Old Jun 06, 2012, 01:30 AM
Haych is offline
Find More Posts by Haych
Australia, WA, Mandurah
Joined Mar 2010
Originally Posted by dr_patso View Post
no BEC..
this is your best options for creating 12V supply with 4s setup.
1. tbs core (80$ but nice and small)
2. 3s battery
3. I use dpcav 1-35V regulator,, (mine came stock at 12V setting, best check it with a voltmeter
http://www.dpcav.com/xcart/Adjustabl...EPIC-Type.html with a filter between it and the things it is powering
http://www.dpcav.com/xcart/Power-Sup...-L-C-Type.html
i've done lots of flights with it and it is reliable and does not reduce rang with uhf, 1.3ghz and gps... the really small 12V step downs have failed on me, don't use them.
yep, I use 4S on the ZII and also use an adjustable step down regulator which powers the 12V video transmitter and 12V camera, but I set it to 10V and I don't use additional filters. My picture is sharp with no interference from the motor. I also use it to provide 10V to my DOSD which I can monitor its voltage for the video system even though it all coming from the one battery.
http://youtu.be/CwvA3cm3z_s
Haych is offline Find More Posts by Haych
Old Jun 06, 2012, 07:53 AM
RUBNorris is offline
Find More Posts by RUBNorris
New Beeeeee
RUBNorris's Avatar
United States, CA, Sacramento
Joined Apr 2011
here is mine all done and maiden (fast post headed out the door)
Miaden the Rightwing ZII (6-3-2012) (7 min 13 sec)
RUBNorris is offline Find More Posts by RUBNorris
Old Jun 06, 2012, 10:28 AM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
http://www.youtube.com/watch?v=r8tRi...ature=youtu.be
Nice throw!
freshmint is offline Find More Posts by freshmint
Old Jun 06, 2012, 10:32 AM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
I see guys putting the motor in front on some and behind the mount on others. is that a cg thing? if not, whats the difference?
Kloner is offline Find More Posts by Kloner
Old Jun 06, 2012, 10:52 AM
dr_patso is online now
Find More Posts by dr_patso
N00b
Boise
Joined Mar 2009
mainly a cg thing, when it is behind the mount it is a little bit quieter.. slightly more sturdy in front of the mount but louder.
dr_patso is online now Find More Posts by dr_patso
Old Jun 06, 2012, 12:29 PM
tobermei is offline
Find More Posts by tobermei
Mt Tamborine, Queensland, Australia
Joined May 2008
Nice maiden. What size prop did you use? It is a ritewing motor you fitted?
Good to see another jeep at the flying field!
tobermei is offline Find More Posts by tobermei
Old Jun 06, 2012, 01:10 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Nice job with your maiden. I like to see someone take their time with a pre-flight check of all the surfaces & motor before launching.
I had an issue once with my Skysurfer where I didn't pre-check and later found that the rudder servo switch had been moved which reversed it's action. I got it down but I won't forget a to check again.
Eagle202 is offline Find More Posts by Eagle202
Old Jun 06, 2012, 04:05 PM
Techmeister is offline
Find More Posts by Techmeister
United States, NY, New York
Joined May 2012
no BEC..
2. 3s battery
Thanks everyone, i think i will go with option three!
Techmeister is offline Find More Posts by Techmeister
Old Jun 06, 2012, 04:17 PM
N00b
Boise
Joined Mar 2009
good call, one less battery to charge or worry about.
you should get the filter just in case, but don't install it unless your video is grainy, or video changes when you throttle etc.
Old Jun 06, 2012, 06:33 PM
faheja is offline
Find More Posts by faheja
faheja's Avatar
United States, CA, Laguna Hills
Joined Sep 2011
Hey all,
Just wanted to share a few pictures of my zephyr with all my TBS gear finally installed!
I think it came out awesome. I added everything from the bottom up.
The quality of the TBS69 camera actually was quite shocking. I never realized how crappy my other camera was lol. Hope to fly it again this weekend. So far i did a range test at a little over a mile and the video was solid.
The TBS core was actually really simple to use and made the wiring really clean.
I made the gopro box from scratch though and added the top. The bottom is all vinyl, and with everything installed right now it comes in at 4.5lb. I will add bigger batteries later when i need more flight time.
Just wanted to say thank you to Trappy for the best support I've ever had with ANY company.
All the pictures were taken by my fiance` Kayli.
Videos to come!
faheja is offline Find More Posts by faheja
Old Jun 06, 2012, 07:08 PM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
That is SWEEEEEEET!!
Pretty much the same colour scheme I am running with too!! Nice job mate!
The_Mongrel is offline Find More Posts by The_Mongrel
Old Jun 06, 2012, 07:32 PM
tobermei is offline
Joined May 2008
Looks really nice!
I'm getting close to attaching the winglets. Manual says to use "Goop". Not sure what that is down under, anyone recommend a different glue?
Old Jun 06, 2012, 07:49 PM
Joined Dec 2007
Yep. I used a similar glue from Bunnings. Hang on and I will find it's name for you.
Old Jun 06, 2012, 07:58 PM
Joined Dec 2007
Here ya go.
I used this stuff - works like Gorilla Glue.
Sikabond - TechGrip - Get it at Bunnings!
Old Jun 06, 2012, 07:59 PM
tobermei is offline
Joined May 2008
thanks
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
