Old Jan 04, 2012, 05:42 AM
Palle_Plutt is offline
Find More Posts by Palle_Plutt
Kingdom of Sweden, Västra Götaland County, Lindome
Joined Jul 2011
Originally Posted by f.a.r.m.e.r View Post
Lol damo666 you have a great sense of humar
Heres my vid on how to bullet proof your stock walkera genius cp servos with an easy to do internal servo saver mod. That I so far have more flights then I can count on theses servos never stripped a gear again or burnt the pot from over extending the arms since :thumbup:
http://www.youtube.com/watch?v=hUmii...e_gdata_player
I really hope it can help yall to because servos are expensive lol
If my video confuses you and you need help with the mod pm me or post it here
Ill try to reply asap :thumbup:
Farmer Pickle
Hi Farmer
The video is missing what you actually did with the servo.
That part was out of picture the hole time.
Regards
Palle_Plutt is offline Find More Posts by Palle_Plutt
Old Jan 04, 2012, 07:42 AM
OnceAFly is offline
Find More Posts by OnceAFly
OnceAFly's Avatar
Singapore, Singapore
Joined Oct 2011
Hey Dave nice one on the video it real funny lol
OnceAFly is offline Find More Posts by OnceAFly
Old Jan 04, 2012, 08:06 AM
OnceAFly is offline
OnceAFly's Avatar
Joined Oct 2011
Look like walkera have the Devo 8S on their website and you can't just upgrade only software but hardware needed too...why can't they just do a complete set then roll it out once and for all?? Do they really need to make this way for more $_$ And what about devo6? If i were to know they will update the devo 8 or12 but left out the 6, I wouldn't even consider the devo 6 in the first place...this really make the stores to throw out devo 6 i suppose.
Old Jan 04, 2012, 08:22 AM
f.a.r.m.e.r is offline
Find More Posts by f.a.r.m.e.r
Farmer
f.a.r.m.e.r's Avatar
United States, CA, San Mateo
Joined Oct 2011
Originally Posted by Palle_Plutt View Post
Hi Farmer
Regards
Yeah I just realized that, i'll make a new video using a tripod rather then my hat cam and it should work fine
Sorry bout not being able to see it, my new one should be fine the the camera on a tripod looking straight down at the table.
Regards
Farmer
f.a.r.m.e.r is offline Find More Posts by f.a.r.m.e.r
Old Jan 04, 2012, 08:27 AM
Farmer
Joined Oct 2011
I know right I should stop using the hat cam for these type of videos, but it works great when flying
Did you atleast see how tough the servo is now I was yanking and slapping the servo horn like it owes me money and it still didnt strip out
Try that with a stock servo **"click click pop"** is what would happen lol
Farmer
Old Jan 04, 2012, 08:40 AM
Farmer
Joined Oct 2011
Originally Posted by shastamike View Post
I had some down time yesterday and tried to install my mCPX main motor. Bought gear puller and stock gear came right off. Went to put the pinion on the mCPX motor and had one of a time. Tried pressing, heating the pinion, wound up hammering the pinion on. Bent the shaft of course, blew out the back of the motor. Only good thing was that the motor was less than $10.
How would one successfully get the pinion on?
Will the mCPX work OK with stock batteries?
Otherwise it was really nice to get the stock motor back together and fly finally last night.
Mike this video might help you for when you install another pinion, its my way of doing it and its quick easy to do. Never have issues this way of removing and re-installing
Hope it helps mike
Farmer
http://www.youtube.com/watch?v=biKCG...e_gdata_player
Old Jan 04, 2012, 08:41 AM
climo is offline
Find More Posts by climo
Philippines, NCR, Marikina City
Joined Mar 2003
Is this a new Devo 12S?
http://www.oomodel.com/walkera-devo-...1-p-62125.html
climo is offline Find More Posts by climo
Old Jan 04, 2012, 08:46 AM
deux_18 is offline
Find More Posts by deux_18
United States, CA
Joined Nov 2011
Regards
Farmer
Can't wait till you get that new video out!
deux_18 is offline Find More Posts by deux_18
Old Jan 04, 2012, 08:52 AM
deux_18 is offline
United States, CA
Joined Nov 2011
Hope it helps mike
Farmer
Very nice!
