Old Jun 24, 2012, 08:48 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Gosh tons more to read, but I am a few hundred posts deep. Few questions so far:
Other than the spray adhesive, is anyone using something else for joining the wing halves? Can I get away with an epoxy joint here? or is that not recommended?
Is there a single thread that covers most of the mods you all are doing during the build? There are some long long threads out there, has anyone posted some clifnotes?
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Pin-ups
Old Jun 24, 2012, 08:56 PM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Don't use Epoxy as it doesn't bond very well. Use some UHU POR, apply some to both wing roots, let it tack off then slap em together. Or regular CA will work also.
Kev.au is offline Find More Posts by Kev.au
Old Jun 24, 2012, 09:03 PM
wootenelli is offline
Find More Posts by wootenelli
Michael W.
wootenelli's Avatar
United States, TN, Cleveland
Joined Nov 2011
I used gorilla glue. I read of other guys using CA with activator, as well as some guys said they used hot glue or epoxy. In my case, making sure the gorilla didn't misalign the halves was a challenge but worth the bond
wootenelli is offline Find More Posts by wootenelli
Old Jun 24, 2012, 09:23 PM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
I used the spray adhesive and then filled the gaps I could see withe CA. I was going to use Epoxy for the motor mount, but used Gorilla Glue, and it is rock solid! I could swing from it! LOL!
Hot glue works well on Servos etc.
Cheers
MG
The_Mongrel is offline Find More Posts by The_Mongrel
Old Jun 24, 2012, 09:28 PM
USA, GA, Atlanta
Joined Nov 2008
thanks fellas!
Old Jun 25, 2012, 12:37 AM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
Originally Posted by flyn View Post
Sweet thread dude! Loads of good info in there, did your RTH settings change much after you posted #225 - on page 23.
Mine is a little heavy 7.2lbs so I had to raise the min/max speed. other than that nothing changed RTH work perfect! the rest you just set to your preference
freshmint is offline Find More Posts by freshmint
Old Jun 25, 2012, 03:20 AM
slarys is offline
Find More Posts by slarys
The Netherlands
Joined Jul 2011
UHU POR is my favorite. It is very powerful.
slarys is offline Find More Posts by slarys
Old Jun 25, 2012, 08:59 AM
Locko is offline
Find More Posts by Locko
Locko's Avatar
Australia, WA
Joined Oct 2011
I use hot glue on wing cores. Nice & easy and strong as. Ive just built my 5th z2, after a few crazy crashes the wing has NEVER ever separated at the core join. And the best thing about hot glue , is that in about 10mins it done, on to the next part of gluing the spars and motor mount
Just be careful if you have a high temp glue gun
Locko is offline Find More Posts by Locko
Old Jun 25, 2012, 09:50 AM
USA, GA, Atlanta
Joined Nov 2008
Thanks for the guidance fellas!
Old Jun 25, 2012, 10:04 AM
ghost2212 is offline
Find More Posts by ghost2212
Skint since 2000
ghost2212's Avatar
Reading, United Kingdom
Joined Oct 2008
Originally Posted by ghost2212 View Post
Is it okay to use epoxy resin on the zephyr II? I was thinking of laying down some light glass fibre around the battery area and where my GoPro box will be as I've seen this is one of the weak points.
Also what paints do people use on the plane before lamming? Am i right in saying you tend to paint then put the 3M77 on then laminate?
Brett
Anyone?
ghost2212 is offline Find More Posts by ghost2212
Old Jun 25, 2012, 10:13 AM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Epoxy is fine , just watch out its heavy.
As per directions spray paint can be used , please read directions.
Anyone?
klique is offline Find More Posts by klique
Old Jun 25, 2012, 03:27 PM
tobermei is offline
Find More Posts by tobermei
Mt Tamborine, Queensland, Australia
Joined May 2008
I found a foam safe RC paint. "RC Styro Colours"
tobermei is offline Find More Posts by tobermei
Old Jun 25, 2012, 05:14 PM
ronrob61 is offline
Find More Posts by ronrob61
United States, AZ, Gilbert
Joined Nov 2011
Rustoleum ULTRA COVER works well too. IT IS NOT FOAM SAFE but dries very fast. If you used light coats and let it dry a few mins between coats it wont damage the foam. The nice thing about this paint is that it takes heat really well and the lam sticks to it great.
ronrob61 is offline Find More Posts by ronrob61
Old Jun 25, 2012, 05:23 PM
ronrob61 is offline
Joined Nov 2011
Originally Posted by Acorns View Post
Interesting! I didn't realize that was what all of this "outside" mounting talk was about. Looks like all I have to do is unscrew it and swap sides too. If it is enough, it will make my CG issues really easy to deal with. Thanks!
Hey bud, Ron here. I had shipped that wing out to the origional owner with the kit to flip the motor in its mount. If you didnt get it when you purchased the plane from him hit me up with an im and Ill send you one for free. Man I loved that pink wing!
Old Jun 25, 2012, 05:44 PM
flyn is offline
Find More Posts by flyn
flyn's Avatar
United Kingdom, England, Cambs
Joined Jun 2009
Wow! That does sound a little heavy, bet it flies real smooth though!
Thanks, those RTH numbers should be a good starting point when I get mine ready to fly, I've just used an old ethernet cable as a AV cable to the VTX, need to test it before I glue it in - I really hope it works!!!
Im getting there with the component layout now as well, just cut the VTX into the wing. I'm going to need to put the GPS unit & the RC RX on the same wing quite close together, will that be ok?
Also to anyone who might know, should I 3m77 the Lam on then stick my carbon vinyl bands (go-faster stripes) on top - or should I stick the carbon vinyl bands to the wings with 3m77 then Lam over the top? I'm thinking the latter as I dont want the CF stickers getting ripped off in flight.
I just need a whole day or two to get this build finished but it seems everything else is getting in the way, I mean - who needs to earn a living, drive hundreds of miles in a gutless courtesy car while mine gets a new gearbox, answer endless work emails, feed the cat, clean the house, visit parents & go on holiday for a week anyway right?!?!
It seems like its just dragging & I'm not getting anywhere, like today all I did was to make an AV cable that might not work. Doh!
I'm sooo close I can't wait but I don't want to rush it.
Thanks.
flyn is offline Find More Posts by flyn
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
