United States, KY, Springfield
Joined Jul 2011
I tried using subtrim, and it starts ok, but by the time the battery is done, I have to hold right rudder to keep it straight. I don't know what to do.... Is there someone out there that has dealt with this using their 2801tx that can show me the settings (I feel like a dolt!) I'm wondering if I replaced the tail rotor with the one from my CB100 if that would be better, but somehow, I don't think that would help.
Joined Nov 2011
I've used the progmix to do it, see the photos. The curve is 0 for the first point, -9 for the rest - you may have to fiddle with the actual value a bit. This is the same method as the post above, but on the 2801.
There's a description of what this actually does somewhere in the main genius thread. If you want to confirm the effect, set it to 'SW: GEAR', so you can enable/disable it with the gear switch. Just make sure your throttle is at 0 when you turn on the receiver. |
is the 10A-LT ESC programmable?
Latest blog entry: Estes Rubber Band Condor gets powered...
that sucks
thanks Mine has a weird start up. It beep and heli initalizes as it should, BUT when I move throttle imput, the motor doesnt start; esc beeps, I then move throttle to lowest setting and then its fine. |
Joined Jun 2011
To be clear, it beeps when I plug in the battery. Then it beeps again when I use the throttle, and finally it fires up. It's been like that since I installed it. I figured it was normal. I'm used to it now. I bind the heli, I give a quick throttle input, back to 0% throttle, wait for the beep, and off I go. Best, Chris |
| Thread Tools | |
| Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX | Tom Z | Micro Helis | 471 | Apr 26, 2013 05:05 PM |
| For Sale Walkera rtf genius cp with devo 8 nib 200.00 shipped (scam?) | Hot_Wheels | Aircraft - Electric - Helis (FS/W) | 46 | Oct 16, 2011 05:08 AM |
| Help! need help on how to press on the stock genius cp pinion onto C05 bl motor | f.a.r.m.e.r | Micro Helis | 12 | Oct 13, 2011 10:20 AM |
| Sold Walkera rtf genius cp with devo 8 nib 200.00 shipped | Lbzracing909 | Aircraft - Electric - Helis (FS/W) | 0 | Sep 30, 2011 08:19 PM |
| Sold Walkera Devo7 with rtf Genius cp.... | magic_marty | Aircraft - Electric - Helis (FS/W) | 1 | Sep 23, 2011 12:10 AM |
