Old Nov 05, 2011, 05:55 AM
vronny is offline
Find More Posts by vronny
los angeles,ca
Joined May 2010
Originally Posted by f.a.r.m.e.r View Post
chris that should work fine, im using an old yanked out motor shaft to balance mine
and thanks Chris
seems I am having to much time in my hands gf is out of town
So which motor are you using C05 or HP03S? I'm still using the V3 & solo pro TBs. I tried the v100d03 motor alot of power need different pinion for that to work maybe to powerful for tail motor. Its like using the stock motor in the M120 compared to the TA 215.
vronny is offline Find More Posts by vronny
Old Nov 05, 2011, 07:28 AM
f.a.r.m.e.r is offline
Find More Posts by f.a.r.m.e.r
Farmer
f.a.r.m.e.r's Avatar
United States, CA, San Mateo
Joined Oct 2011
im flying the C05 with 9t pinion and the hp03s with 7t pinion, tried the modded stock tail blade and still no blow out so far,
if you look at the vid I did a full inverted positive pitch drop toward the ground into a full negative pitch pump before it hit the ground with no tail blow out, I tried that with the mcpx v3 blade stock blade solopro blade they all blew out hard.
because they bog the tail motor.
they have alot of static thrust but it takes to long to react to the torque produced during hard pitch pumps.
the modded stock blade is lighter with less pitch but reacts much quicker. finless bob mentioned in his review video that the stock tail blade was bogging down the tail motor because of so much surface area on the stock tail blade, thats what got me thinking on modding the tail blade, but I cut about 17+ stock tail blades before I got it right.
I havnt tried the v100d03b motor yet I might have to purchase one and try it
but all in all im happy with this mod
dave
f.a.r.m.e.r is offline Find More Posts by f.a.r.m.e.r
Old Nov 05, 2011, 07:54 AM
OnceAFly is offline
Find More Posts by OnceAFly
OnceAFly's Avatar
Singapore, Singapore
Joined Oct 2011
Guys i need help on the C05 brushless motor have 3 wire all black, how am i going to know which wire go where?
OnceAFly is offline Find More Posts by OnceAFly
Old Nov 05, 2011, 08:29 AM
Rafa's CB100 is offline
Find More Posts by Rafa's CB100
Live to learn. . .
Rafa's CB100's Avatar
Austin, TX
Joined Dec 2009
Just solder them any which way. If the motor spins backwards, switch two of the wires, that will make it spin the other way.
Rafa
Rafa's CB100 is offline Find More Posts by Rafa's CB100
vronny is offline
los angeles,ca
Joined May 2010
Just have to either use a plug solder to ESC check to see which direction motor if wrong switch any 2 wires if using plug flip over on other side.
Old Nov 05, 2011, 08:30 AM
Live to learn. . .
Austin, TX
Joined Dec 2009
Ha!
Old Nov 05, 2011, 08:38 AM
vronny is offline
los angeles,ca
Joined May 2010
dave
Hay I'm just a sport flier so I don't get the tail blow out like mcpx did but will check out since I have some stock TBs laying around.
Old Nov 05, 2011, 08:41 AM
OnceAFly is offline
OnceAFly's Avatar
Joined Oct 2011
Thanks guys i will try it.
Old Nov 05, 2011, 08:45 AM
OnceAFly is offline
OnceAFly's Avatar
Joined Oct 2011
Anyone here using devo tx? I have devo 6 but it never come with the pc linking cable. Any idea how to make one?
Old Nov 05, 2011, 09:04 AM
pmerritt is online now
Find More Posts by pmerritt
Joined Oct 2010
you can get that cable from any computer store....it's a mini usb to standard usb.
pmerritt is online now Find More Posts by pmerritt
Old Nov 05, 2011, 09:20 AM
OnceAFly is offline
OnceAFly's Avatar
Joined Oct 2011
Ok it on the right side i just saw it and i have the cable for it thanks.
Old Nov 05, 2011, 09:23 AM
vronny is offline
los angeles,ca
Joined May 2010
Originally Posted by Rafa's CB100 View Post
Ha!
Say Rafa did you get a big heli how is it going?
Old Nov 05, 2011, 02:03 PM
Farmer
Joined Oct 2011
I sport fly alot to, actually I wish someone would make a scale fuslage to fit the genius cp that would be awsome kinda like the V120D02Q coastgaurd one.
btw if you try it out the mod to add a little washout to the tips of the tailblade and that they are tracking right or it will vibe like crazy
Dave
Old Nov 05, 2011, 02:14 PM
Farmer
Joined Oct 2011
Originally Posted by magic_marty View Post
lol....wow the thread is dead, everybody must be cutting and sanding on there tail rotors...lol
lmao
just read your other post, the trex 100 blade starts slipping on the motor shaft on me, must be the hard plastic.
it also has to much pitch so you would have to cut down the trailing edge. it has the shape of a tractor style prop rather then a pusher prop, plus its a bit heavy
best of luck
Dave
Old Nov 05, 2011, 02:25 PM
Farmer
Joined Oct 2011
try this with a V3 mcpx tail blade or any tail blade
walkera genius cp inverted tail blow out test (1 min 20 sec)
Dave
Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX Tom Z Micro Helis 561 Oct 17, 2015 01:50 AM
For Sale Walkera rtf genius cp with devo 8 nib 200.00 shipped (scam?) Hot_Wheels Aircraft - Electric - Helis (FS/W) 46 Oct 16, 2011 05:08 AM
Help! need help on how to press on the stock genius cp pinion onto C05 bl motor f.a.r.m.e.r Micro Helis 12 Oct 13, 2011 10:20 AM
Sold Walkera rtf genius cp with devo 8 nib 200.00 shipped Lbzracing909 Aircraft - Electric - Helis (FS/W) 0 Sep 30, 2011 08:19 PM
Sold Walkera Devo7 with rtf Genius cp.... magic_marty Aircraft - Electric - Helis (FS/W) 1 Sep 23, 2011 12:10 AM
