Old Jun 03, 2012, 03:37 PM
Techmeister is offline
Find More Posts by Techmeister
United States, NY, New York
Joined May 2012
Originally Posted by hotdog1 View Post
6kg is like 200 oz's right ? the servos Im using are around 70oz torque at 4.8v
6 kg/cm = around 83 oz/in
Techmeister is offline Find More Posts by Techmeister
Old Jun 03, 2012, 03:59 PM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
Oh ok , That should be fine
hotdog1 is offline Find More Posts by hotdog1
Old Jun 03, 2012, 04:17 PM
Joined May 2012
Thanks you have been very helpful, i really thank you guys for all your help i would be lost without it.
Old Jun 03, 2012, 04:50 PM
hotdog1 is offline
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
no problem I try to help when I can! I have been building my fpv setup for almost a year now and everyday I am on the here and another fourm learning all I can
Old Jun 03, 2012, 06:33 PM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
I ran into a little problem with COG. If I use the 3300mah I need to add about 120g in lead weight to balance it out. But with 4000mah it balance good. The Z2 is so heavy? 3071g with the 8000mah.
freshmint is offline Find More Posts by freshmint
Old Jun 03, 2012, 08:00 PM
Acorns is offline
Find More Posts by Acorns
United States, IA, Mason City
Joined Oct 2008
Thanks for that pic! can you tell me how far the hook is from the back opening ?
7.25in from the opening, but that might not be the most accurate way to measure as the mount was cut back a little from stock. The hook itself is 3.75in in front of the CoG.
Acorns is offline Find More Posts by Acorns
Old Jun 03, 2012, 08:05 PM
RUBNorris is offline
Find More Posts by RUBNorris
New Beeeeee
RUBNorris's Avatar
United States, CA, Sacramento
Joined Apr 2011
Just maiden my ZII today, video will be a while. Fly nice, super fast! CG is set. 3000mah with lead for weight. Did a watt test on the ritewing 35-36 1400kv w/10x5 aPc prop. I was getting 67A and 1000+ watts.... Is that too high or prop down?
After flight the 110A ESC was hot!!
RUBNorris is offline Find More Posts by RUBNorris
Old Jun 03, 2012, 08:31 PM
Acorns is offline
Joined Oct 2008
On 4S I assume. I get 40A with with same motor on 10x6 with 3S. Sounds about right, though the 110A ESC should not be hot after a normal run... my 60A one comes back cool.
Old Jun 03, 2012, 08:36 PM
Joined Nov 2011
are you using a separate bec? if you dont and your esc fail you will have no control.
esc shouldn't be getting hot.. whats the setting?
Old Jun 03, 2012, 09:16 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
I dont sell a 1400 kv , do you mean 1200 kv ?
klique is offline Find More Posts by klique
Old Jun 03, 2012, 09:41 PM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
oh yeah, 1200kv. oops.
Old Jun 03, 2012, 09:42 PM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
Hey lads,
I have an order about to leave HC - Anyone know if these are any good for the Z2?
http://www.hobbyking.com/hobbyking/s...2kg_14sec.html
I can't get the Hitechs locally without paying near on $60 each.
The_Mongrel is offline Find More Posts by The_Mongrel
Old Jun 03, 2012, 09:54 PM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
2x 3000mah 4s (im cheap) with lead for weight.
110A ESC w/ stand alone BEC (is now on the outside)
10x5 apc prop
HK15288A Analog BB/MG (TUFF)
Old Jun 03, 2012, 10:04 PM
Joined Nov 2011
nice paint
Old Jun 03, 2012, 10:09 PM
chicken sashimi is offline
Find More Posts by chicken sashimi
WOT happened?
chicken sashimi's Avatar
Canada, BC, Vancouver
Joined Sep 2011
My zephyrII finished at last. Maiden this weekend.. can't wait!
chicken sashimi is offline Find More Posts by chicken sashimi
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
