Old Apr 30, 2012, 09:13 AM
Dave O is offline
Find More Posts by Dave O
United States, NJ, Evesham Township
Joined Oct 2011
Bob,
Thanks. I ran into bobepine's thread on building a tray and all the rest. My helipad is laying in the grass, and not level at all. Probably not the best for gyro initialization. However it's not an issue in 3-axis. I'll look at the RX position and try on a level surface.
Dave O is offline Find More Posts by Dave O
Old Apr 30, 2012, 09:14 AM
Dave O is offline
Joined Oct 2011
Originally Posted by livonia bob View Post
As you don't seem to want to even read about it. Most of use only did it for the challenge of getting it to work right... Then yes stick with the 3 axis as you seem able to fly it as is..
No, I did some reading, I just didn't know what to search for. Thanks for the link.
Old May 16, 2012, 10:39 AM
pmerritt is online now
Find More Posts by pmerritt
Joined Oct 2010
For Sale
My Brushless Genius CP with no slop head mod.
it has a new c05 and new servos, it flies great.
why am i selling it?
i purchased a devo10 and i'm switching everything over to it.
i already have a 500, 450 (getting new rcvrs for em), V120D02s, and miniCP.
Can't see myself paying 70.00 for a devo rcvr for the Genius.
asking 175.00 that includes the 2801pro a few spares and 3 hyperion batteries with micro deans already soldered on. pm me for serious inquiries only.
SOLD
pmerritt is online now Find More Posts by pmerritt
Old May 20, 2012, 12:55 PM
FoamAddict is offline
Find More Posts by FoamAddict
Joined Dec 2010
Can the Genius cp with a C05 tick toc?? Or do I need an hp05?
FoamAddict is offline Find More Posts by FoamAddict
Old May 22, 2012, 03:26 PM
rldeveer is offline
Find More Posts by rldeveer
rldeveer's Avatar
Big Island of Hawaii
Joined Jan 2011
Orange servo question
I have modified one of my GCPs to a mini using the mech dog leg mod, as playing with small servos is not my thing. I have 3 orange 282A servos that couldn't be used on the GCP without being modified.
Question: Could the 282A be used for the pitch servo when doing the GCP to MiniGCP mod? Two wrongs = right sort of thing.
Will still need to change the connector leads on the servo but won't have to go inside of it. I can't remember which ones to change and don't want to fry anything.
RD
Update:
(Swapped orange and brown) Electricly it worked fine, it just will not fit in a Mini CP frame. The mech mod works fine just wanted to find a use for the 282As.
rldeveer is offline Find More Posts by rldeveer
Old May 23, 2012, 12:23 AM
paul2pilot is offline
Find More Posts by paul2pilot
paul2pilot's Avatar
Huntington Beach, CA
Joined Jan 2011
I'm a novice at 3d, but if the tick tock is wide enough (like a short rainbow), you can do several without too much bogging. If you try really rapid tight (near vertical) tick tocks, the motor will bog down and you have to recover after only a few cycles.
paul2pilot is offline Find More Posts by paul2pilot
Old May 27, 2012, 02:25 PM
RM3Studios is offline
Find More Posts by RM3Studios
RM3Studios's Avatar
Joined Jun 2011
After doing the c05 upgrade I have a bounce (up & down) in the tail. Sometimes I get a small fast wag. I turned the gyro down a little, lowered my pitch and head speed. I also have an extended boom installed to try to help with the blow out on pitch pumps, but it doesnt do much . Im finding I cant fly with the canopy on because it goes crazy. It will do it without the canopy sometimes too.
What should the max pitch, gyro & throttle be with the c05 set-up (don't know if there is a universal sweet spot to help some of the issues)? Also why would the tail bounce? It flies great when it flies correctly, but when you plug in the battery, you never know what youre gonna get until youre in the air
RM3Studios is offline Find More Posts by RM3Studios
Old May 27, 2012, 04:09 PM
magic_marty is offline
Find More Posts by magic_marty
<Marty>
United States, KY, Springfield
Joined Jul 2011
check the front elevator servo and make sure its not stripped...if there is a gear inside with a tooth missing it will cause the servo to jump which could be whats causing the tail to bob up and down...
magic_marty is offline Find More Posts by magic_marty
Old Jun 03, 2012, 03:30 PM
ginoroberti is offline
Find More Posts by ginoroberti
Joined May 2012
hello im new to this. managed to break my landing gear in a matter of 10 minutes on my genius. does anybody know of different skids i can use. attach with double sides tape.
ginoroberti is offline Find More Posts by ginoroberti
Old Jun 03, 2012, 10:06 PM
paul2pilot's Avatar
Joined Jan 2011
Hot glue works well if you want to just glue the existing skids back on place.
Old Jun 04, 2012, 07:44 AM
Crash Survivor is offline
Find More Posts by Crash Survivor
Heli Crash Survivor
Crash Survivor's Avatar
United States, AR, North Little Rock
Joined Feb 2011
I just buy a new frame & use the mod below, just on the front skids though. Seems to hold up pretty well.
http://benmlee.com/Genius_Landing_Gear.htm
Crash Survivor is offline Find More Posts by Crash Survivor
Old Jun 23, 2012, 05:54 PM
Newbheli is offline
Find More Posts by Newbheli
Grenoble, France
Joined Jan 2010
Hello,
This frame mod looks good, my own version of it is to use some CB100 landing gears maintained with heat shrink tube.
Newbheli is offline Find More Posts by Newbheli
Old Aug 15, 2012, 07:43 PM
bobfa is offline
Find More Posts by bobfa
bobfa's Avatar
United States, TX, Cypress
Joined Jan 2012
Originally Posted by f.a.r.m.e.r View Post
Hey Chris before you go drilling holes in your skids check out my glueless version of rldeever's mod.
It is really simple to do and all I used was spare genius cp parts, i'm not a big fan of using glue on plastic. plus I wanted to be able to take it off and put it on to another heli if I had to with ease.
Glad he came up with this mod, other wise I wouldnt even thought about it doing it.
Thanks again rldeever
Bestest Regards
Dave
Good mod, looks good and functional. Lucky I had the stuff laying around.
bobfa is offline Find More Posts by bobfa
Old Aug 15, 2012, 10:38 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Wow took mine out today for the first time in six months. With the nice weather I have been too busy flying my 500's and crashing my 450. Went to plug in the battery and finally my power wires broke.
mhills51 is offline Find More Posts by mhills51
Old Oct 13, 2012, 06:29 PM
randyrogerslife3 is offline
Find More Posts by randyrogerslife3
Joined Oct 2012
hi are you selling the rx for your mini genuis cp devo7 i will buy your rx for the heli if itworkingyou can reach me at 7189287187 thank you somuch
randyrogerslife3 is offline Find More Posts by randyrogerslife3
Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX Tom Z Micro Helis 561 Oct 17, 2015 01:50 AM
For Sale Walkera rtf genius cp with devo 8 nib 200.00 shipped (scam?) Hot_Wheels Aircraft - Electric - Helis (FS/W) 46 Oct 16, 2011 05:08 AM
Help! need help on how to press on the stock genius cp pinion onto C05 bl motor f.a.r.m.e.r Micro Helis 12 Oct 13, 2011 10:20 AM
Sold Walkera rtf genius cp with devo 8 nib 200.00 shipped Lbzracing909 Aircraft - Electric - Helis (FS/W) 0 Sep 30, 2011 08:19 PM
Sold Walkera Devo7 with rtf Genius cp.... magic_marty Aircraft - Electric - Helis (FS/W) 1 Sep 23, 2011 12:10 AM
