Old Jul 12, 2012, 08:02 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by klique View Post
Even 5 to 8 clicks up from neutral wont get you in trouble usually.
I also do never use expo , I lower the rates , it makes your flights much more smooth .
I usually do a higher rate for fatser speeds , and lower it 10 % for lower speeds .
I have flown thumbs in the past and now fly pinch with two fingers, this has made a huge improvement in flight, it makes me fly much more smooth and true.
I feel more in control , I dont chase the plane , I am in control.
You wife would laugh at you if you tried to touch her with just your thumbs, but two fingers will make her much more happy. You dont point with your thumb m you dont pull a trigger with your thumb, why would you fly a precise plane with only your thumb???
Nice analogy about using two fingers on the wife.
Are you saying that your D/R setup for the Lo rates is 10 % for Aileron and Elevator and 100 % for the high rate?
Eagle202 is offline Find More Posts by Eagle202
Old Jul 12, 2012, 08:07 PM
dr_patso is offline
Find More Posts by dr_patso
N00b
Boise
Joined Mar 2009
wait i use dual rates to set my end points.. probably not the best way.. but wouldn't this be "lowering rates" as well as expo? It flies real nice with these settings.. this is for ailerons, pretty much the same for the elevators..
dr_patso is offline Find More Posts by dr_patso
Old Jul 12, 2012, 08:49 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Your ail can usually be 10 20 to 30 % more than elev dep on how you fly.
klique is offline Find More Posts by klique
Old Jul 12, 2012, 08:53 PM
dr_patso is offline
N00b
Boise
Joined Mar 2009
well my ailerons have 3mm more travel.. but the expo is the same.
Old Jul 12, 2012, 08:55 PM
chicken sashimi is offline
Find More Posts by chicken sashimi
WOT happened?
chicken sashimi's Avatar
Canada, BC, Vancouver
Joined Sep 2011
My wife likes a little expo now and then.
chicken sashimi is offline Find More Posts by chicken sashimi
Old Jul 12, 2012, 10:51 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
I use travel adjustment to set my end points. My hi rate is at 100% and lo rate is 60 to 70% but I may adjust it to keep from over correcting.
The question is how much is any Expo should I use? I guess that is going to depend on how fast I want my ZII to respond to stick control.
It won't matter if I yank and bank the stick to the full position.
Old Jul 13, 2012, 12:57 AM
tobermei is offline
Find More Posts by tobermei
Mt Tamborine, Queensland, Australia
Joined May 2008
How difficult was the transition? Any tips?
tobermei is offline Find More Posts by tobermei
Old Jul 13, 2012, 01:07 AM
klique is offline
Mum is the word!
Joined Jun 2003
Just start the transition , you will find yourself adjusting the rates to get a better feel
Old Jul 13, 2012, 09:15 AM
flyn is offline
Find More Posts by flyn
flyn's Avatar
United Kingdom, England, Cambs
Joined Jun 2009
Just thought I'd share,
spent an afternoon making my bungee launcher earlier this week & yesterday I got a break in the weather to try it.
Worked like a charm 1st time!!
ZII Bungee Launcher (1 min 23 sec)
Here's the how I attached the launch hook - it goes through the foam belly & bolts into the battery box, the ply plate is to help spread the load of launching across the foam.
flyn is offline Find More Posts by flyn
Old Jul 13, 2012, 09:39 AM
nakelp86 is online now
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
spent an afternoon making my bungee launcher last week & yesterday I got a break in the weather to try it.
whats the minimum length and angle of the launcher?
nakelp86 is online now Find More Posts by nakelp86
Old Jul 13, 2012, 10:25 AM
flyn is offline
flyn's Avatar
Joined Jun 2009
Hi,
The launcher pipes were cut to 5ft length, 2ft wide, rear upright 1ft, front upright 2.5ft (maybe a little high - go with 2ft). The 2 holes at the back are for staking down, we use 6-7m of 8mm bungee & a cork screw type dog lead ground anchor.
Old Jul 13, 2012, 10:36 AM
Nakelp
nakelp86's Avatar
Joined Sep 2004
Thx a lot , so I see it doesnt have to be that long which is great to load it in the car :-)
Old Jul 13, 2012, 10:37 AM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
Nice launcher Flyn!
Ian Davidson is offline Find More Posts by Ian Davidson
Old Jul 13, 2012, 11:10 AM
flyn is offline
flyn's Avatar
Joined Jun 2009
NP fella, that's the exact reason it's the size it is, it fits perfectly. Also don't know if you can see in the vid but the uprights are removable & are held in with a bolt & wing-nut so no tools required to pitch up or pull down.
Oh & if you make one, make sure you don't leave the lip on the end of the rail where the joint is, tape it smooth or grind it off - it'll rip your ZII up!
Originally Posted by Ian Davidson View Post
Nice launcher Flyn!
Cheers mate
Old Jul 13, 2012, 12:48 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
http://youtu.be/0fJIosJlO3c
Nice job on the bungee launcher and hook. I like the way you used the ply to spread out the load.
As for where you are flying. Why did you have to cut down all of the trees?
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