Old Jan 04, 2012, 09:07 AM
Farmer
Joined Oct 2011
me to Otherwise they will laugh and pick on me all day
it was kinda funny like I was hiding something top secret and can't fall into the wrong hands LOL
Farmer
Old Jan 04, 2012, 09:09 AM
Farmer
Joined Oct 2011
Originally Posted by txipicopter View Post
Ok... Lo intentaré.
¿Que piñón usa con el motor mcpX?
¿Que es GCP 9t?... ¿El original de el genius?...
Yo tenía vibraciones y no era capaz de volar en invertido, solo vuelo normal con mucha dificultad.
en mi mcpx estoy
usando el stock de 9
dientes del piñón, el
motor de un genio. la
malla de los dientes
tiene que ser perfecto,
o que va a vibrar como
un loco, también lo que
las baterías están
usando? porque no va a
funcionar con una
batería de valores, la
velocidad de la cabeza
sería demasiado bajo.
si instalar me muestra
un video de lo que está
haciendo de esa
manera será más fácil
para mí para tratar de
diagnosticar el
problema Estoy seguro
de que puede conseguir
que va a la derecha
tenemos que encontrar
la fuente de la primera
vibración. por lo que si
no te importa cuando
se instala el motor
después de un video de
lo que habla de lo que
tal vez alguien aquí para
ver lo que está pasando
en este continente una
vibración Espero que
esto ayude amigo
agricultor
Farmer
Old Jan 04, 2012, 09:37 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Farmer
I watched the whole video and than sat here going what the heck did he do?? I don't have a clue other than he was working the servos back and forth..
Glad I'm not the only one kept in the dark about this secret of yours..
I need to make a how to do video today,, so the don't do it this way video of yours was a great help because I was going to do it with the hat camera also,,, Looking forward to the tripod video..
livonia bob is offline Find More Posts by livonia bob
Old Jan 04, 2012, 10:14 AM
Hellraser is offline
Find More Posts by Hellraser
Hellraser's Avatar
UK
Joined Jul 2007
Farmer
You think a new video will stop that
Regards David
Hellraser is offline Find More Posts by Hellraser
Old Jan 04, 2012, 10:17 AM
Hellraser's Avatar
UK
Joined Jul 2007
Originally Posted by climo View Post
Yes like the 8 the 12 has been updated to 12S nice gray gunmetal case
seems like the key feature is feedback to Tx with low voltage warnings and temp etc
Regards David
Old Jan 04, 2012, 10:37 AM
Heli collector
Joined Apr 2009
Regards David
But is this going to be only for the standalone RX's or are the little heli's going to have this built into the RX now also??
Will I need to get a forth Genius,, so a sweet female voice says nicely to me "Bob it's time to land now battery is low", or "Bob please land before you crash again".. Or "Bob the heli refuses to take off,,, it's scared to death you are going to kill it"..
Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX Tom Z Micro Helis 561 Oct 17, 2015 01:50 AM
For Sale Walkera rtf genius cp with devo 8 nib 200.00 shipped (scam?) Hot_Wheels Aircraft - Electric - Helis (FS/W) 46 Oct 16, 2011 05:08 AM
Help! need help on how to press on the stock genius cp pinion onto C05 bl motor f.a.r.m.e.r Micro Helis 12 Oct 13, 2011 10:20 AM
Sold Walkera rtf genius cp with devo 8 nib 200.00 shipped Lbzracing909 Aircraft - Electric - Helis (FS/W) 0 Sep 30, 2011 08:19 PM
Sold Walkera Devo7 with rtf Genius cp.... magic_marty Aircraft - Electric - Helis (FS/W) 1 Sep 23, 2011 12:10 AM
