Old Oct 20, 2011, 10:58 PM
FlybarlessMatt is offline
Find More Posts by FlybarlessMatt
iFlybarless
FlybarlessMatt's Avatar
Joined Oct 2011
Official Blade 450 X 3D Forum
The Brand New Blade 450 3D X
Here is the compiled information about the Blade 450 X.
Found here: http://www.horizonhobby.com/Products...ProdID=BLH4380
Blade 450 X BNF
Overview
The phenomenal Blade 450 X has been designed from the ground up to give experienced 3D pilots the most extreme performance available in a Bind-N-Fly 450-size platform. Central to its awesome performance is the Spektrum AR7200BX 7-channel DSMX® receiver with built-in BeastX™ flybarless technology – the most advanced flybarless technology available for high-performance 3D helicopters. This, along with features like its high-output brushless power system, hardened dampers and carbon fiber main blades, allow the Blade 450 X to achieve a level of 3D performance that practically defies physics.
Key Features
Spektrum™ AR7200BX DSMX receiver with BeastX technology
Powerful E-flite® 440H 4200Kv brushless motor
E-flite 35A S-BEC ESC
325mm carbon fiber main blades
Hardened 80-degree dampers
Composite aluminum/fiber-reinforced swashplate
E-flite DS76 digital sub-micro cyclic servos
E-flite DS76T digital sub-micro tail servo
CNC-machined aluminum head block
Triple ball bearing supported, hardened steel main shaft
Belt-driven tail rotor
Weighted tail blade mounting hardware
Rigid, lightweight main frame
Aluminum tail boom
Tail rotor grips with thrust bearings
Includes a high-output E-flite 3S 11.1V 2200mAh 30C Li-Po battery
Includes 3-cell DC Li-Po balancing charger
Needed to Complete
A 6+ channel DSM2- or DSMX-compatible transmitter with helicopter programming
Specs
Type: Electric Flybarless Collective-Pitch Helicopter
Main Rotor Diameter: 28.4 in (721mm)
Tail Rotor Diameter: 6.1 in (155mm)
Gross Weight: 25.3 oz (717 g)
Length: 25.8 in (655mm)
Kit/ARF/RTF: BNF
Rotor Blade Length: 325mm
Minimum Age Recommendation: 14 years
Experience Level: Advanced
Recommended Environment: Outdoor
Is Assembly Required: No
Expected release: Late November, 2011
Total price: $499.99
This makes my regular Blade 450 3D look like last years iPad. Obsolete.
Well guys, I guess we get what we asked for... a Flybarless Blade 450 3D.
This is an open conversation; comments, ideas, and thoughts are welcome.
FlybarlessMatt is offline Find More Posts by FlybarlessMatt
Old Oct 20, 2011, 11:08 PM
sirs69 is offline
Find More Posts by sirs69
sirs69's Avatar
United States, MO, St Peters
Joined Apr 2011
Looks slick, can't wait
sirs69 is offline Find More Posts by sirs69
Old Oct 20, 2011, 11:36 PM
nick_onelove is offline
Find More Posts by nick_onelove
Build, Fly, Crash. Repeat.
nick_onelove's Avatar
Joined May 2011
Here we go again. Subscribed.
nick_onelove is offline Find More Posts by nick_onelove
Old Oct 20, 2011, 11:40 PM
choppersrule is offline
Find More Posts by choppersrule
Got Helis
choppersrule's Avatar
United States, IN, Greenwood
Joined Mar 2010
Me too, I'm very interested in this heli and anxious to see how it performs.
choppersrule is offline Find More Posts by choppersrule
mhunter is offline
Find More Posts by mhunter
Joined Jul 2011
Tagscribed...
mhunter is offline Find More Posts by mhunter
Old Oct 21, 2011, 12:07 AM
Druss is offline
Find More Posts by Druss
Canada, AB, Edmonton
Joined May 2008
Looks like it might be pretty good value but I've never been a big fan of eflite servos and fbl systems work the cyclic servos hard. The specs on the servos look ok but they only list 4.8v, wonder if that means you have no option to output 6v?
