Old Jun 23, 2012, 03:46 PM
ghost2212 is online now
Find More Posts by ghost2212
Skint since 2000
ghost2212's Avatar
Reading, United Kingdom
Joined Oct 2008
Epoxy Resin
Is it okay to use epoxy resin on the zephyr II? I was thinking of laying down some light glass fibre around the battery area and where my GoPro box will be as I've seen this is one of the weak points.
Also what paints do people use on the plane before lamming? Am i right in saying you tend to paint then put the 3M77 on then laminate?
Brett
ghost2212 is online now Find More Posts by ghost2212
Old Jun 23, 2012, 03:47 PM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
Originally Posted by superevan View Post
No problem! In fact I have 2 3s 3000mah turnigy with motor inside motor mount and, with no gopro or camera pod still have to add 350g dumb weight to the nose. Needless to say, I got a gopro
What flight times are you getting with that setup?
hefest is offline Find More Posts by hefest
Old Jun 23, 2012, 05:07 PM
Acorns is offline
Find More Posts by Acorns
United States, IA, Mason City
Joined Oct 2008
That is the same thing I am running, although Zippy atm instead of Turnigy. I'm getting 30 mins flying normally, 15 pretty aggressively, or 50 treating it like a glider.
Acorns is offline Find More Posts by Acorns
Old Jun 23, 2012, 06:52 PM
flyn is offline
Find More Posts by flyn
flyn's Avatar
United Kingdom, England, Cambs
Joined Jun 2009
Originally Posted by brosius85 View Post
i used to use a seperate battery for the video gear, but it is annoying keeping track of what is left in the battery, and having to plug in an extra battery all the time etc....
single batt systems are just easier to manage. but you need filters and regulators when using 4s so it can get a bit more complicated / expensive when setting it all up.
i just run the signal wire to the rx from the servo, i run the red and black straight to the BEC. the esc needs all 3 wires to function though.
I can see where you're coming from with the one pack setup but I just like the idea of having a clean independent power supply for my cam that won't be under load from other systems. With my ETosd I've set it up to have an onscreen AV pack display bar as well as the flight pack display, which is very helpful.
Originally Posted by Eagle202 View Post
That is really easy to understand. Great job Brosius.
+1!!
flyn is offline Find More Posts by flyn
Old Jun 23, 2012, 06:56 PM
flyn is offline
flyn's Avatar
Joined Jun 2009
Originally Posted by freshmint View Post
I'm also running full ETOsd check out my build on fpvlab.com
http://fpvlab.com/forums/showthread.php?5733-FM-Z2
Niceone, thanks for the link - ill be sure to check it out!!!
Old Jun 23, 2012, 09:16 PM
traderdmb is offline
Find More Posts by traderdmb
FPV nut
traderdmb's Avatar
Sorrento, FL
Joined Nov 2010
My first time Mountain surfing with the Z2.
http://www.youtube.com/watch?v=Di6tk...mment_received
traderdmb is offline Find More Posts by traderdmb
Old Jun 23, 2012, 10:39 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Great video. How far was that rock from you launch point?
Eagle202 is offline Find More Posts by Eagle202
Old Jun 24, 2012, 12:22 AM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
At the end you said your your video system sucked.. what are you using? 2.4?
freshmint is offline Find More Posts by freshmint
Old Jun 24, 2012, 07:23 AM
SPG is offline
SPG
Find More Posts by SPG
SPG
Sydney, Australia
SPG's Avatar
Australia, NSW, Sydney
Joined Jan 2010
Finished My ZII build yesterday and maidened today and I have to say I am totally stoked!
Well done CK. What a great flying FPV plane.
Like everyone says, "It goes where you point it" and keeps heading in that direction until you point it somewhere else.
Can't wait to put a few more flights on it and really put it through its paces.
Video to come.
SPG is offline Find More Posts by SPG
Old Jun 24, 2012, 12:30 PM
flyn is offline
flyn's Avatar
Joined Jun 2009
Sweet thread dude! Loads of good info in there, did your RTH settings change much after you posted #225 - on page 23.
Old Jun 24, 2012, 01:23 PM
FPV nut
traderdmb's Avatar
Sorrento, FL
Joined Nov 2010
I was on 900mhz and when I got close to the cliff, my downlink got really really bad. YOu can see where I attempted to fly down the face and when I went vertical it would go pure snow. I could see nothing. My buddy Don (realtvnow) was on 1.28 and his video was rock solid.
Old Jun 24, 2012, 01:24 PM
FPV nut
traderdmb's Avatar
Sorrento, FL
Joined Nov 2010
it was about 1.5 miles from launch point I think.
Old Jun 24, 2012, 01:25 PM
FPV nut
traderdmb's Avatar
Sorrento, FL
Joined Nov 2010
Video to come.
very nice build man. Congrats! you did a great job on that Z.
Old Jun 24, 2012, 01:32 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
I was wondering if you were going to chance it and fly above or beyond it but I thought maybe you were at the max range for video or control.
Too bad about your video breaking. I would have like to have seen you "ski" down the rock face and pull out before hitting them trees.
Old Jun 24, 2012, 01:40 PM
FPV nut
traderdmb's Avatar
Sorrento, FL
Joined Nov 2010
stay tuned, I have another video that I am working on only its from a swift 2. I got pretty close to another rock and shoot down it nicely.
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
