Old Jul 15, 2012, 05:10 PM
tobermei is offline
Find More Posts by tobermei
Mt Tamborine, Queensland, Australia
Joined May 2008
Originally Posted by marhar View Post
Can I use 3M 77 for applying the lamination? Is it similar to loctite 200?
Yep, I used 3M Super 77 for applying the laminate, worked just fine.
tobermei is offline Find More Posts by tobermei
Old Jul 16, 2012, 09:44 AM
kefir is offline
Find More Posts by kefir
Poland Gdynia
Joined Feb 2009
Hello
Gentlemen, tell the repair such damage
or inserted into the hot water is a fix?
Because at 160km / h lost visions and hit a tree: (
kefir is offline Find More Posts by kefir
Old Jul 16, 2012, 11:01 AM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by kefir View Post
Hello
Now I know what it looks like to hit a tree at 100 pmh. I think you will need more than hot water to fix. At least the spars stayed in so you must have done a decent job building your ZII.
The nose should come back out with the hot water or hot air but that crack going to the back will need more help. Maybe some type of spare inserted perpendicular to the crack and then glued. Probably gorilla glue which is lighter than hot glue and stronger. You don;t want to make one side that much heavier than the other.
I just saw the close up of the underside. Looks like the fiberglass spare has been dislodged a little and the main carbon spars may be cracked. Can't tell how bad but they look bent. Need to fix those as well.
Eagle202 is offline Find More Posts by Eagle202
Old Jul 16, 2012, 11:06 AM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
double post
Old Jul 16, 2012, 02:40 PM
w4Rd3n is offline
Find More Posts by w4Rd3n
w4Rd3n's Avatar
Switzerland, VS, Oberems
Joined Apr 2010
are you guys using differential on the ailerons?
do you use bigger throws for landing? i did a test today and at slower speeds the elevator loses pretty fast his effect.
w4Rd3n is offline Find More Posts by w4Rd3n
Old Jul 16, 2012, 03:51 PM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
nope, i like to have them with a large throw at all times, i just go gentle on the sticks. when going slow, however, at some point, there just isn't enough airspeed for them to have any effect no matter the angle (when its heavy in particular, you can't go all that slow)
if you really don't have much throw when you fly you might want to have a rate switch for landing/slow speed. a matter of preference i guess.
as for differential it doesn't really make sense on elevons afaik. you'd need some kind of tail and true ailerons. (like a plank wing?)
CrashMeUp is offline Find More Posts by CrashMeUp
Old Jul 16, 2012, 05:47 PM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
kefir - try a heat gun on it for a little. it should come out a fair bit.
brosius85 is offline Find More Posts by brosius85
Old Jul 17, 2012, 01:55 PM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Weight range?
What's the typical weight range for a Zii?
lightest ever:
heaviest ever:
typical non-fpv:
typical fpv:
Does the COG vary by weight?
marhar is offline Find More Posts by marhar
Old Jul 17, 2012, 03:20 PM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
i think these were about 1.5kg - im not too sure. foam elevons over the blasa ones, no laminate, 2200 3s battery, motor mount cut in even deeper than standard, tiny motor, tiny servos
SEFF 2012 Paintball Shoot (7 min 47 sec)
heaviest i know of was adamchicago with a 3.6kg zeph (not a ZII)
my old ZII was 2.7kg it flew fine. it had 6600 of 6s
typical weight for FPV is about 2.2 -2.4 kg with 6600 of 4s.
the CG is always the same.
Old Jul 18, 2012, 05:54 PM
RemiWM is offline
Find More Posts by RemiWM
Norway
Joined Feb 2012
My Z2 is on a ride again. Got 5 km out, and could go much further... Enjoy!
FPV - Zephyr Experience (4 min 37 sec)
RemiWM is offline Find More Posts by RemiWM
Old Jul 21, 2012, 04:40 PM
zkilzz is offline
Find More Posts by zkilzz
Joined Sep 2011
http://www.youtube.com/watch?v=HxIR09m23js
Mine had 10.000MAH 4S and a really heavy motor. It flew nice and glided nice.
zkilzz is offline Find More Posts by zkilzz
Old Jul 22, 2012, 01:17 AM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
heres a video of my 1st fpv flight and first long range flight with my z2 its in fairbanks alaska enjoy
RiteWing Zephyr 2 1st FPV flight 2miles out Fairbanks, Alaska (5 min 6 sec)
flohio117 is offline Find More Posts by flohio117
Old Jul 22, 2012, 03:42 AM
Locko is offline
Find More Posts by Locko
Locko's Avatar
Australia, WA
Joined Oct 2011
Heya fellas Loving the Z2 , here is a bit of footage on my 4 day break in Dunsborough Western Australia
Dunsborough (4 min 24 sec)
Locko is offline Find More Posts by Locko
Old Jul 22, 2012, 03:51 AM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
nice effort locko what a spot!
Old Jul 22, 2012, 09:09 AM
Locko is offline
Locko's Avatar
Australia, WA
Joined Oct 2011
Thanks Bro, Finally mastered the pizza box z2 launch with out sweating/shaking too much.
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