Druss is offline Find More Posts by Druss
Old Oct 21, 2011, 12:48 AM
iFlybarless
Joined Oct 2011
That brings up a good point. I looked at the specs of the cyclic servos and I found they do function at 6V, but the advantages aren't very much IMHO.
http://www.horizonhobby.com/Products...S76#quickSpecs
Old Oct 21, 2011, 12:57 AM
destinbeachman is offline
Find More Posts by destinbeachman
destinbeachman's Avatar
Florida
Joined Jul 2010
It would be easier to keep up with this if it were moved to the Mini section.Just a suggestion.
destinbeachman is offline Find More Posts by destinbeachman
Old Oct 21, 2011, 10:06 AM
Druss is offline
Joined May 2008
Ya... pretty cheap servos though (cost wise). I'm very interested in the receiver/3-axi gyro but will pass on the rest. Would rather build a clone w/ my own electronics choices and just stick the ar7200bx in it.
Old Oct 21, 2011, 10:37 AM
mhunter is offline
Joined Jul 2011
Amazing how these "real" servos are a full $5 cheaper than the stupid mCP X servos.
But, these servos seem pretty good so far. I have a bunch of flights on my B450 3D and they're holding up fine. And I fly pretty hard...but I haven't crashed YET, either... I'm fully expecting them to strip and I have three Hitec HS65MG servos standing by for when they do. Last I checked, HH didn't even have the replacement plastic gear train parts for those servos.
Old Oct 21, 2011, 12:04 PM
egaus is offline
Find More Posts by egaus
Quadrophenia
egaus's Avatar
Seattle
Joined Mar 2009
More interesting than the helicopter itself is:
Can a sat be plugged into this unit as well?
e
egaus is offline Find More Posts by egaus
Old Oct 21, 2011, 12:14 PM
Druss is offline
Joined May 2008
e
From the pictures it doesn't look like there's a port for a satellite. The other thing is that while it's nice and compact... what if you need more channels for something like a scale heli? 7ch is more than enough if all you want is an fbl heli but what if you have retracts, lights, winch... etc? Wonder if an AR9200BX is in the works?
Old Oct 21, 2011, 02:33 PM
mhunter is offline
Joined Jul 2011
e
Yes. If you look at the picture in the link below closely, there is an Rx L port right in the middle of all the other channels. It was also confirmed by a HH employee over on Helifreak.
http://www.spektrumrc.com/Products/D...ID=SPMAR7200BX
Old Oct 21, 2011, 02:42 PM
mhunter is offline
Joined Jul 2011
Also, they REALLY need to offer a TT option for the tail, especially if they're aiming for the Align Trex 450 market. This thing is marketed as an "advanced" heli right on their website. A great many serious, hardcore heli pilots aren't going to want a belt tail. Have a "sport" version with the belt and a "pro" version with TT tail drive...
Old Oct 21, 2011, 02:49 PM
tcb22185 is offline
Find More Posts by tcb22185
tcb22185's Avatar
USA, Fl , Venice
Joined Jan 2010
They Will NEVER hit the Align 450 Market NEVER COME CLOSE!!!!
tcb22185 is offline Find More Posts by tcb22185
Discussion Blade 450 X statiiic 3D Electric Heli Flying 146 Mar 27, 2016 08:35 PM
Discussion Official Blade 450 3D owners and support thread KYlawyer Mini Helis 293 Jun 02, 2014 02:36 AM
Discussion E-Flite Blade 450 X?? statiiic Electric Heli Talk 1 Oct 20, 2011 10:50 PM
Sold FS/T Blade 400 3d, Blade CP, HDX 450 Hegemone Aircraft - Electric - Helis (FS/W) 2 Apr 10, 2011 09:38 PM
