Old Jun 17, 2012, 03:05 PM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
just to clarify i used 1 piece of lam for the bottom and 1 for the top, but only heated a small patch at a time. it comes out as straight as an arrow.
i tried the "warp it one way then warp it back" on my IYF and it was a disaster lol - it looked like a bannana
i guess you need to be really good to get that way to work
brosius85 is offline Find More Posts by brosius85
Old Jun 17, 2012, 05:12 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
I do 3 pieces or more always, it makes for a much more true plane.
It keeps schrinkcage and warpage to a minimum and makes it much easier , you cant even see the 6 mm overlaps .
klique is offline Find More Posts by klique
Old Jun 18, 2012, 08:53 AM
ronrob61 is offline
Find More Posts by ronrob61
United States, AZ, Gilbert
Joined Nov 2011
3 pieces is the way to go. one for each wing and one down the center. Lamming the top of the wing first, then the bottom. comes out perfectly str8 and tru every time. for some reason same lamming process but doing the bottom first leaves a slight curve to the final product
ronrob61 is offline Find More Posts by ronrob61
Old Jun 18, 2012, 09:02 AM
ronrob61 is offline
Joined Nov 2011
Originally Posted by Eagle202 View Post
I had a similar problem. This was the first laminating job I have done. I thought my Hanger 9 iron has temperature settings on the dial. It only had the numbers 1 to 5.
Not having the experience with laminating as well as not having a way to properly set my temperature made it a little difficult to get an even smooth surface. I could tell when it was too hot but until it cooled and wrinkled I couldn't tell when it was not hot enough so I just went back over those areas again.
For future lamination jobs I plan to get a temperature gun and to practice practice practice.
on the Hanger 9 iron with dial 1 - 5. set it to 3. start there and if not quite hot enough go to 3.5. Ive burned up 3 of the hanger 9 irons cause I use them alot but the temp settings on them seems to be pretty consistant. so far 3 - 3.5 has worked perfect on 4 of the Irons of gone thru.
Old Jun 18, 2012, 10:01 AM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
That helps. Thanks for the info.
Eagle202 is offline Find More Posts by Eagle202
Old Jun 18, 2012, 10:49 AM
RemiWM is offline
Find More Posts by RemiWM
Norway
Joined Feb 2012
My latest film with my Z2:
Z2 FPV June Compilation - GoPro Breaks (4 min 17 sec)
RemiWM is offline Find More Posts by RemiWM
Old Jun 18, 2012, 11:57 AM
Techmeister is offline
Find More Posts by Techmeister
United States, NY, New York
Joined May 2012
HI, if i am going to apply a carbon fiber vinyl to the plane, do i need to lam it first?
Techmeister is offline Find More Posts by Techmeister
Old Jun 18, 2012, 03:10 PM
wootenelli is offline
Find More Posts by wootenelli
Michael W.
wootenelli's Avatar
United States, TN, Cleveland
Joined Nov 2011
I'd say no...the purpose of the lam is to protect the foam and to provide strength for the wing...the 3m carbon vinyl would do both of those, and do them well from what everyone is saying on here. I would probably ask some of the guys if they are using 3m spray to adhere the vinyl first, but no, don't lam it first....
wootenelli is offline Find More Posts by wootenelli
Old Jun 18, 2012, 05:41 PM
Joined May 2012
Thanks, just what i wanted to hear
To "some of the guys" do you think i should use 3m spray (77) on the wing then use the ALREADY ADHESIVE backing on the vinyl or not use the 3m spray.
Old Jun 18, 2012, 06:07 PM
klique is offline
Mum is the word!
Joined Jun 2003
Hi ,have you read the pdf directions?
I would do the same as you would for lam .
Old Jun 18, 2012, 06:53 PM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
YES! Spray the 77 first. The vinyl has a sticky back but not enough to hold, and over a short space of time with the wing flexing, it will let go.
I have started and once you spray the 77 and then lay the vinyl, it sticks really well.
No - I didn't lam it either.
The_Mongrel is offline Find More Posts by The_Mongrel
Old Jun 19, 2012, 01:46 AM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
i think the lam is a good idea under the carbon vinyl. it is a big strength component
depends how you fly really :/
Old Jun 19, 2012, 01:53 AM
Joined Dec 2007
Yeah man. If you are going to be pulling some serious Gs, then it might be worth it. But if you are going to be doing general purpose FPV, then not really needed I reckon.
Heck - I have a wing that has a few strategically placed strips of packaging tape and that's all! And it flies OK - when I am not bouncing it!! LOL!!
Old Jun 19, 2012, 12:22 PM
ronrob61 is offline
Joined Nov 2011
I agree, the carbon fiber isnt gonna give you the nice stiffness that you get from the lam. Im about to start a new custom build. The customers wants the carbon fiber look. Im going to lam the entire wing as I usually would but then place enough carbon fiber over it to give it the rt look. Ill post some pics as the build begins.
Old Jun 19, 2012, 12:53 PM
Michael W.
wootenelli's Avatar
Joined Nov 2011
do you think that because of the new foam on the z2 that it is not as big of a factor in stiffness?? I bow to you on this one considering i never fly over 60kph....
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
