Old Apr 15, 2012, 07:28 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by ROCKY2 View Post
Rocky
Again an amazing video. Great flying and editing going from farmland to the beach during a spin. Fantastic
Only one place I think you need to avoid. If you play with the electric grid they will come after you.
Going through the wires is somewhat ok but if you had hit one of those insulators on the towers, it would have been the 4th of July.
Eagle202 is offline Find More Posts by Eagle202
Old Apr 15, 2012, 08:16 PM
freshmint is offline
Find More Posts by freshmint
Joined Nov 2011
You think these foam plane will cause that much destruction?
freshmint is offline Find More Posts by freshmint
Old Apr 15, 2012, 08:44 PM
paintz2007 is offline
Find More Posts by paintz2007
Guess Who's Back? :D
paintz2007's Avatar
Joined Sep 2006
you ever have a squirrel knock out the power at your house?
paintz2007 is offline Find More Posts by paintz2007
Old Apr 15, 2012, 09:08 PM
ROCKY2 is offline
Find More Posts by ROCKY2
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
Rocky
haha ya maybe but im careful
ROCKY2 is offline Find More Posts by ROCKY2
Old Apr 15, 2012, 09:27 PM
paintz2007's Avatar
Joined Sep 2006
got her done! gotta laterally balance it yet and cover the holes with some lam.. maybe add a scoop or two or three...
Axi 2820/10
Castle Ice 100
hs-645mg's
3s3p 2200
10x8 graupner cam (with 10x6 on stand-by, and a 9x5 if i want to run 4s)
pulls 60a at 600+ watts, nearly 1:1 but I'm almost positive my prop is stalling...
900/500
kx171
remzibi osd
3s 2200 (wing mounted)
model was Tigger
Old Apr 15, 2012, 10:53 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
I estimate that the power line was at least 138kv to 260kv or higher. It doesn't take much to cause an arc across anything that might be conducting even moist air. The rule of thumb is electricity can arc one inch for every 1000 volts. At 138kv that is more than 10 feet.
If he had hit one of the insulators head on it could have caused an arc to be created to the tower steel.
That would have shut down that circuit and caused a major power blackout.
So yes I do think a foam plane could cause a power outage.
Old Apr 15, 2012, 11:29 PM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
hey paintz
i used a 10x8 (aeronaut) it was a waste of time. the Z is too draggy to use that prop. either use less pitch or a bigger prop. 10x6 will work beautifully.
Axi 2820/10
Castle Ice 100
hs-645mg's
3s3p 2200
900/500
kx171
remzibi osd
model was Tigger
brosius85 is offline Find More Posts by brosius85
Old Apr 17, 2012, 09:05 AM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
hey guys what is the lam is it like ultra coat or some other heat activated material ?
hotdog1 is offline Find More Posts by hotdog1
Old Apr 17, 2012, 10:10 AM
slarys is online now
Find More Posts by slarys
The Netherlands
Joined Jul 2011
heat activated
slarys is online now Find More Posts by slarys
Old Apr 17, 2012, 10:57 AM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
it is just laminate used for laminating paper documents, like they use at your local Staples or Office Depot. Super super inexpensive and yet strengthens these planes really well. I bought a 250 ft roll online for $35 which is enough to cover 15 or 20 planes.
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Apr 17, 2012, 11:11 AM
Hugeone is offline
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
When a ground fault is detected the line's circuit breaker open and re-close half a second later, if fault is gone (which is likely) then things go back to normal.
-Hugo
Hugeone is offline Find More Posts by Hugeone
Old Apr 17, 2012, 12:29 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
-Hugo
Hugo
I agree. That is the design and practice for most utility electrical distribution systems. The consumers would only get a momentary outage which can still be disruptive to manufacturing plants.
My fear is that while the insulator may not break from the impact, it may crack and break from the arc blast. The conductor would no longer be attached to the tower and could now swing and create another arc if it go too close to the tower or another conductor.
There is a lot of power released in a high voltage fault.
Old Apr 17, 2012, 12:55 PM
Eagle202 is offline
Eagle202's Avatar
Joined Aug 2011
I performed a bench test of my motor to see how many amps it draws at WOT. I am using the following:
Ritewing 1200kv motor
Ritewing 65A ESC
3s 3000mah battery
10 x 5E prop.
I got a reading of about 39 amps which is great. What bothered me was how much the motor's outrunner moved away from the base. It stopped when the retaining c clamp came in contact with the motor frame. My estimate is about 3/32 of an inch or a little over 2 mm.
Is that normal and if not what do I need to do?
Old Apr 17, 2012, 03:45 PM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Is it like this stuff?
http://www.binding101.com/25x250-school-film.html
Do you know the thickness? I see 1.5 ml and 3 mil.
marhar is offline Find More Posts by marhar
Old Apr 17, 2012, 04:56 PM
paintz2007's Avatar
Joined Sep 2006
Shouldn't be a problem as long as the c clip stays in place if not maybe get a collar with a set screw to lock it in place
Ritewing 65A ESC
3s 3000mah battery
10 x 5E prop.
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
