Old Apr 08, 2012, 09:21 AM
Grips is offline
Find More Posts by Grips
Eat-Sleep-Work-Fly-Repeat
Grips's Avatar
Canada, NL, Division No. 9
Joined Mar 2011
Guys: Has anyone setup a head tracker on a Zephyr yet?
Grips is offline Find More Posts by Grips
Old Apr 08, 2012, 02:35 PM
sharonx is offline
Find More Posts by sharonx
sharonx's Avatar
Under the bridge...
http://www.youtube.com/watch?v=fCJq6eQ-gBc
sharonx is offline Find More Posts by sharonx
Old Apr 08, 2012, 04:50 PM
dr_patso is offline
Find More Posts by dr_patso
N00b
Boise
Joined Mar 2009
Originally Posted by sharonx View Post
blocked in US =(
dr_patso is offline Find More Posts by dr_patso
Old Apr 08, 2012, 05:46 PM
ands is offline
Find More Posts by ands
wottree
United Kingdom, England, Exeter
Joined Nov 2011
nice vid man,
what set up?
why blocked in the US?
ands is offline Find More Posts by ands
Old Apr 08, 2012, 06:44 PM
Stone1295 is offline
Find More Posts by Stone1295
AMA 937634
Stone1295's Avatar
United States, AK, Anchorage
Joined Jan 2010
The error message states:
"This video contains content from WMG, who has blocked it in your country on copyright grounds."
-Mike
Stone1295 is offline Find More Posts by Stone1295
Old Apr 09, 2012, 10:42 AM
Halford is offline
Find More Posts by Halford
Belgium, Brussels
Joined Jul 2010
I'm going to be ignored or joked about, but.....
This is my first wing, I'm a heli/quad copter guy.... And now that I have to link my servos on the Zeph I wonder how do I do it.... I have multiple input for 2 servos... Do I need mixing or "Y" wires to hook up? I'm a noob, sorry...
Halford is offline Find More Posts by Halford
Old Apr 09, 2012, 12:31 PM
zooman is offline
Find More Posts by zooman
zooman's Avatar
Canada, AB, Jasper
Joined Feb 2007
They need there own channel and mixing.
The same sevro that makes the plane go left and right also makes the plane go up and down.
zooman is offline Find More Posts by zooman
Old Apr 09, 2012, 01:28 PM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
usually need to plug the elevons into 2 channels and program the mix in the radio. Need to know which channels your radio uses for elevon mixing, so check the manual.
- unless you are using onboard mixing like I am (Eagle Tree) which still uses 2 channels from control input, but the servos are wired differently.
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Apr 09, 2012, 01:34 PM
Halford is offline
Belgium, Brussels
Joined Jul 2010
Thanks guys, so I guess the elevons and aileron will be in a Y cable to the servos and then do the mixing in the radio.... I'll read my maunal...I bought it in Honk Kong at the time, I'll have to download the english version from their site
Old Apr 09, 2012, 01:51 PM
zooman is offline
zooman's Avatar
Canada, AB, Jasper
Joined Feb 2007
Just so were on the same level.
There's only elevons on this wing. NO ailerons.
http://rcvehicles.about.com/od/glossary/g/elevons.htm
Old Apr 09, 2012, 02:07 PM
Halford is offline
Belgium, Brussels
Joined Jul 2010
right! thanks, I was getting confused...
Old Apr 09, 2012, 04:50 PM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
I had a hard time getting a handle on exactly how elevon mixing worked, so after I figured it out I wrote it up here:
http://eastbay-rc.blogspot.com/2011/...il-mixing.html
http://eastbay-rc.blogspot.com/2011/...culations.html
As everybody has pointed out, it's typical to have the servos on to separate channels and have your radio mix into elevon mode.
If you've got a Spektrum DX6i, there's a bug in elevon mixing and it doesn't work. Hance has a nice workaround here:
http://www.rcgroups.com/forums/showthread.php?t=1553248
marhar is offline Find More Posts by marhar
Old Apr 10, 2012, 01:35 AM
Halford is offline
Belgium, Brussels
Joined Jul 2010
Wow thanks! I have an old wk2801 pro that I modified with a dragon link... I just found out that it has a delta wing preset for elevons...I'll check out your guide, thank you for doing that!!!
Old Apr 10, 2012, 02:51 AM
fly by night
Joined Sep 2011
there is a bug? I have programmed elevons in my DX6i easy as pie on 2 planes. Plug the elevons into ch1 and 2, select elevons in the Wing-Tail Mix menu and make sure throws are the right direction. This took me like 30 seconds and I didn't even consult the manual and had never set up elevons before. Nowhere near as many steps as in the thread.
and Halford - just to be sure you understand, you cannot use any Y cable for elevons!
Old Apr 10, 2012, 08:18 AM
paintz2007 is offline
Find More Posts by paintz2007
Guess Who's Back? :D
paintz2007's Avatar
Joined Sep 2006
elevator+ailerons=elevons
paintz2007 is offline Find More Posts by paintz2007
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
