Old May 04, 2012, 03:44 PM
paintz2007 is offline
Find More Posts by paintz2007
Guess Who's Back? :D
paintz2007's Avatar
Joined Sep 2006
it doesn't need to be a pusher prop. electric motors can run backwards
.. on that subject though I think I'm gonna open an e pusher prop shop and make a killing
paintz2007 is offline Find More Posts by paintz2007
Old May 04, 2012, 04:23 PM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
Originally Posted by seibernator View Post
Could someone also recommend a good pusher folding prop supplier here in the UK?
Thanks.
all you have to do is put a regular prop on with the side with the writing facing the front of the zephyr. and if you motor is turning the wrong way switch any two esc wires.
hotdog1 is offline Find More Posts by hotdog1
Old May 04, 2012, 04:41 PM
seibernator is offline
Find More Posts by seibernator
***** on a stick
seibernator's Avatar
United Kingdom, England, Solihull
Joined Sep 2011
Yeah, thanks for the suggestions guys. I already have various other pusher style planes so am aware that regular type props can be used in reverse.
I was asking about pusher folding props. I am not sure that regular folding props can be used in reverse as the hinges are not designed to fold in the other direction.
Any other suggestions?
Cheers
seibernator is offline Find More Posts by seibernator
Old May 04, 2012, 05:51 PM
paintz2007's Avatar
Joined Sep 2006
I know i went through 2 folders on my first couple flights, switched to a apc standard and instead of breaking the prop i just unscrewed it from the motor
as for the folder, i used the big wheel servo horn out of my hs645 pack to make a prop stop. on a graupner cam it was perfect for my yoke i have idk the size though
Old May 04, 2012, 07:04 PM
***** on a stick
Joined Sep 2011
Ok, thanks.
Chris mentions in his manual that the approved list of adhesives includes 3M 77 and Lock Tight 200. Which would you recommend using to stick the laminate to the wing? Is one better than the other? I guess it will all come down to availability.
Old May 04, 2012, 07:09 PM
alistair2 is offline
Find More Posts by alistair2
Joined Dec 2010
Zephyr II FPV (3 min 10 sec)
Never FPVed anything with ailerons before, let alone a flying wing - the ZII makes it look easy! First couple of FPV flights, enjoy
alistair2 is offline Find More Posts by alistair2
Old May 04, 2012, 08:30 PM
Macattaka is offline
Find More Posts by Macattaka
Beyond the BlackStump
Macattaka's Avatar
Australia, SA, Adelaide
Joined Mar 2006
Nice work, lovely scenery.
Macattaka is offline Find More Posts by Macattaka
Old May 05, 2012, 12:30 AM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Ok I got my dragon link in now I need to connect it up and finish building my zephyr then I'll be doing some long distance FPV!!!! I cant wait
flohio117 is offline Find More Posts by flohio117
Old May 05, 2012, 03:01 AM
drumbum961 is offline
Find More Posts by drumbum961
Joined Dec 2010
Originally Posted by alistair2 View Post
http://vimeo.com/41585801
Saweeeet footage dude! Wish I had a place that scenic to fly round here!
Keith Frikkin' Morris
drumbum961 is offline Find More Posts by drumbum961
Old May 05, 2012, 06:36 AM
khaled_abobakr is offline
Find More Posts by khaled_abobakr
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
Congratulations Alistair2
Could you please tell me about your power setup on your ZII ... Also what VRX antenna do you use ... omni, directional , or Antenna tracker ???
Thanks a lot
keep them coming
Khaled
khaled_abobakr is offline Find More Posts by khaled_abobakr
Old May 05, 2012, 08:08 AM
Macattaka's Avatar
Joined Mar 2006
Cheers
Not sure there is such a beast as a pusher folder. Just use a normal folder, discard the spinner, reverse the blades and make a plate to stop the blades folding back past centre, I used FR4.
Name: Folding pusher.jpg
Description:
Old May 05, 2012, 10:38 AM
***** on a stick
Joined Sep 2011
Nice one, thanks for the advice!
Old May 05, 2012, 12:11 PM
sa-woody is offline
Find More Posts by sa-woody
X - USAF X - FAA
Santa Ana, CA
Joined Dec 2004
Can Tesa spray glue be purchased over the internet?
Purchase in North America - I should have noted that when I posted.
sa-woody is offline Find More Posts by sa-woody
Old May 05, 2012, 12:45 PM
MrBen. is offline
Find More Posts by MrBen.
Great Britain
MrBen.'s Avatar
Joined Dec 2008
yes i just got a tin via amazon uk, delivered this morning infact!
MrBen. is offline Find More Posts by MrBen.
Old May 05, 2012, 10:13 PM
hotdog1 is offline
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
Well I just screwed up and put the lam on backwards now I dont have enough to do the top
but the bottom came out ok after my little goof
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 06:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 09:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 05:37 PM
