Old Jun 25, 2012, 06:54 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by freshmint View Post
Mine is a little heavy 7.2lbs so I had to raise the min/max speed. other than that nothing changed RTH work perfect! the rest you just set to your preference
Is the extra weight from all that armor monokote you used?
I don't have any FPV gear but mine only weighs about 2kg or about 4.4 lb. I can't believe all of your FPV hardware is almost 3 lbs in weight.
Eagle202 is offline Find More Posts by Eagle202
Old Jun 25, 2012, 09:00 PM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Part II of my maiden, loving this bird, handles the wind like a champ.
FPV Zephyr 2: Maiden Flight Part II. (2 min 35 sec)
Kev.au is offline Find More Posts by Kev.au
Old Jun 26, 2012, 04:55 AM
SPG is offline
SPG
Find More Posts by SPG
SPG
Sydney, Australia
SPG's Avatar
Australia, NSW, Sydney
Joined Jan 2010
http://www.youtube.com/watch?v=spLObEz8fkA
Nice video Kev. You do know you don't have to fly a full throttle all the time
SPG is offline Find More Posts by SPG
Old Jun 26, 2012, 06:15 AM
Macattaka is offline
Find More Posts by Macattaka
Beyond the BlackStump
Macattaka's Avatar
Australia, SA, Adelaide
Joined Mar 2006
Bollox to that idea!....
Great vid Kev.
Macattaka is offline Find More Posts by Macattaka
Old Jun 26, 2012, 06:43 AM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
yea lol, that flight lasted 20min and i covered 30km all within 1km hahaha, tha's a sh*t load of high speed passes.
Great vid Kev.
Thanks mate .
Old Jun 26, 2012, 09:11 AM
drumbum961 is offline
Find More Posts by drumbum961
Joined Dec 2010
Holy cow kev! That thing is moving! what are you running for a motor/esc and batts? That z rips! Nice flying!
KFM
drumbum961 is offline Find More Posts by drumbum961
Old Jun 26, 2012, 10:00 AM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
Nice video. I think I would have crashed playing chicken with those trees that looked like you were doing.
Watching you catch up to the other Z at the end of the video all I could think about was adding the text "fox 2 away" or "guns guns guns" caused it looked like you were dog fighting.
Old Jun 26, 2012, 10:23 AM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
KFM
Hey thanks man.
2x RMRC 3300 4s from ReadyMadeRC, 60 amp plush ESC, Hyperion Zs 3014-12, 9x7 folding prop. AUW is at 2.4kg and this set-up produces 700watts @ just under 50 amps. Got a solid 20min flight with ALOT of full throttle runs. Motor/prop was recommended by Sander.
heheh was a ZII i was chasing running a 3s set-up, that was my first time trying formation, it's harder then it looks!.
Old Jun 26, 2012, 07:57 PM
Maddmax is offline
Find More Posts by Maddmax
United States, TN, Lebanon
Joined Jun 2011
I think I'm going to give my ZII another shot. What trim levels and settings are you guys using???
Maddmax is offline Find More Posts by Maddmax
Old Jun 26, 2012, 08:07 PM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
Run elevons flat with top of wing with only a couple of mm of up reflex , EDIT: CG at 9 1/4 - 9 1/2 in from the nose, full throttle over arm launch.
brosius85 is offline Find More Posts by brosius85
Old Jun 26, 2012, 08:12 PM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
I only needed about 3mm of reflex, i have 10mm throw both ways and that felt about right.
Old Jun 27, 2012, 04:31 AM
flyn is offline
Find More Posts by flyn
flyn's Avatar
United Kingdom, England, Cambs
Joined Jun 2009
Originally Posted by flyn View Post
Wow! That does sound a little heavy, bet it flies real smooth though!
Thanks, those RTH numbers should be a good starting point when I get mine ready to fly, I've just used an old ethernet cable as a AV cable to the VTX, need to test it before I glue it in - I really hope it works!!!
Im getting there with the component layout now as well, just cut the VTX into the wing. I'm going to need to put the GPS unit & the RC RX on the same wing quite close together, will that be ok?
Also to anyone who might know, should I 3m77 the Lam on then stick my carbon vinyl bands (go-faster stripes) on top - or should I stick the carbon vinyl bands to the wings with 3m77 then Lam over the top? I'm thinking the latter as I dont want the CF stickers getting ripped off in flight.
I just need a whole day or two to get this build finished but it seems everything else is getting in the way, I mean - who needs to earn a living, drive hundreds of miles in a gutless courtesy car while mine gets a new gearbox, answer endless work emails, feed the cat, clean the house, visit parents & go on holiday for a week anyway right?!?!
It seems like its just dragging & I'm not getting anywhere, like today all I did was to make an AV cable that might not work. Doh!
I'm sooo close I can't wait but I don't want to rush it.
Thanks.
Tested my homemade ethernet AV cable - it seemed to work great on the ground! So fingers crossed.
I've pretty much got all components cut into the wing & the ol' gal is about ready to be Lam'd - can anyone help with my above question about stick on decals & Lam'ing?
flyn is offline Find More Posts by flyn
Old Jun 27, 2012, 04:58 AM
Bauf is offline
Find More Posts by Bauf
Norway
Joined Aug 2011
Originally Posted by brosius85 View Post
Run elevons flat with top of wing with only a couple of mm of up reflex , cg at 10.5 , full throttle over arm launch.
CG @ 10.5 inches, that's 26.6cm. wasn't the CG @ 23.8cm? I'm struggling to get my Z2 in the air, finished the build about a week ago. Have managed to get 4 launches, broken prop on 2 of them.
I have the CG @ 23.8cm from the nose, 2 times i've launched it over the head with one arm holding the nose, with a few mm up flex. It went down 3m away Will get a friend to throw it next time.
I'm using the ritewing motor and esc, 2x 4s 3300. And it weighs in @ 3.1kg
Bauf is offline Find More Posts by Bauf
Old Jun 27, 2012, 05:01 AM
Peck is offline
Find More Posts by Peck
Hungary, Budapest
Joined Jun 2009
The manual says:
CG is located on the bottom 9 3/8‘’ to 9 1/2’’ from the nose back.
Peck is offline Find More Posts by Peck
Old Jun 27, 2012, 05:26 AM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
oops - i was remembering the old Z CG.... WHOOOOPS!
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
