Old Jul 22, 2012, 11:56 AM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Beautiful Locko , no music needed when you have great pilot a well tuned ZII , and a great place to fly.
Watched the whole vid, great Job!!!!
So smooth!!!!
klique is offline Find More Posts by klique
Old Jul 22, 2012, 01:58 PM
w4Rd3n is offline
Find More Posts by w4Rd3n
w4Rd3n's Avatar
Switzerland, VS, Oberems
Joined Apr 2010
i have some vibrations if flying at high speeds.
gopro is hard mounted. one wing is a bit loose on top side. just the glue. on the bottom side is a CF spar which is holding the wing just fine.
maybe this which is causing the surface to vibrate at higher speed ?
any idea?
w4Rd3n is offline Find More Posts by w4Rd3n
Old Jul 22, 2012, 02:03 PM
klique is offline
Mum is the word!
Joined Jun 2003
Is your prop ballanced , is it a folder, do you have a few pix of your plane?
Are they body waving up and down or are the vibration?
Old Jul 22, 2012, 03:12 PM
w4Rd3n is offline
w4Rd3n's Avatar
Joined Apr 2010
prop is balanced . no folder. i have glued the other wing now. just a little too much glue i ll report if this was the problem. i don't think so.
i lost one landing skid in the grass during a bad launch. therefore i have put on some home made. maybe they are not so aerodynamic and cause this vibration at higher speed?
Old Jul 22, 2012, 03:34 PM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
when you say high speed, how high? what power system and prop are you running?
brosius85 is offline Find More Posts by brosius85
Old Jul 22, 2012, 03:39 PM
w4Rd3n is offline
w4Rd3n's Avatar
Joined Apr 2010
9x6 prop. ritewing esc and motor combo. 80mph+
4s 2x 3000 zippy
Old Jul 22, 2012, 04:08 PM
klique is offline
Mum is the word!
Joined Jun 2003
The hard wood mounts for the cam and motor plate will also transfer alot of vibration.
There is a reason why my cam box is made of coro , it cancels vibrations out.
Old Jul 22, 2012, 04:40 PM
w4Rd3n is offline
w4Rd3n's Avatar
Joined Apr 2010
the motor plate is not fixed to the wood mount. between them is foam.
Old Jul 22, 2012, 04:54 PM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
if you put up some video we can probably diagnose a bit better
Old Jul 22, 2012, 04:58 PM
klique is offline
Mum is the word!
Joined Jun 2003
Ok, does it CG with the motor on the other side of the mount, the prop mounted close to the mount will help, but a Vid would be nice to see the type of vibrations you are talking about.
Aerodynamic or mechanical??
Old Jul 22, 2012, 05:20 PM
w4Rd3n is offline
w4Rd3n's Avatar
Joined Apr 2010
http://www.youtube.com/watch?v=nzoph...=youtube_gdata
it was pretty windy this day.
Old Jul 22, 2012, 05:52 PM
klique is offline
Mum is the word!
Joined Jun 2003
Thats a slight aero dynamic wingflex flutter.
It is not from the motor , it could be from all the over sized skids and rough box , it could be causing buffeting over the center of the wing top and bottom.
Old Jul 22, 2012, 06:05 PM
w4Rd3n is offline
w4Rd3n's Avatar
Joined Apr 2010
Thanks for this answer. I ll change them out to see if this was causing it.
Old Jul 22, 2012, 06:34 PM
klique is offline
Mum is the word!
Joined Jun 2003
I saw that ZII fly when rocky had it and it was real smooth , I bet its the cross country skids you put on it.
Old Jul 22, 2012, 07:47 PM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
to me it just looks too fast. the first dive - you are pushing the limit of what the plane will survive. there are a bunch of guys that have seen that, gone slightly faster and the airframe folds.
try the skids but be cautious pushing it that hard, unless you beef up the reinforcements.
is this right CK? if you think its a load of crap i will delete it bro
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
