Old Feb 16, 2013, 12:36 PM
coolboarder is offline
Find More Posts by coolboarder
Plane on the Brain
coolboarder's Avatar
Joined Apr 2005
I posted the link to the exploded diagram 6 posts ago.
repair Vids
Blade 450 X Repair Tutorial: Spindle Replacement (12 min 22 sec)
coolboarder is offline Find More Posts by coolboarder
Old Feb 21, 2013, 05:19 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Here is my problem. The Stock motor was the perfect length with the pinion as close to the motor as possible.
The Scorpion pinion in 4mm longer. This puts me hitting the Tail drive gear.
Is there a good way to fix this? Putting 4mm of washers between the motor and motor mount doesn't sound like a great idea, bu it will probably work.
May be I should just find a 12T pinion that is not longer than 10mm.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Feb 21, 2013, 08:40 PM
Diesel6401 is offline
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
Take the collar off. Slide the pinon up higher.
Diesel6401 is offline Find More Posts by Diesel6401
Old Feb 21, 2013, 08:44 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Here's mine.
No problems this way for me.
Old Feb 22, 2013, 07:18 AM
You down with EPP?
Houston, Tx
Joined May 2009
Originally Posted by Diesel6401 View Post
Here's mine.
Which pinion gear are you using? Where did you get it?
Old Feb 22, 2013, 09:26 AM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Rhino from Helidirect:
http://helidirect.com/450-class-pini..._44_78_513.hdx
Old Feb 22, 2013, 06:36 PM
You down with EPP?
Houston, Tx
Joined May 2009
No collar on mine. The pinions that Innov8tie Designs has in in stock are like 14mm long.
I am going to order one of those rhinos.
Old Feb 22, 2013, 07:58 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
In the picture you showed side by side with the stock motor your scorpion still has the lock collar / thrust bearing around the shaft. Remove that.
Old Feb 25, 2013, 10:56 AM
You down with EPP?
Houston, Tx
Joined May 2009
Anyone know which Swash leveler fits a 450x at Heli Direct?
Old Feb 25, 2013, 01:38 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Get the blade one http://www.bladehelis.com/Products/D...rodID=BLH1690A
It sets the swash mid stick, levels and you don't need to take the head off. Slides from behind. Nice and simple. Your LHS may have one.
Old Feb 25, 2013, 02:41 PM
r/cdawg is offline
Find More Posts by r/cdawg
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
Hi johnnyrocco,
I went and took the plunge and picked up a new 450x from my lhs. Very sweet looking bird and I hope mine is as good as the vast majority of those who have them. Looking forward to geting this one in the air.
dawg
r/cdawg is offline Find More Posts by r/cdawg
Old Feb 25, 2013, 04:18 PM
You down with EPP?
Houston, Tx
Joined May 2009
Originally Posted by r/cdawg View Post
Hi johnnyrocco,
dawg
I absolutely love mine. IT has crazy power right out of the box. Just be careful with that motor. Hover for a good 30 seconds before you fly. You will hear it when it is about to go.
Or just upgrade the motor now
Diesel, thanks for the swash tip. I picked one up today.
I always borrowed one in the past. This one seems to do the job.
Old Feb 25, 2013, 06:14 PM
Jboy90277 is offline
Find More Posts by Jboy90277
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
... Just be careful with that motor. Hover for a good 30 seconds before you fly. You will hear it when it is about to go.
+1. My new 440H motor only lasted about 10 flights before the bearings disintegrated doing pitch pumps - ended up bending the motor shaft and destroying the rest of the motor in the process.
I'll put a plug in for the eFlite Heli 450 motor - great power, comes down cool , and gives me over 4 minutes of hard flying with my 3S 2200s. This is a video of mine paired with a 13T pinion (stock main gear).
Blade 450 High Energy Flying (4 min 9 sec)
Jboy90277 is offline Find More Posts by Jboy90277
Old Feb 25, 2013, 07:01 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
You can replace the bearing on the motor or move to a scorpion.
If not I have a NIB stock motor, $40 shipped (US). They're $47.99 normally.
http://www.bladehelis.com/Products/D...odID=EFLM1360H
Check out the Fusuno canopies also new guys. They're so much better than the stocks its not even funny.
Old Feb 25, 2013, 11:12 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Dig the canopy Diesel!
what motor are you running in your 450?
and how are you liking the Pulse packs?
brushless55 is offline Find More Posts by brushless55
Discussion Blade 450 X statiiic 3D Electric Heli Flying 146 Mar 27, 2016 08:35 PM
Discussion Official Blade 450 3D owners and support thread KYlawyer Mini Helis 293 Jun 02, 2014 02:36 AM
Discussion E-Flite Blade 450 X?? statiiic Electric Heli Talk 1 Oct 20, 2011 10:50 PM
Sold FS/T Blade 400 3d, Blade CP, HDX 450 Hegemone Aircraft - Electric - Helis (FS/W) 2 Apr 10, 2011 09:38 PM
