Old Apr 05, 2012, 02:54 PM
chicken sashimi is offline
Find More Posts by chicken sashimi
WOT happened?
chicken sashimi's Avatar
Canada, BC, Vancouver
Joined Sep 2011
ok.. good to know.. thanks Chris.
Is there a specific brand name you suggest i search for? Do you have any favorites? Where do you buy your props?
Thanks again.
chicken sashimi is offline Find More Posts by chicken sashimi
Old Apr 05, 2012, 04:16 PM
Halford is offline
Find More Posts by Halford
Belgium, Brussels
Joined Jul 2010
Thanks again.
I find very good and widely used the aeronaut cam 10X6 Folding prop
Halford is offline Find More Posts by Halford
Old Apr 05, 2012, 10:56 PM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Hey everyone I just paid for my z2 and everything except for a prop for it. What is some good props to run in a 3s setup? And a good prop for a 4s setup. I have both batteries 3s-4s but I have 3 4400mah 3s batteries that I'd like to be able to use in this if I want to.
Oh this will also be my 1st build besides stuff I've made out of foam board so I hope it's not to hard to putbtogether. I've never had to use aproxies or gorilla glue or anything so this will be interesting. I hope it goes easy.
flohio117 is offline Find More Posts by flohio117
Old Apr 06, 2012, 02:13 AM
Raften is offline
Find More Posts by Raften
NorCal
Joined Dec 2009
Make sure you know how to control the foaming of GG.
Raften is offline Find More Posts by Raften
Old Apr 06, 2012, 03:50 AM
brosius85 is offline
Find More Posts by brosius85
never mind the boll⁣⁣⁣ocks
brosius85's Avatar
Australia, NSW
Joined Dec 2010
flohio
i am guessing you have the ritewing motor? 3s 10x5 4s 9x6
i think. i have not got the data on it but that should be a safe place to start.
more than anything it depends on your flying style and altitude. high altitude needs more pitch, low altitude will draw more amps.
keep an eye on the temps when running a new prop, that will tell you for certain if it is the right prop. if the motor ends up too hot to touch you are going to kill it for sure.
brosius85 is offline Find More Posts by brosius85
Old Apr 06, 2012, 07:52 AM
khaled_abobakr is offline
Find More Posts by khaled_abobakr
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
I strongly recommend that you simulate the whole process of installing the main spars .. so you don't end like me.... a scrap foam and some extra GG will save your ZII for sure .. it is something that has to be done to be felt right .. and be prepared to fix the spars with blunt tools like flat screw drives or whatever .. so they don't float .. also dry fit the main spars in the slot before you proceed with the gorilla glue .. so you have an idea of how they should look at the end ... and know for sure if your spars have floated or they are properly seated ..
the use of CA and kicker to hold the spars so they won't float .. has to be tested to .. use brands that you're comfortable with and already know how long will it take to cure .. ... this step is messy .. but with right preparations and this suggested simulation you should be fine .. try it on scarab foam and a couple of wooden dowels... just to get the proper feeling
Khaled
khaled_abobakr is offline Find More Posts by khaled_abobakr
Old Apr 06, 2012, 12:02 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
Dang guys this thing sounds out of my skill level to build lmao! Also thanks for breaking down the props. I think I'll just pay the extra and have it built right so I don't mess it up.
Old Apr 06, 2012, 12:09 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Its not hard if you pay attention to detail.
klique is offline Find More Posts by klique
Old Apr 06, 2012, 12:25 PM
sharonx is offline
Find More Posts by sharonx
sharonx's Avatar
just replaced my axi with the 30 10l hacker. it draws 68 amp on 4s and folding 10x6. can I run it on WOT unlimited or can it burn? how long bursts are possible?
Sent from my Samsung Galaxy II using Tapatalk
sharonx is offline Find More Posts by sharonx
Old Apr 06, 2012, 06:26 PM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
if you want to run a thousand watts for extended periods, get a motor rated to do it.
the 10L is not a thousand watt rated motor.
Old Apr 06, 2012, 07:55 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
My ZII was my first "build from scratch" also. It is not difficult and if you run into any issues there is a lot of help right here on this thread.
If you build it yourself you will enjoy flying it that much more..
Eagle202 is offline Find More Posts by Eagle202
Old Apr 06, 2012, 07:56 PM
superevan is offline
Find More Posts by superevan
superevan's Avatar
United States, TX, Austin
Joined Aug 2007
Brosius85, I bought an el cheapo plastic 10x6 just to start with on my 3s, ritewing motor setup (2kg auw). My LHS didn't have many options and I didn't feel the need to take the plunge on an expensive CF folding prop. You think that'll be alright?
Due to timing, and life in general I probably won't get to maiden it for a couple of weeks but I figure I'd ask the man now.
superevan is offline Find More Posts by superevan
Old Apr 06, 2012, 10:13 PM
brosius85's Avatar
Australia, NSW
Joined Dec 2010
on 3s it will probably be ok. i just would not use a cheap folder. go with a normal prop and there is no chance of a problem.
Old Apr 06, 2012, 10:16 PM
superevan's Avatar
Joined Aug 2007
Thanks for the advice. And you are in fact the zephyr man!
Old Apr 06, 2012, 10:37 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
I'm just going to have it made that way I know I'm not throwing my money away. And I also don't really have the time to mess one up. Because I'm moving from alaskanto Texas soon and I'm driving the whole way and want to fly FPV and get great video while on the trip.
Build Log Building the ultimate Ritewing Zephyr ThomasWF FPV Talk 34 Feb 20, 2012 05:14 PM
Discussion wing thickness ritewing zephyr Herishi The Builders Workshop 2 Oct 05, 2011 08:36 AM
Discussion Ritewing Zephyr hobbycity motor nexstarselect FPV Talk 2 Mar 07, 2011 04:37 PM
