Old Nov 04, 2011, 05:23 PM
buster7467 is offline
Find More Posts by buster7467
morgantown, wv
Joined Mar 2004
Cool. I see in the other genius thread you say you run 80 in your pitch. That's crazy that the tail will hold with that much pitch. I set my genius up to have exactly 0 pitch at center stick. I use in-scents and wave it over and under the rotor disk and you can see if it is blowing the smoke up or down. I am only able to run 69 in my pitch or i get tail blowout with the modded tail blade that i have. I would love to run just a little more pitch in the main blades because even going up to 73 it has some nice pop to it that it just don't have at the lower 69 that i run. Cant wait to see your vid on how you modded the prop. And i wonder if it will allow the tail motor to last even longer or if it will hurt the lifespan of the tail motor.
buster7467 is offline Find More Posts by buster7467
Old Nov 04, 2011, 06:46 PM
f.a.r.m.e.r is offline
Find More Posts by f.a.r.m.e.r
Farmer
f.a.r.m.e.r's Avatar
United States, CA
Joined Oct 2011
motor isnt working as hard with this new mod so im sure it will last longer.
ok posting vid
f.a.r.m.e.r is offline Find More Posts by f.a.r.m.e.r
Old Nov 04, 2011, 06:47 PM
Farmer
United States, CA
Joined Oct 2011
how to mod the stock tail blade video
https://www.youtube.com/watch?v=LkG5...e_gdata_player
best of luck
dave
Old Nov 04, 2011, 06:50 PM
Hellraser is offline
Find More Posts by Hellraser
Hellraser's Avatar
UK
Joined Jul 2007
ok posting vid
Nice work and very impressive tail holding - hope walkera are listening it seems like E-Flight Nine eagles and your self have all made a better job of tail rotor design
Regards David
Hellraser is offline Find More Posts by Hellraser
Old Nov 04, 2011, 06:57 PM
morgantown, wv
Joined Mar 2004
Thanks, i will give it a try soon and let you know how it works.
Old Nov 04, 2011, 07:22 PM
Farmer
United States, CA
Joined Oct 2011
Regards David
hey thanks david, I hope you try it out when your tail holds really well it gives you more confidence in trying new things when your flying. the key to getting the tail to hold is high rpm lighter blade with less pitch. kinda how a faster tail servo works.
static thrust had no play in it e-flight obviously knows this because of the design of the V3 mpcx blade which is paper thin light wieght so the motor can react quicker
and yeah buster let me know how it works for ya
best if luck
dave
Old Nov 04, 2011, 07:29 PM
magic_marty is online now
Find More Posts by magic_marty
<Marty>
United States, KY, Springfield
Joined Jul 2011
so it appears how this works is by sharpening the leading and trailing edges on the blade...making it slice thru the air better reducing the drag which allows it to move more air ....plus shortening it reduces the rotating mass giving it more RPM to move more air ....
is that how this mod works?
cause i have a trexx 100s tail rotor that is a tad smaller then the stock G rotor....and i am thinking if i sharpen the edges on it i might get the same results....
magic_marty is online now Find More Posts by magic_marty
Old Nov 04, 2011, 08:25 PM
<Marty>
Joined Jul 2011
lol....wow the thread is dead, everybody must be cutting and sanding on there tail rotors...lol
Old Nov 04, 2011, 10:21 PM
Hellraser's Avatar
UK
Joined Jul 2007
Just don't do it where the people next door can hear - probably think your practicing legal dentistry on the wife or kids
Regards David
Old Nov 05, 2011, 12:53 AM
bobepine is online now
Find More Posts by bobepine
Team Armattan
bobepine's Avatar
Joined Jun 2011
Nice work, Farmer. I will definitely give this a go. Looks like this would increase the motor life, too.
Do you think a sewing needle inserted in the rotor would work to test the blade balance to see if one side is heavier than the other? I think I read about someone doing this somewhere else.
Regards,
Chris
bobepine is online now Find More Posts by bobepine
Latest blog entry: Armattan F1 Lineup Revealed
Old Nov 05, 2011, 04:56 AM
vronny is online now
Find More Posts by vronny
los angeles,ca
Joined May 2010
Regards,
Chris
DK modded his by twisting adding more angle or pitch.
vronny is online now Find More Posts by vronny
Old Nov 05, 2011, 06:32 AM
Farmer
United States, CA
Joined Oct 2011
that works to, to a certain extant but in reality the cause of blow out was to much wing area causing the tail motor to bog, more pitch worked until I started flying in wind and doing inverted pitch and having to replace the motor every 10th flight lol
Old Nov 05, 2011, 06:33 AM
Farmer
United States, CA
Joined Oct 2011
Regards David
david you're to much lmao
Old Nov 05, 2011, 06:37 AM
Farmer
United States, CA
Joined Oct 2011
Regards,
Chris
chris that should work fine, im using an old yanked out motor shaft to balance mine
and thanks Chris
seems I am having to much time in my hands gf is out of town
Old Nov 05, 2011, 06:48 AM
Farmer
United States, CA
Joined Oct 2011
Ok so it was windy yesterday howling at over 30+ mph, I wouldnt even try to fly my trex 600efl 3gx pro on this kinda day lol, but I went ahead and flew with the modded tail blade and you can see the heli's tail barely even broke a sweat or even weather vained just a tad inverted, so thats good news for.the sport flyers as well
ill stop typing and let the video speak for its self
walkera genius cp windy flight (2 min 51 sec)
enjoy
Dave
Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX Tom Z Micro Helis 561 Oct 17, 2015 02:50 AM
For Sale Walkera rtf genius cp with devo 8 nib 200.00 shipped (scam?) Hot_Wheels Aircraft - Electric - Helis (FS/W) 46 Oct 16, 2011 06:08 AM
Help! need help on how to press on the stock genius cp pinion onto C05 bl motor f.a.r.m.e.r Micro Helis 12 Oct 13, 2011 11:20 AM
Sold Walkera rtf genius cp with devo 8 nib 200.00 shipped Lbzracing909 Aircraft - Electric - Helis (FS/W) 0 Sep 30, 2011 09:19 PM
Sold Walkera Devo7 with rtf Genius cp.... magic_marty Aircraft - Electric - Helis (FS/W) 1 Sep 23, 2011 01:10 AM
