Old Jan 24, 2013, 09:11 AM
Gedexas is offline
Find More Posts by Gedexas
CP heli ≠ 3D heli
Gedexas's Avatar
United States, NJ, Point Pleasant Beach
Joined Mar 2009
Originally Posted by poiyt View Post
Gents I have a pr of stock 450X CF blades f/s:
http://www.rcgroups.com/forums/showthread.php?t=1816015
Thx for looking
Jeff
You have to remove your e-mail address from your for sale post. That's what the PM system is for. #1 You don't want multiple people sending you payments for only one item. #2 you don't want Viagra ads in your inbox. Unless, of course, you do want that. #3 You don't want me to attempt to guess your e-mail password. If I do happen to guess it, I already have your first and last name, guess what I can do with that information.
Gedexas is offline Find More Posts by Gedexas
Old Jan 24, 2013, 09:58 PM
coolboarder is offline
Find More Posts by coolboarder
Plane on the Brain
coolboarder's Avatar
Joined Apr 2005
i logged in to read that . gmail does have the best spam filter of any service out there.
Oh and I installed the metal tail case. I am almost certain it made the belt tighter which means i will have to re-trim the darn tail
coolboarder is offline Find More Posts by coolboarder
Old Feb 02, 2013, 08:00 AM
RyPlane is offline
Find More Posts by RyPlane
United States, MN, Clearwater
Joined Jul 2012
Originally Posted by Diesel6401 View Post
I'm running stock motor and pinion on one of mine and a Scorpion 2221-8 on the other. The Scorpion motor I'm in love with. I forget which pinion I'm running on that one.
Thank you much. Still looking for that gaui style body through
RyPlane is offline Find More Posts by RyPlane
Old Feb 02, 2013, 02:34 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Tail blades
Looking at the tail blades, is this the way they're supposed to go back on? I forgot if the screw goes in the outside of the grip and the nut goes on the inside of the grip? What about the washer? Does it go on the inside of the grip with the blade?
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Feb 02, 2013, 11:34 PM
Plane on the Brain
Joined Apr 2005
I'm pretty sure your blades are facing the wrong direction. The leading edge cuts up into the propwash so simply unhook the two ball links and flip them.
As far as the grips, the exploded diagram can be found here
http://www.bladehelis.com/Products/S...LH4380#manuals
Old Feb 03, 2013, 01:06 AM
You down with EPP?
Houston, Tx
Joined May 2009
Yeah, I flipped the blades. They were backwards.
My issue is the screw and nut that hold the tail blades on.
I can tighten them by hand and the tail blade gets too tight, yet the nut is still loose.
...in other words, if I don't tighten the nut, the blade is going to fly off, but if I do tighten the nut, the blade can't move.
Old Feb 03, 2013, 08:54 AM
Plane on the Brain
Joined Apr 2005
What is your definition of loose?
I achieved proper tension with my bare hands, but there is enough friction that general spinning would not loosen them on their own. I also used some loctite. You could then add hot glue for piece of mind. Hot glue will stick like crazy to the stock plastic. Maybe check the thread on helli freeek
Has it flown yet? Was it loose out of the box? maybe you need new hardware
Old Feb 03, 2013, 10:42 AM
DanBo3D is offline
Find More Posts by DanBo3D
RC Keeps Me Sane
DanBo3D's Avatar
United States, NJ, Carlstadt
Joined Sep 2005
You need to add a drop of medium/blue locktite and tighten the nut until you get the blade just right and then let it dry. It'll only come off if and when you break the thread lock.
DanBo3D is offline Find More Posts by DanBo3D
Old Feb 03, 2013, 10:34 PM
You down with EPP?
Houston, Tx
Joined May 2009
Yes, I thought I was in the twilight zone.
Is it just me, or is a lock nut the standard on every heli tail blade/ main blade in the hobby????
I put some locktite on and it was fine.
Old Feb 03, 2013, 11:58 PM
DanBo3D is offline
RC Keeps Me Sane
DanBo3D's Avatar
Joined Sep 2005
Because blade uses the weighted style nut and bolt design it's a thread lock type and not lock nut type. Although you could use lock nuts with hardly a difference in performance if any at all.
Old Feb 12, 2013, 11:08 PM
Topher87 is offline
Find More Posts by Topher87
United States, MO, KCMO
Joined Mar 2011
Hey what r the blade dimensions just curious thinking about getting one of these and haven't been able to find any led blades so im just gonna have to make em I need to know how wide and long the blades r and also how thick thank u if u can answer
Topher87 is offline Find More Posts by Topher87
Old Feb 13, 2013, 08:19 PM
Plane on the Brain
Joined Apr 2005
these are from the Edge website of the blades i use. stock blades are different
Specs:
- Length: 325mm
- Width: 32mm
- Root: 4.5mm
- Bolt Hole: 3mm
- Weight: ~ 24 grams
Old Feb 15, 2013, 10:26 AM
You down with EPP?
Houston, Tx
Joined May 2009
Scorpion HK-2221-8V2
Can anyone confirm that the stock ESC is ok to use with this scorpion motor and a 12T pinion?
I honestly, don't even know how to check amps on a Heli
Old Feb 16, 2013, 09:24 AM
450man is offline
Find More Posts by 450man
450 Helis Rule!
450man's Avatar
United Kingdom, England, Saltash
Joined Aug 2012
Had my first crash with my 450X yesterday. Feathering shaft and possibly main shaft is the main damage.
Is there a build/repair manual for the 450X? I have to remove the feathering shaft and replace it and I don't have an expanded diagram.
450man is offline Find More Posts by 450man
Old Feb 16, 2013, 09:44 AM
You down with EPP?
Houston, Tx
Joined May 2009
When I did mine, it was very easy. Just wait to take it apart until you are ready to swap it out. Same with the main shaft.
Discussion Blade 450 X statiiic 3D Electric Heli Flying 146 Mar 27, 2016 08:35 PM
Discussion Official Blade 450 3D owners and support thread KYlawyer Mini Helis 293 Jun 02, 2014 02:36 AM
Discussion E-Flite Blade 450 X?? statiiic Electric Heli Talk 1 Oct 20, 2011 10:50 PM
Sold FS/T Blade 400 3d, Blade CP, HDX 450 Hegemone Aircraft - Electric - Helis (FS/W) 2 Apr 10, 2011 09:38 PM
