Old Jan 05, 2012, 08:56 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Originally Posted by bytemuncher View Post
Seems some have. I tried today with hk-282a's (orange color) and failed. They looked okay on the ground, ele, ail, and pitch all working fine. As soon as I tried to lift off the heli would just nose dive like it was possessed. I tried turning the gyros down but didn't help. The wire switching part was easy, but mounting them was a pita. Quite possible I screwed something up but I'm not going to spend anymore time on it as my stock are fine...for now at least.
So before the word gets out that these don't work anyone want to buy 8 new in package 282A servos??
You did remember to switch the gyro switch back to ON right?
livonia bob is offline Find More Posts by livonia bob
Old Jan 05, 2012, 09:19 AM
bytemuncher is offline
Find More Posts by bytemuncher
Tokyo
Joined Jan 2010
I had the gyro on, but better to get a second opinion before setting off a fire sale.
Might be the same problem described in this thread, http://www.rcgroups.com/forums/showthread.php?t=1562262 ?
bytemuncher is offline Find More Posts by bytemuncher
Old Jan 05, 2012, 10:09 AM
benmlee is offline
Find More Posts by benmlee
Los Angeles
Joined Oct 2006
Originally Posted by f.a.r.m.e.r View Post
Lol damo666 you have a great sense of humar
Heres my vid on how to bullet proof your stock walkera genius cp servos with an easy to do internal servo saver mod. That I so far have more flights then I can count on theses servos never stripped a gear again or burnt the pot from over extending the arms since :thumbup:
http://www.youtube.com/watch?v=hUmii...e_gdata_player
I really hope it can help yall to because servos are expensive lol
If my video confuses you and you need help with the mod pm me or post it here
Ill try to reply asap :thumbup:
Farmer Pickle
I am surprised the mod actually worked. Usually, is the inertia of the drivetrain that breaks the gear.
At moment of impact, the drivetrain cannot react fast enough, so something has to give, and is the gears.
On mine, the failure mode of the gear teeth is in tooth bending instead of wear. Lubricant would not have done
much good.
However, there can be other factors at work here. Curious if it actually fix the breakage problem. It would be great if it does.
benmlee is offline Find More Posts by benmlee
Old Jan 05, 2012, 10:44 AM
Heli collector
Joined Apr 2009
much good.
Actually you will run into at least two problems with these stock servos,, first the usual stripped/bent tooth if you are lucky it's on the last gear and you can rotate this one 180 degrees and get one more crash out of them. Or 120 degrees and get two more. Most of the time I find that it's a inner gear and you are out of luck,, but save the parts for a later mix and match.. The other problem is that the last gear also drives the shaft that turns the wiper on the pot. This shaft is driven by a brass insert in the plastic gear, this insert on some servos is NOT held to the gear very well and will slip, when it slips the gear/arm is moving to the end of it's travel and jamming because the shaft turning the wiper on the pot isn't turning due to the insert slipping. So the servo doesn't know that the arm has moved and is now jammed and is still trying to move it,,, this burns out the motor if allowed to go on very long..
Some of you have noticed this happening and have moved the arm back down to center by hand and the servo will work again for awhile till it happens again.. Sometimes I think the RX sort of fixes this it's self in flight by noticing that the heli is now going to far and correcting/changing the direction of the servo and things go back to normal for awhile. But this will start to happen more and more often.. Till the heli is unflyable... Here is where you start mixing and matching parts to get one good servo out of the two bad ones..
Old Jan 05, 2012, 02:08 PM
benmlee is offline
Los Angeles
Joined Oct 2006
Little bit of hot glue to fix this one maybe. Do it before it becomes a problem.
Old Jan 05, 2012, 05:02 PM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
servos are fine for GCP but do have mod them.
Problem is as farmer said pwm from rx is inverted. I used 2N7002 does the trick but swapping motor and pot wires around lot nicer if your happy with soldering that small area.
I will add when i swapped wires around 2 had red wires from centre of pot but one was all black.
SadSack is offline Find More Posts by SadSack
Old Jan 05, 2012, 05:24 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
What is up with the stock battery connector? Is it like just a walkera type plug?
I plan on changing them to a standard JST plug. I know people dislike this plug and
I don't know why? I have them on my trex250 and they never get hot also all my chargers already have this plug.
mhills51 is offline Find More Posts by mhills51
Old Jan 05, 2012, 05:25 PM
RawmadeCF is offline
Find More Posts by RawmadeCF
Perpetually covered in resin
RawmadeCF's Avatar
United States, NV, Las Vegas
Joined Dec 2011
They are just standard walkera connectors for their small helis. I use micro deans.
RawmadeCF is offline Find More Posts by RawmadeCF
Old Jan 05, 2012, 07:06 PM
Tokyo
Joined Jan 2010
I was aware that was an issue with the HK-5320's, but thought the hk-282a's were supposed to be somewhat plug-in-play-ish...just requiring the negative and signal wire to be swapped on the outside and not requiring internal rewiring/soldering.
Old Jan 05, 2012, 07:08 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
If it is backwards it should be just a mater of reversing that servo.
Old Jan 05, 2012, 07:09 PM
Tokyo
Joined Jan 2010
I like micro deans too but the other day I absentmindedly plugged a hyperion into a hyperion thinking I had my voltage meter in one hand. Terminals on one bat burnt right through the electrical tape in milliseconds, but both seem to be working fine now. For Darwin award candidates like myself a male/female connector setup might be safer
Old Jan 05, 2012, 07:10 PM
RawmadeCF's Avatar
Joined Dec 2011
Not that easy unfortunately.
Old Jan 05, 2012, 07:19 PM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
Helifreak G CP servo options
There is a thread started on HeliFreak about servo options if that would help anyone out.
http://helifreak.com/showthread.php?t=369137
shastamike is offline Find More Posts by shastamike
Old Jan 05, 2012, 10:54 PM
englanito is offline
Find More Posts by englanito
addicted to the sound ehhhhhhh
Joined Dec 2011
I'm a noob here and found this is this a mod or a stock part for the gcp?
http://www.wowhobbies.com/hm-geniusc...verholder.aspx
englanito is offline Find More Posts by englanito
Old Jan 05, 2012, 11:49 PM
pmerritt is online now
Find More Posts by pmerritt
Joined Oct 2010
stock part
pmerritt is online now Find More Posts by pmerritt
Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX Tom Z Micro Helis 561 Oct 17, 2015 01:50 AM
For Sale Walkera rtf genius cp with devo 8 nib 200.00 shipped (scam?) Hot_Wheels Aircraft - Electric - Helis (FS/W) 46 Oct 16, 2011 05:08 AM
Help! need help on how to press on the stock genius cp pinion onto C05 bl motor f.a.r.m.e.r Micro Helis 12 Oct 13, 2011 10:20 AM
Sold Walkera rtf genius cp with devo 8 nib 200.00 shipped Lbzracing909 Aircraft - Electric - Helis (FS/W) 0 Sep 30, 2011 08:19 PM
Sold Walkera Devo7 with rtf Genius cp.... magic_marty Aircraft - Electric - Helis (FS/W) 1 Sep 23, 2011 12:10 AM
