Old May 07, 2012, 10:56 AM
superevan is offline
Find More Posts by superevan
superevan's Avatar
United States, TX, Austin
Joined Aug 2007
Originally Posted by flohio117 View Post
Hey guys I have a 1000mw 1.3 vid rx that I want to install on my z2. Where should I put it? Should I cut a spot for it in the wing and then put LAN over it? Or should I just cut a spot in the wing and put it in it with no lam? Or should I just Velcro and tapse it to the top of the wing? Also if anyone has a hitec aurora9 that they have installed the dragon link on let me know bc I'm trying to install mine but I don't want it mess it up.
Just make sure it has sufficient airflow, especially a 1W tx. I've cut a slot out for mine and plan in laminating over it (or at least packing tape), but I will have a heat sink out in the air flow. The tx will bake in the foam with no ventilation.
superevan is offline Find More Posts by superevan
Old May 07, 2012, 10:59 AM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
I'm probably going to just Velcro it on the outside so it will get the best flow I guess
flohio117 is offline Find More Posts by flohio117
Old May 07, 2012, 11:09 AM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
this is what alot of people do sink it into the wing but leave the top exposed for cooling
hotdog1 is offline Find More Posts by hotdog1
Old May 07, 2012, 11:23 AM
RemiWM is offline
Find More Posts by RemiWM
Norway
Joined Feb 2012
Here's my latest Z2 video. Enjoy!
AWESOME Z2 Speed Flight-Trees and Diggers-Flown With Dragonlink.mpeg (3 min 52 sec)
RemiWM is offline Find More Posts by RemiWM
Old May 07, 2012, 01:42 PM
dr_patso is offline
Find More Posts by dr_patso
N00b
Boise
Joined Mar 2009
So I ordered this for a hacker a30
http://www.gravesrc.com/HACKER_A30_B...M_p/haca30.htm
think this is the ticket for mounting the prop on the back?
dr_patso is offline Find More Posts by dr_patso
Old May 07, 2012, 01:46 PM
FlyHighSelllow is offline
Find More Posts by FlyHighSelllow
Champagne Supernova
FlyHighSelllow's Avatar
United States, FL, Orlando
Joined Jul 2010
Originally Posted by Eagle202 View Post
I think $70 is way too much for some pvc pipe, bungy cord and hardware though
Vince
It is. Especially when you have to make modifications to make it work............
FlyHighSelllow is offline Find More Posts by FlyHighSelllow
Old May 07, 2012, 01:49 PM
Champagne Supernova
Joined Jul 2010
Originally Posted by elchoclo View Post
I modified a little bit the jetapult so it's angled a little bit higher, I used longer pvc tubes (the grey ones in the pictures) to increase the angle
Me ttoo and had to buy longer surgical tubing
Old May 07, 2012, 03:10 PM
hotdog1 is offline
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
how long is your tubing and how much tension are you using to launch your zeph
Old May 07, 2012, 07:26 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
I am actually building a launcher. It is a copy of LostLarry's who was kind enough to loan it to me.
Larry uses a 10ft surgical tube he got at Home Depot. I will probably go with a double tube to increase the tension and shorten the stretch distance. I have heard the proper tension is 4 to 5 times the weight of the plane so with my 4.5 lb ZII I will be going with 20 to 25 lb.
Eagle202 is offline Find More Posts by Eagle202
Old May 07, 2012, 07:46 PM
Locko is offline
Find More Posts by Locko
Locko's Avatar
Australia, WA
Joined Oct 2011
Yep looks like the one
Locko is offline Find More Posts by Locko
Old May 07, 2012, 09:36 PM
carlocivicsi is offline
Find More Posts by carlocivicsi
United States, FL, Miami
Joined Mar 2012
My new zII made by rockyflyr check him out on YouTube.
Check this out.
Ritewing ZII Maiden FPV (4 min 54 sec)
carlocivicsi is offline Find More Posts by carlocivicsi
Old May 08, 2012, 12:13 AM
dr_patso is offline
N00b
Boise
Joined Mar 2009
thanks for confirming! a new more durable zeph to come for me!
Old May 08, 2012, 04:01 AM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
Check this out. http://www.youtube.com/watch?v=uaxX9E7Bb1M
Wow awesome look like rocky videos did he edit it?you should hide your gps location just in case
freshmint is offline Find More Posts by freshmint
Old May 08, 2012, 06:34 AM
Blue Chip is offline
Find More Posts by Blue Chip
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
Anyone using vinyl wrap on their plane? If so - is it all the 3M DI-NOC or has anyone used any other kinds?
I am thinking about a 3D CF vinyl wrap - but wondering what the difference is between the 3M DI-NOC and some of the alternatives that are half the price.
Blue Chip is offline Find More Posts by Blue Chip
Old May 08, 2012, 08:19 AM
matthew.wright is offline
Find More Posts by matthew.wright
Australia, ACT, Hume
Joined Jan 2010
There is a reason why its more expensive... I will be buying some, it appears to have great molding ability and easy to work with, which will be essential when your bending it into wierd angles and sharp edges.
Samples appear very strong as well.
matthew.wright is offline Find More Posts by matthew.wright
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
