Old Jun 23, 2012, 10:07 AM
mjc1970 is offline
Find More Posts by mjc1970
Leicester, UK
Joined Sep 2010
Having fun on the beach with my ZII
Ritewing Zephyr II - FPV Flying around Sandy Hills Beach - Dumfries & Galloway Scotland (3 min 32 sec)
mjc1970 is offline Find More Posts by mjc1970
Old Jun 23, 2012, 10:24 AM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
Originally Posted by flyn View Post
Gents, just wondering if you'd mind helping me position my electronics?
I've been away for over a week & little has happened with my build since my last post - I've cut out & covered my elevons & thats about it.
I'm gonna setup for short/med range FPV for now with a view to possibly getting a UHF system at a future date. I've not cut any holes yet & have roughly set my VTX midway out on the plane's left wing with my GPS unit countering it midway out on the plane's right wing, I've also got an extension cable for the RC satellite RX so I can stick it right out on the left wingtip at a 90 orientation to however I mount my main RX (yeah, I know it's Spektrum & how a lot of people hate it etc etc. but its all I've got at the moment I'm afraid). My Eagletree OSD, logger, Guardian, & RX BEC live in the electronics bay, so there's pretty much no room in there. I'm also running a separate 1000mah 3s VTX lipo thats not pictured, where does everyone else mount their VTX packs if they use one?
My issue is how should I mount my main RC RX so I don't have to cut another hole for a UHF when I eventually splash out for one? Should I switch the positions of my GPS unit & RX, or am I missing something else?
Some advice would be gratefully received. Thanks.
Attachment 4955870
I'm also running full ETOsd check out my build on fpvlab.com
http://fpvlab.com/forums/showthread.php?5733-FM-Z2
freshmint is offline Find More Posts by freshmint
Old Jun 23, 2012, 11:24 AM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by Acorns View Post
Interesting! I didn't realize that was what all of this "outside" mounting talk was about. Looks like all I have to do is unscrew it and swap sides too. If it is enough, it will make my CG issues really easy to deal with. Thanks!
The only difference between inside and outside mounting is the motor shaft that the prop attaches to.
I have the 1200kv Ritewing motor mounted on the inside. The 5mm motor shaft is where I mount my prop.
If I swapped it to the outside I would need to attach the prop adapter that came with my motor. Depending on the hole size in your prop it may or may not fit the shaft diameter of the adapter.
If you have any issues ask for help. There is a lot of good advice and help from people on this thread.
Vince
Eagle202 is offline Find More Posts by Eagle202
Old Jun 23, 2012, 11:57 AM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
Freshmint
I went to your build thread on FPV. Man all I can say is that you did a really great job of showing the build details with your photos. I am really impressed with your organizational skills. As for how you fly!!!
Only kidding. Great job on the build photos and flying.
Old Jun 23, 2012, 02:37 PM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
Guys, one question. I'm thinking of going single 4s 3000/3300mAh battery instead of dual. Looks too me like dual battery setup is leaving batteries unequally discharged resulting in too low voltage in some of the cells.
So, what could be average expected crusing flight time with 1x3000mAh 4S setup?
hefest is offline Find More Posts by hefest
Old Jun 23, 2012, 02:47 PM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
Maybe 10min, I get around 25min flight times with 2x 4000mah's
I use 2x 4000mah 4s in paralell in my ZII and in my trex 700e I run 2 x 5000mah 6s in series and never have any issues with packs unequally discharged in either setup.
hotdog1 is offline Find More Posts by hotdog1
Old Jun 23, 2012, 03:09 PM
ghost2212 is offline
Find More Posts by ghost2212
Skint since 2000
ghost2212's Avatar
Reading, United Kingdom
Joined Oct 2008
Where do you get that impression?
If there in parallel there's no way they can discharge unequally.
ghost2212 is offline Find More Posts by ghost2212
Old Jun 23, 2012, 03:29 PM
superevan is offline
Find More Posts by superevan
superevan's Avatar
United States, TX, Austin
Joined Aug 2007
Flight time aside, that will not be enough weight to balance cg. Unless you plan on 400 or so extra grams of electronics in the nose, aside from a gopro and case, flight can, skids and camera housing.
superevan is offline Find More Posts by superevan
Old Jun 23, 2012, 03:32 PM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
Well they do, all the time. Both pairs are nano-tech, one is set is 2x3000mAh 4S and the other is 2x3300mAh 4S. I already had to replace one of the batteries. When I discharge it to around 3.75V per cell there is always one of the cells that gives up earlier and discharges more.
I'm using these packs in bigger and heaving wing, 1.68cm wingspan 3.2kg Hercules, and getting around 15min of semi-aggressive flying or 20-25min of cruising around but with less efficient twin motor tractor setup.
My guess is I could get around the same flight times with one 4S setup in Zephyr.
One motor pusher with bigger prop and significantly less weight should improve the flight time.
Did anyone try smaller battery packs like 2x3S 2200-2500mAh ?
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
That's something to think about, thanks.
I could push the motor mount a bit forward.
Old Jun 23, 2012, 03:36 PM
Skint since 2000
ghost2212's Avatar
Joined Oct 2008
If the packs arent matched properly that will happen even when there not in parallel.
Old Jun 23, 2012, 03:39 PM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
What do you mean by matched properly?
Its the same battery pack, same capacity, from the same manufacturer with identical look and bought at the same time. How else could one "match it up properly"?
Old Jun 23, 2012, 03:41 PM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
I actually thought about configure it to be able to fly with both battery setups, 1 and 2 batteries, by changing the way motor is mounted (before and after motor mount) and possibly adding some weight to the nose if necessary, but that sounds like less possible to pull out.
PS: Take a look at this post.
Old Jun 23, 2012, 03:44 PM
Skint since 2000
ghost2212's Avatar
Joined Oct 2008
If the cells in the individual packs aren't matched properly then they will still do the same thing even when not in parallel.
superevan's Avatar
Joined Aug 2007
No problem! In fact I have 2 3s 3000mah turnigy with motor inside motor mount and, with no gopro or camera pod still have to add 350g dumb weight to the nose. Needless to say, I got a gopro
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
