Old May 15, 2012, 10:01 AM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Hey everyone this is my video of all my experience flying my zephyr so far. please thumbs up if you like it thanks.
My Ritewing Zephyr 2 Experience So Far! Flown with Dragon link. (6 min 26 sec)
flohio117 is offline Find More Posts by flohio117
Old May 15, 2012, 02:45 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by flohio117 View Post
Hey everyone this is my video of all my experience flying my zephyr so far. please thumbs up if you like it thanks. http://youtu.be/9-ttkwEA87s
Very nice flying. I am envious of your flying area. Nice big open and relatively flat.
That is a very big satellite dish nearby. Do you get any interference flying in front of it?
Eagle202 is offline Find More Posts by Eagle202
Old May 15, 2012, 03:13 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
Omm no I havnt gotten any interference. This area isn't normally where I fly it's just a good middle point for meeting up with my friends. Today I'm going to try my 1st FPV flight with my zephyr using Dragonlink also it will be my 1st flight using my 8dbi patch antenna and my new 1W vid tx and v antenna. I hope it goes well
Old May 15, 2012, 04:06 PM
oesti is offline
Find More Posts by oesti
Joined Jun 2011
Just finished my second ZII build. This time I used hot-glue for everything (used epoxy for the motor mount). I did a test with hot-glue (low temp) first and was not able to pry apart the foam pieces, so it seems to be up to the job. The nice thing is that when ironing on the laminate, the hot glue melts again and the seams become very smooth. Fought Gorilla glue mess on my first ZII. This one looks much cleaner.
Also built a plywood battery compartment inspired by TBS. Fits 2 4000mAh 3S Nanotech batteries side by side. The CG seems to be just about right once I add the GoPro.
Description: My second ZII build. This time I used hotglue for everything (used epoxy for the motor mount). Also a plywood battery compartment inspired by TBS.
Description: Plywood battery compartment inspired by TBS. Fits 2 4000mAh 3S Nanotech batteries side by side. The CG seems to be just about right.
My first ZII is still going strong, this will by my exhibition model until the first one bites the dust
oesti is offline Find More Posts by oesti
Old May 15, 2012, 05:48 PM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
looks nice
hotdog1 is offline Find More Posts by hotdog1
Old May 15, 2012, 10:13 PM
fpv-tor is offline
Find More Posts by fpv-tor
fpv-tor's Avatar
norway
Joined Oct 2009
Looking good nice throw.
Cant wait to maiden mine
fpv-tor is offline Find More Posts by fpv-tor
Old May 15, 2012, 10:15 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
Attachment 4864522
Attachment 4864523
Nice home made battery box. Looks similar to mine except for the opening between the bat bay and instrument bay.
Old May 15, 2012, 10:46 PM
paintz2007 is offline
Find More Posts by paintz2007
Guess Who's Back? :D
paintz2007's Avatar
Joined Sep 2006
haha the spotter in the beginning whoah whoah slow down...
and don't we all feel like that.. "I did it, it flies!"
paintz2007 is offline Find More Posts by paintz2007
Old May 16, 2012, 01:34 AM
dr_patso is offline
Find More Posts by dr_patso
N00b
Boise
Joined Mar 2009
Hoping someone here can help,
I am trying to to mount my hacker a30-10lv2 outboard this time around. I have ordered the backmount and have it setup, it appears the threads on the backmount are of smaller diameter than my graupner yoke etc...
From what I've read all the graupner spinners are 8mm in the middle of the yoke and i beleive the stock backmount for an a30-10L is 6mm.. Before you think I was lazy, I read on fpvlabs that you can use apc-e adapters, even stack a couple to make this work.. I just went through an 8x6, 8x3.8 and 11xsomething apc-e and there's only one that fits around the backmount adapter's shaft but then it is too big for my graupner yoke.. bleh so frustrating.
dr_patso is offline Find More Posts by dr_patso
Old May 16, 2012, 02:08 AM
dr_patso is offline
N00b
Boise
Joined Mar 2009
sorry to spam,
I couldn't use something like this right? http://www.gobrushless.com/shop/inde...ROP-ADAPTER6mm
because it would be clamping onto the threaded part of the backmount adapter's shaft and not go on straight.
i think this would work
http://www.hobby-lobby.com/1_4_prop_...r_756_prd1.htm
but it's not in stock =(.. should I go to my LHS and get a certain size APC-E prop that will have a bushing/adapter that i can use?
Old May 16, 2012, 04:17 AM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
Originally Posted by dr_patso View Post
sorry to spam,
I have something similar to the hobbylobby but in cf pm me your address and I will send you it for free
freshmint is offline Find More Posts by freshmint
Old May 16, 2012, 06:24 AM
mjc1970 is offline
Find More Posts by mjc1970
Leicester, UK
Joined Sep 2010
I'm currently building a Z2 (see pictures attached) and read more from my build log on my Blog: http://mjc70.blogspot.co.uk/
A friend has also built a Z2 recently and this is a video I took from our second outing with it. Watch out for more to follow soon!
Ritewing Zephyr 2 ZII - Sunset Flight - GoPro Hero2 and LOS footage - Leicestershire UK (5 min 6 sec)
mjc1970 is offline Find More Posts by mjc1970
Old May 16, 2012, 07:44 AM
Blue Chip is offline
Find More Posts by Blue Chip
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
Nice - what kind of wrap did you use?
Blue Chip is offline Find More Posts by Blue Chip
Old May 16, 2012, 08:06 AM
fpv-tor is offline
fpv-tor's Avatar
norway
Joined Oct 2009
http://www.youtube.com/watch?v=zyW44C61cHw
nice build. im allso using the carbon fibre vinyl for my wing. very easy to apply
Old May 16, 2012, 08:46 AM
carlocivicsi is offline
Find More Posts by carlocivicsi
United States, FL, Miami
Joined Mar 2012
cloud surfing with rite wing zII. hope you LIKE IT.
Ritewing Zephyr ZII flies through the clouds 4000 FT FPV (4 min 38 sec)
carlocivicsi is offline Find More Posts by carlocivicsi
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
