidian.
I was able to stay aloft for 2 30min flights.
I know some of the info will depend on the wind and location.
But what is the longest ZII flight?
I would love to duplicate it to see if it matches my needs.
There is a awesome drive over some open country on the way to bend, Oregon.
That I would like to try and fly the full 30 min run at 40 mph.
I will also have a video request.
Has two of you FPV guys flown from two different places. And met up in the middle of the two places. Then follow the other back to his take off spot and land.
Old Sep 11, 2012, 01:03 PM
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
I usualy fly for 25-30 min with 2x 4000mah 4s nanotechs with my ZII doing around 38-40mph
hotdog1 is offline Find More Posts by hotdog1
Old Sep 11, 2012, 01:24 PM
Milwaukie , Oregon
Joined Feb 2003
With the stock motor?
Old Sep 11, 2012, 01:28 PM
Money Shot
Joined Apr 2010
mine did 14 miles at 30-40 with stretches of 50-60 mph and had 1400 mah left out of 6000 of packs leaving the 20% in the tank as well. 3014-12 scorp with 9.5x6 with an ice 75
left bar is the speed, right bottom amp draw... it was windy so it's a little skewed, it's gps speed. starts with a tail wind and by 1 minute shows a headwind.
feelin the bottom (3 min 12 sec)
the google earth download showed it traveled 14 miles and was aloft for 21 minutes
Old Sep 11, 2012, 06:26 PM
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
That works for me. Thanks
Vince
Eagle202 is offline Find More Posts by Eagle202
Old Sep 13, 2012, 12:32 AM
DFC~ We Do Flyin' Right
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
Are most of yall running a 30 or 36 inch DL antenna on your Zephyrs?
Do I get better reception with a longer antenna?
bsbauman is offline Find More Posts by bsbauman
Latest blog entry: Burned Retina Shorts
Old Sep 13, 2012, 01:10 AM
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
im using ez uhf. when i was on Mhz though i had a 4m antenna. it was awesome, just a little cumbersome and draggy.
brosius85 is online now Find More Posts by brosius85
Old Sep 13, 2012, 09:19 AM
Money Shot
Joined Apr 2010
no, the shorter the better. most of have the rx out on the end of the wing. The DL antennas length is just how long the wire from the rx to the 1/2 wave dipole.
mine is like this
i'm on ez too, but am using the same antenna you mention,,,
Old Sep 13, 2012, 05:47 PM
j j
United States, CA, Santa Clarita
Joined Sep 2012
what do you think the best advance controller is for the zephry 2
j j is offline Find More Posts by j j
Build Log Building the ultimate Ritewing Zephyr ThomasWF Video Piloting (FPV/RPV) 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect Video Piloting (FPV/RPV) 2 Mar 07, 2011 04:37 PM
