Old May 02, 2012, 12:05 PM
MrBen. is offline
Find More Posts by MrBen.
Great Britain
MrBen.'s Avatar
Joined Dec 2008
Originally Posted by Ian Davidson View Post
Many thanks (although I see that's still a US link). Is spackle flexible too then; would it not simply crack when the wing flexes?
I used this one on mine, works well
http://www.decoratingwarehouse.co.uk...deep-gaps-/178
I think all the lightweight fillers are pretty simular, same product but with different labels!
You can add a few drops of water or even pva glue to make it easier to spread!
MrBen. is offline Find More Posts by MrBen.
Old May 02, 2012, 12:50 PM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
Cool - thanks MrBen!
Ian Davidson is offline Find More Posts by Ian Davidson
Old May 02, 2012, 10:22 PM
paintz2007 is offline
Find More Posts by paintz2007
Guess Who's Back? :D
paintz2007's Avatar
Joined Sep 2006
from todays flight, i have a new osd induced video issue so no videi yet
paintz2007 is offline Find More Posts by paintz2007
Old May 03, 2012, 04:39 AM
Locko is offline
Find More Posts by Locko
Locko's Avatar
Australia, WA
Joined Oct 2011
People with Z2/ motor/esc experience, Could you see a problem if I ran this setup in my Z2:
Eflite 32 motor with 11*7
Chris ESC 60 (red one)
2 4s 3300 batterys
Cheers if you can help :-)
Locko is offline Find More Posts by Locko
Old May 03, 2012, 07:14 AM
Ho-Jazz is offline
Find More Posts by Ho-Jazz
Taking care of business
Ho-Jazz's Avatar
United States, GA, Buford
Joined Nov 2009
Too low kv on that eflite 32. On 4s you need around 1200+ kv.
Ho-Jazz is offline Find More Posts by Ho-Jazz
Old May 03, 2012, 07:19 AM
Locko is offline
Locko's Avatar
Australia, WA
Joined Oct 2011
It is pretty low KV ( 770) , I still managed to hand launch and get 110kmh.
But will it cause problems , like the esc to catch on fire?. Which did happen., and I did have a separate ubec
Old May 03, 2012, 03:54 PM
Kahuna717 is offline
Find More Posts by Kahuna717
FPV-ophile
Kahuna717's Avatar
United States, TN, Greeneville
Joined Oct 2010
Latest FPV flight with my original Zephyr:
FPV-Back In The Groove (4 min 22 sec)
Kahuna717 is offline Find More Posts by Kahuna717
Old May 03, 2012, 04:24 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
http://www.youtube.com/watch?v=mzy-d...1&feature=plcp
Very nice flying. You should put a blade on the leading edge of that thing since you were low enough to cut the grass.
Eagle202 is offline Find More Posts by Eagle202
Old May 03, 2012, 04:27 PM
FPV-ophile
Kahuna717's Avatar
Joined Oct 2010
Thanks and yeah i definitely should, although knowing my luck i would end up hitting somebody or myself haha!!
Old May 03, 2012, 05:04 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
Yeah. That would be a badddd idea. You wouldn't be able to launch it without cutting yourself on those blades.
Old May 04, 2012, 01:24 AM
dr_patso is offline
Find More Posts by dr_patso
N00b
Boise
Joined Mar 2009
nice!! holy crap, you really were just driving through the grass, think that might be the first time i've seen a bug splat on a gopro lens.
dr_patso is offline Find More Posts by dr_patso
Old May 04, 2012, 08:19 AM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
hey guys the manual says to use spray paint with flat or neon colors because of the solvents but what about water based acrilic paint like from michaels ? will the lam/3m77 not stick as well to the water based paint as well as the spray paint ?
hotdog1 is offline Find More Posts by hotdog1
Old May 04, 2012, 10:28 AM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Those paints will work great , just do a lite coat at first to test.
77 will be fine.
klique is offline Find More Posts by klique
Old May 04, 2012, 10:43 AM
hotdog1 is offline
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
77 will be fine.
cool thanks
BTW this is my first Ritewing product and i am very impressed the build is going great and easy I was on the fence before you came out with the zII it looked like alot of work and i didn;t have that much time to devote to building . but i am already thinking about ordering another one
Old May 04, 2012, 01:04 PM
seibernator is offline
Find More Posts by seibernator
***** on a stick
seibernator's Avatar
United Kingdom, England, Solihull
Joined Sep 2011
Gents
I have just ordered a ZII myself so I am looking forward to the build. I am scratching through the garage trying to find spare parts and have found a Turnigy SK3536 1400kv motor with a 40amp Hobbywing Pentium ESC. Would this motor/ESC combination be good for the ZII?? Am planning to use a 9x6 prop with it.
Could someone also recommend a good pusher folding prop supplier here in the UK?
Thanks.
seibernator is offline Find More Posts by seibernator
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
