Old Oct 20, 2011, 11:08 PM
f.a.r.m.e.r is offline
Find More Posts by f.a.r.m.e.r
Farmer
f.a.r.m.e.r's Avatar
United States, CA
Joined Oct 2011
Originally Posted by Hellraser View Post
Thanks I ave a C05 I am thinking of using just wondering what pinion to use - wondered if a 7T would work without too much cogging - wit a 6K headspeed haws the stock tail holding up ?
Regards David
im using the mcpx v2 tail blade my boom is extended/strectched 1/2 inch tail holds great so far. plenty of hold for my flying capability lol.
f.a.r.m.e.r is offline Find More Posts by f.a.r.m.e.r
Old Oct 21, 2011, 01:59 AM
Farmer
United States, CA
Joined Oct 2011
Originally Posted by vronny View Post
So you used the same CB100 ESC of course it feels lighter it only is 3g with much higher HS 15800kv compare to 11500kv. No problem installing in frame. I was waiting on HP05-2 13500kv but this has more power
but a larger motor shaft 1.5mm. So where did you get the gear?
I used the helimax brushless tail speed control/converter, was easier to get from local shops here lol
Old Oct 21, 2011, 07:59 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Originally Posted by f.a.r.m.e.r View Post
iv never ordered from them im going to give them a try
@livonia bob what you running on your heli?
Right now a AEO 0-3 7500KV with the stock 9t pinion. Remember I'm not after high head speed I want torque so I can run less head RPM and more pitch to get long flight time and light weight...
So don't use what I use if you are looking for 3D flight..
livonia bob is offline Find More Posts by livonia bob
Old Oct 21, 2011, 11:01 AM
Picofly is offline
Find More Posts by Picofly
Blade 180 FPV & Mini-Protos
Picofly's Avatar
Helsinki, Finland
I have a HP03S and the brushless converter waiting for the brushless conversion but I bought 0.4 MOD pinion by mistake because somebody in RCGroups claimed that the pinion should be 0.4 MOD. Well, it was 0.5 Mod instead...
What is the best place to find 7T and 8T pinions in 0.5 MOD? Most of the wendors seem to sell only 0.3 Mod pinions for 1.5mm shaft. I have sent an order to Homefly a couple of days ago but so far they haven't sent any confirmation back.
Picofly is offline Find More Posts by Picofly
Old Oct 21, 2011, 02:34 PM
vronny is offline
Find More Posts by vronny
los angeles,ca
Joined May 2010
What is the best place to find 7T and 8T pinions in 0.5 MOD? Most of the wendors seem to sellonly 0.3 Mod pinions for 1.5mm shaft. I have sent an order to Homefly a couple of days ago but so far they haven't sent any confirmation back.
Just receive my gears today from Homefly. There is not a phone # on my invoice.
vronny is offline Find More Posts by vronny
Old Oct 21, 2011, 04:21 PM
Farmer
United States, CA
Joined Oct 2011
my current head speed is 5846 at zero pitch 100% throttle with stock battery and 7t pinion. its great for outside flying, but if your flying indoor the pop you get from positive to negative transitions is nasty with out running a S curve expo on pitch. I hit the walls many times lol
Old Oct 21, 2011, 06:21 PM
Heli collector
Joined Apr 2009
I took mine to the field again today to fly in the wind... Nice and stable,, came home and ordered another one..
Old Oct 22, 2011, 01:40 AM
benmlee is offline
Find More Posts by benmlee
Los Angeles
Joined Oct 2006
I will second that. Have a bunch of .5 mod gears from mini-z racing, and they seem to match up perfectly. Unfortunately, those gears are for 2mm shaft.
However, PN Racing does sell .5 mod delrin gears that have a 2mm bore on one end and 1.43mm bore on the other end. The 1.43mm bore is about 3mm deep. So if you put the 1.43mm bore on the motor, it might work. You may have to cut off the solid part of it. Is only $2.44 for a set of 4 if it doesn't work. Don't have a brushless motor yet, so can't tell you if it will work.
