Old Jul 10, 2012, 11:58 PM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
Originally Posted by klique View Post
LOL, well when you start flying at spersonic speeds then I will make wipers for you and servo cowlings.
You dont need wipers at supersonic here is the proof
GoPro F18 Fighter Jet (3 min 56 sec)
freshmint is offline Find More Posts by freshmint
Old Jul 10, 2012, 11:59 PM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
Originally Posted by tobermei View Post
What was the setup on that fast wing? motor / esc / battery / prop?
it is not a ZII, its a D40
brosius85 is offline Find More Posts by brosius85
Old Jul 11, 2012, 06:24 AM
RCTinTin is offline
Find More Posts by RCTinTin
Joined Jun 2007
My Zii is going well with the building stage, but at this time, I do not have all the funds for the FPV gear. I want to just fly the Zii with the GoPro and just get used to flying her.
My question is, is the lam easy to pull back off for when I want to install the FPV gear at a later date? Or do I just cut out where I want to fit the gear, and lam over the top of the cutouts?
Thanks guys
RCTinTin is offline Find More Posts by RCTinTin
Old Jul 11, 2012, 11:09 AM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Dont pull it off , just slice gear in and relam over when ready
klique is offline Find More Posts by klique
Old Jul 11, 2012, 01:11 PM
RCTinTin is offline
Joined Jun 2007
Thanks Chris
Old Jul 12, 2012, 05:36 PM
w4Rd3n is offline
Find More Posts by w4Rd3n
w4Rd3n's Avatar
Switzerland, VS, Oberems
Joined Apr 2010
where to measure the aileron resp. elevator throws?
at the end of the elevons near the winglets or at the hinge?
w4Rd3n is offline Find More Posts by w4Rd3n
Old Jul 12, 2012, 05:52 PM
dr_patso is offline
Find More Posts by dr_patso
N00b
Boise
Joined Mar 2009
i always measure towards the outside of the wing...
10mm + and 10mm - for elevator 13mm + and 13mm - for ailerons.... I put the wing on the floor like it's flying and put a a ruler on the ground vertically and measure that the trailing edge of the elevons moves those measurements
dr_patso is offline Find More Posts by dr_patso
Old Jul 12, 2012, 05:53 PM
dr_patso is offline
N00b
Boise
Joined Mar 2009
40-60% expo too..
Old Jul 12, 2012, 05:56 PM
w4Rd3n is offline
w4Rd3n's Avatar
Joined Apr 2010
Thank you!
Old Jul 12, 2012, 07:05 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
For my clarification when you measure the aileron travel of +/- 13mm are you just moving the stick full left and full right or are you moving it on a diagonal from the center position?
I am still making setup adjustments and have the same +/- 10mm for the elevator and +/- 10 for the aileron but that measurement increases to almost +/- 20mm when I combine both elevator and aileron control.
All those dimensions are when I am using my Hi rate. They are smaller when I switch to my Lo rates.
Eagle202 is offline Find More Posts by Eagle202
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Originally Posted by Eagle202 View Post
Chris
Really top notch job on the Burly ZII. Looks like a stealth tank.
I also like the Ritewing decals on the elevons. Let me know how to order a half dozen of them so I can spread the word on who makes these fantastic wings. Thanks
Vince
+1
:-)) could use few myself
nakelp86 is offline Find More Posts by nakelp86
Old Jul 12, 2012, 07:06 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Just check Chris' video he explains it very clearly
Old Jul 12, 2012, 07:39 PM
klique is offline
Mum is the word!
Joined Jun 2003
Even 5 to 8 clicks up from neutral wont get you in trouble usually.
I also do never use expo , I lower the rates , it makes your flights much more smooth .
I usually do a higher rate for fatser speeds , and lower it 10 % for lower speeds .
I have flown thumbs in the past and now fly pinch with two fingers, this has made a huge improvement in flight, it makes me fly much more smooth and true.
I feel more in control , I dont chase the plane , I am in control.
You wife would laugh at you if you tried to touch her with just your thumbs, but two fingers will make her much more happy. You dont point with your thumb m you dont pull a trigger with your thumb, why would you fly a precise plane with only your thumb???
Old Jul 12, 2012, 07:53 PM
dr_patso is offline
N00b
Boise
Joined Mar 2009
haha you made a reference to touching lady parts, do you apply gold bond with two fingers?
Old Jul 12, 2012, 08:00 PM
dr_patso is offline
N00b
Boise
Joined Mar 2009
anyway, i'm not sure what lowering rates would accomplish I actually don't understand higher level RC well at all, but so many RC nuts are using expo like me.
if the full range of the stick goes from 0 to the 10mm or 13mm spots.. what would lowering rates do? I understand expo makes it smooth in the center of the stick but then theres a huge jump if you need to make a big maneuver.. is it not actually more precise? just makes it move slower but at bigger steps?? lets say, like just chopping a video from 30fps to 15fps?
lowering rates does it give you less throw?, you get more resolution?? so you do that first then your end points??
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
