Old Jun 09, 2012, 12:04 PM
MrBen. is offline
Find More Posts by MrBen.
Great Britain
MrBen.'s Avatar
Joined Dec 2008
Originally Posted by dr_patso View Post
just bought a usb programmer... damn it.
yep the hacker x70 is a pain to get into prog mode, I too had to get a programmer.
MrBen. is offline Find More Posts by MrBen.
Old Jun 09, 2012, 12:12 PM
RUBNorris is offline
Find More Posts by RUBNorris
New Beeeeee
RUBNorris's Avatar
United States, CA, Sacramento
Joined Apr 2011
Originally Posted by wrath90210 View Post
Could anyone hint as if these servos are any good for the zeph? Not because they are cheap but because I have them lying around. They are 3.6kg or 126.9oz right? I believe the minimum servos are 70oz, I just don't want to cheap on servos if I loose a plane. Thanks guys!
Cheers!
Try it, might work good. I got HK $6 monster servos that I think can lift a truck. They don't move that much for the ZII's throws.
RUBNorris is offline Find More Posts by RUBNorris
Old Jun 09, 2012, 12:17 PM
wrath90210 is offline
Find More Posts by wrath90210
wrath90210's Avatar
Joined May 2009
Thanks mate! I just want to make sure if I put this thing in a dive I can pull out quickly.
wrath90210 is offline Find More Posts by wrath90210
Old Jun 09, 2012, 05:43 PM
flyn is offline
Find More Posts by flyn
flyn's Avatar
United Kingdom, England, Cambs
Joined Jun 2009
I'm halfway through my build, it's getting there:
Description:
Please excuse the mess of a work area!
flyn is offline Find More Posts by flyn
Old Jun 09, 2012, 06:16 PM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
Cheers!
I could't find any Hitech locally at a decent price, so I went with these. They are not here yet, but I am hoping they will do the job.
http://www.hobbyking.com/hobbyking/s...idProduct=6335
The_Mongrel is offline Find More Posts by The_Mongrel
Old Jun 09, 2012, 06:22 PM
Haych is online now
Find More Posts by Haych
Australia, WA, Mandurah
Joined Mar 2010
thats what I use as well, zero issues with the servos, my only issue is the foam, it gets damaged when I crash...
Haych is online now Find More Posts by Haych
Old Jun 09, 2012, 06:26 PM
Joined Dec 2007
ahahah! Nice. I hope I don't have that problem.
Old Jun 09, 2012, 07:02 PM
ghost2212 is offline
Find More Posts by ghost2212
Skint since 2000
ghost2212's Avatar
Reading, United Kingdom
Joined Oct 2008
What servos are people using apart from the ones talked about above?
Brett
ghost2212 is offline Find More Posts by ghost2212
Old Jun 09, 2012, 07:29 PM
tobermei is offline
Find More Posts by tobermei
Mt Tamborine, Queensland, Australia
Joined May 2008
I'm in the process of building my Z2, using Hi-tech HS-645MG servos
tobermei is offline Find More Posts by tobermei
Old Jun 09, 2012, 07:32 PM
Assaf110 is offline
Find More Posts by Assaf110
Joined Jun 2011
+1 (actually 2...)
Assaf110 is offline Find More Posts by Assaf110
Old Jun 09, 2012, 07:53 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by BCSaltchucker View Post
I wondered the exact same thing! Yeah, they seem to be the same stuff. And more awesome for model building than shoe-repair. But I do not know if they are the same chemical.
I glued the tumor onto my wing last night with Goop. And I just glued a wide angle lens on my #16 cam with Goop (tacked with hotglue) 20 minutes ago (trying to make it a GoPro killer)
The Goop they sell in the States is used by plumbers since it works great on PVC pipes. It contains toluene and petroleum distillate. It is very flammable and the vapor will make you sick so make sure you have some ventilation.
When you use that Goop, DO NOT let it touch the ZII foam directly. It will eat a hole in it. It works fine as long as you have used the laminate to cover the foam first but if it contacts the foam directly it will melt the foam.
Eagle202 is offline Find More Posts by Eagle202
Old Jun 09, 2012, 08:09 PM
BCSaltchucker is online now
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
have used it directly on the foam. No eating, no holes. But there are several different varieties of Goop. I am wondering why a 6 foot tall dung beetle wearing LA Raiders jersey was trying to convince my that the ZII has inferior lift to a Clark Y airfoil. Must need more ventilation!
BCSaltchucker is online now Find More Posts by BCSaltchucker
Old Jun 09, 2012, 09:00 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
LOL. Nice come back.
I guess there are different types of goop out there. The stuff I use had that toluene and petroleum distillates as the main components. What is in your goop?
Old Jun 09, 2012, 09:50 PM
paintz is offline
Find More Posts by paintz
Joined May 2012
haha!
some corn, peanuts.....
paintz is offline Find More Posts by paintz
Reply With Quote  (Disabled)
Old Jun 09, 2012, 11:06 PM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
Brett
Im using these from HK http://www.hobbyking.com/hobbyking/s...dProduct=17794 . I also have them in my 5lbs Sbach with full throws and work way better then my hi tech (twitchy). ZII needs less throws (1/4")
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
