Old Apr 28, 2012, 11:26 PM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
Originally Posted by p-plater View Post
Have you broken any fixed props on landing?
Nope, but you must have the brake feature enabled on your ESC. This will ensure the prop pretty much always stops inline with the wing's profile i.e. where the wing is actually shielding the prop from the airflow, which of course happens also to be the most aerodynamic place for it to be held too.
Ian Davidson is offline Find More Posts by Ian Davidson
Old Apr 28, 2012, 11:28 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
The manual is posted on the first of this thread.
Originally Posted by sa-woody View Post
Where in this 133 pages does it refer to painting the ZII?
klique is offline Find More Posts by klique
Old Apr 29, 2012, 03:30 AM
khaled_abobakr is offline
Find More Posts by khaled_abobakr
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
Hi
Just wanted to share how I ended up launching my 2223g ZII ... you still have to use at least 3/4 throttle to launch, but with a good grip on that chunk of foam, and a firm, steady throw like a Javelin from behind with an angle of about 45 degree ... it launches a lot easier .. yes a powered launch ... much like launching an EZ star type plane .. but with more power and more weight ..
I hope it helps some one ...
PS... it doesn't seem to alter aerodynamics ... and you may lose it in the future when you get more skilled
Update :... On another note ... one long central skid... reaching to the CG and firmly glued/velcroed to the bottom can do the job too .. with less volume/drag
Here are a couple of photos ...
Khaled
khaled_abobakr is offline Find More Posts by khaled_abobakr
Old Apr 29, 2012, 04:38 AM
Joined Nov 2006
Originally Posted by sharonx View Post
the anti vibration is a must - trust me, my friend learnt it the hard way.
Here you go :
https://picasaweb.google.com/1109419...MPkp_mLiYPvywE
https://picasaweb.google.com/1109419...OLxgK6-mL7dvgE
Hi Sharonx
If the RVOSD V5 uses the same technology as the FY20A... I'm pretty much sure it is the case .. then Velcro did the the job just fine in my Bixelr.. you may use a layer of gyro foam for extra dampening and at the same time keep the height low so it can fit inside the back electronic bay ..
what I don't like about the original anti vibration mount, is, if for some reason the wires moved , they will alter the perfect flat mounting position of the RVOSD board .. and will cause unwanted reactions from it .. this is why I use solid ant vibration mount rather than the flexible mounts with rubber rings ...
Khaled
Old Apr 29, 2012, 09:51 AM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by paintz2007 View Post
refer to the build instructions, you can find them on the at the rmrc site... on the zii page,
flat, light colors, bright colors, fusion all in light coats
that is about 3-4 light coats of paint on each color
Your cat seems to like the colors.
Eagle202 is offline Find More Posts by Eagle202
Old Apr 29, 2012, 12:14 PM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
Where is the best location for bungee launch hook? Right at the cog? I would think in front of it would be better but how far?
freshmint is offline Find More Posts by freshmint
Old Apr 29, 2012, 12:20 PM
paintz2007 is offline
Find More Posts by paintz2007
Guess Who's Back? :D
paintz2007's Avatar
Joined Sep 2006
I think she was huffing the spray adhesive...
paintz2007 is offline Find More Posts by paintz2007
Old Apr 29, 2012, 01:18 PM
klique is offline
Mum is the word!
Joined Jun 2003
Do you seriously want to put your hand that close to a prop???
Throw it pizza box style it works great everytime.
Originally Posted by khaled_abobakr View Post
Hi
Khaled
Old Apr 29, 2012, 01:20 PM
klique is offline
Mum is the word!
Joined Jun 2003
I usually go about 1/3 to 1/2 way back to the cg mark.
Old Apr 29, 2012, 04:53 PM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
Can anyone tell me if this motor will work " O.S. .25 1200kv "http://www.amainhobbies.com/product_info.php/cPath/3_437_700/products_id/207264/n/OS-25-Brushless-Motor-1200kV
hotdog1 is offline Find More Posts by hotdog1
Old Apr 29, 2012, 05:16 PM
paintz2007's Avatar
Joined Sep 2006
should be fine its rite around the same as what is used, i have a lite build on an axi 2820-10 (1185kv .25 size) and i go vertical on a 10x8 prop forever on 3s.
Old Apr 29, 2012, 05:26 PM
Mechnan is offline
Find More Posts by Mechnan
Schweiz, BE, Neuenegg
Joined Apr 2011
Zephyr Maiden in Bern (4 min 4 sec)
Mechnan is offline Find More Posts by Mechnan
Old Apr 29, 2012, 10:47 PM
Hance is offline
Find More Posts by Hance
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
Hi
Khaled
I have thrown lots of ritewings and your launch method looks down right scary to me
Hance is offline Find More Posts by Hance
Old Apr 29, 2012, 10:58 PM
BCSaltchucker is online now
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
damage today upon launch today. I had a volunteer throw it off a cliff for me. Now I admit not informing him to take a run at it and really heave it, but it just puked out and the battery pushed the camera box right off. OK only 20 minutes to fix it isn't too bad, but no flight means I am bummed.
That is it, I am either putting retracts or building a takeoff cart for it NOW.
meanwhile had some great FPV flight with my EPP Eagle today .. just really slow compared to the Zeph.
BCSaltchucker is online now Find More Posts by BCSaltchucker
Old Apr 29, 2012, 11:06 PM
paintz2007's Avatar
Joined Sep 2006
Originally Posted by BCSaltchucker View Post
putting retracts
please do i already want to but am concerned for weight.. a cart is more feasable though
and price
http://www.e-fliterc.com/Products/De...ProdID=EFLG230
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