Here it is:
http://www.kenonhobby.com/PN-Racing-...T_p_43055.html
Kenon hobbies is a good shop. Go racing there all the time. Quick shipping.
While you are there, I highly recommend the Kyosho flourine oil. Is expensive, but there is nothing like it for lubrication on plastic parts and gears.
benmlee is offline Find More Posts by benmlee
Old Oct 22, 2011, 02:32 AM
Picofly is offline
Picofly's Avatar
Helsinki, Finland
Here it is:
Thank you for the link! I may give it a try.
I found this vendor from another thread. A little bit pricey but maybe these will work as well:
http://www.shop.kkpmo.com/index.php/...ls-Pinion.html
EDIT: I noticed the following message on www.homefly.com: "I'll be on vacation Oct. 21 through Oct. 24". That explains why I didn't got response form the shop...
Old Oct 26, 2011, 01:34 PM
Picofly is offline
Picofly's Avatar
Helsinki, Finland
I received a mod 0.5 7T pinion from Microantreibe.
Homefly shop owner returned from his holidays and told that he has shipped me a pinion yesterday so I will have some spares soon...
Here is a my Genius BL after the first test flights. Motor is a 14000 kV version of HP03S. AUW is 42.1g including the stock 200mAh battery.
I was positively surprised about the noise level. I was expecting to get a noisy heli but it is just as silent as it was in the stock form!
I am really happy with this setup. My Genius is extremely enjoyable heli now!!!
Old Oct 26, 2011, 06:08 PM
Farmer
United States, CA
Joined Oct 2011
Have you tried the g3 hyperian battery yet? Thats what im using with my hp03s
Regards
Dave
Old Oct 26, 2011, 11:47 PM
Picofly is offline
Picofly's Avatar
Helsinki, Finland
It really wakes up that motor
Dave
Not yet.
I have some 24 mAh Hyperions on the way. They should arrive next week. Motor bogs a little bit with the stock batteries but it is still much better than the original setup.
I really like the Microantriebe pinion. It was worth of the higher premium. Shape of the teeth is 100% perfect and my heli is actually more silent than what it was before. That is amazing!
Old Oct 26, 2011, 11:54 PM
Farmer
United States, CA
Joined Oct 2011
awsome
Not yet.
yeah mine vibrates a little more then i want it to. how much are those pinions and do you have a link i would love to give them a try
so how do you like your genius overal?
i put my mcpx away the genius is just so much fun to fly
Old Oct 27, 2011, 01:53 AM
Picofly is offline
Picofly's Avatar
Helsinki, Finland
I love my Genius!
It is the best sub-micro I have owned. It is amazing how quickly these micro Walkeras have developed in four years time! I bought a mcpx last spring but it was kind of dissappointment. The heli was really tuff but but I sold it away because it was so underpowered and tail didn't hold in flips.
Here is link to the Microantriebe shop: http://www.shop.kkpmo.com/index.php/...ls-Pinion.html
Old Oct 27, 2011, 08:18 AM
Air Vaca is offline
Find More Posts by Air Vaca
Air Vaca's Avatar
Arivaca,Arizona
Joined May 2008
pricey, but top shelf stuff
Air Vaca is offline Find More Posts by Air Vaca
Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX Tom Z Micro Helis 561 Oct 17, 2015 01:50 AM
For Sale Walkera rtf genius cp with devo 8 nib 200.00 shipped (scam?) Hot_Wheels Aircraft - Electric - Helis (FS/W) 46 Oct 16, 2011 05:08 AM
Help! need help on how to press on the stock genius cp pinion onto C05 bl motor f.a.r.m.e.r Micro Helis 12 Oct 13, 2011 10:20 AM
Sold Walkera rtf genius cp with devo 8 nib 200.00 shipped Lbzracing909 Aircraft - Electric - Helis (FS/W) 0 Sep 30, 2011 08:19 PM
Sold Walkera Devo7 with rtf Genius cp.... magic_marty Aircraft - Electric - Helis (FS/W) 1 Sep 23, 2011 12:10 AM
