Old Jan 15, 2012, 09:55 PM
scrat111 is offline
Find More Posts by scrat111
scrat111's Avatar
Originally Posted by bytemuncher View Post
scrat, thank you for posting your test results. Couple questions. Do you get any cogging with the c05 w/ the 8t? I am running it with a 9t (I think hs is too high) and sometimes I have to give the blades a spin by hand to start it spinning. Mesh is good so I don't think that's it. When I oil the bearings that helps a little.
Could you post a picture of your c05 setup? I'm curious how you got the weight so low. Probably I'm using too much hot glue...I blame Bob for getting me addicted to the stuff.
No cogging that I can tell... starts right up every time. I wasn't really trying to get the weight low, but I soldered the motor directly to the esc, and I took off the thick heat shrink from the esc and just used packing tape for insulation. It would have weighed even less if I'd had a smaller tie wrap, haha.
Mark
scrat111 is offline Find More Posts by scrat111
Old Jan 15, 2012, 11:29 PM
scub is offline
Find More Posts by scub
United States, MA, Springfield
Joined Dec 2010
i installed a bigger 7mm tail motor, different rotor blade with more pitch and the damn tail still won't hold. on top of that i have a program mix with 12% added to left rudder, it's ridiculous.. this heli doesn't make a great indoor hoverer which is what i want it for. basically hold left rudder 24/7 while hovering i hate helicopters with two motors
scub is offline Find More Posts by scub
Old Jan 15, 2012, 11:37 PM
bytemuncher is offline
Find More Posts by bytemuncher
Tokyo
Joined Jan 2010
Hey scub, when you say it won't hold the tail are you talking about tail blow outs during pitch pumps and flips, or are you talking about the ccw tail drift? I think a 7mm will only help for blow outs, not for the ccw tail drift.
bytemuncher is offline Find More Posts by bytemuncher
Old Jan 15, 2012, 11:59 PM
scub is offline
Joined Dec 2010
i thought it would help tail drift a little but had absolutely no effect. it gets much worse as voltage starts to drop below 3.85.
Old Jan 16, 2012, 12:06 AM
Tokyo
Joined Jan 2010
Yeah, I think it's something wrong in the rx (e.g. cheap rudder gyro, bad firmware code). If you haven't already you can read about available workarounds here http://www.helifreak.com/showthread.php?t=368255.
Dkfuji said it is NOT present in the new mini cp http://www.rcgroups.com/forums/showp...&postcount=201
Alishanmao said he would test his sample to see if it has it. I also asked Finless to check once he gets his sample from Walkera.
None of this really helps with the genius though
Old Jan 16, 2012, 12:49 AM
airbasher is offline
Find More Posts by airbasher
United States, MI, East Lansing
Joined Mar 2008
Will be good to get verification of no tail drift on Mini CP from different sources. For mine, putting the V3 mcpx tail on got rid of it for awhile, then it came back.
Besides that though, the tail HOLD is tremendous. Got to let mine breath outside today and was doing full speed backwards hurricanes with just a light 4mph wind and it was just rock steady. Turned them into nose down/skids in funnels and same thing. Just amazing. Add to that after 100 flights the tail boom doesn't fit so snug so it's got play in it and I slid it back a few mm.
airbasher is offline Find More Posts by airbasher
Old Jan 16, 2012, 03:10 AM
Arthure is offline
Find More Posts by Arthure
Arthure's Avatar
United States, AZ, Surprise
Joined Mar 2007
Originally Posted by pmerritt View Post
I'm using a 9t pinion. The 1st one was a 1mm c05 from wow hobbies and this one is the 1.5mm from hobbyking. Both have worked for me with no cogging.
Where did you get a 8t 1.5mm pinion? Does it hold up...not much wall thickness at the spec is there?
Arthur
Edit: I see Dylan has them. I thought I looked there.
Arthure is offline Find More Posts by Arthure
Old Jan 16, 2012, 03:46 AM
dado099 is offline
Find More Posts by dado099
Italy
Joined Sep 2007
Hello, I have the c05 with zippy 400mah 20c soldered walkera ESC.
My problem is that when I try a fast flip back, tail starts spinning, loosing control.
Tail motor and blades are stock.
Do you think that walkera double brushless upgrade (obviously only tail) can fix the above situation ?
dado099 is offline Find More Posts by dado099
Old Jan 16, 2012, 04:54 AM
Username> is offline
Find More Posts by Username>
Joined Dec 2007
Just finished setting up my 2801 pro for both of my Geniuses but need to check my blade pitch.
My 450 pitch gauge is far too large for the Genius.
How are you Guys checking the blade pitch? Is there something available that screws into the rotor head so that I can fit a flybar for checking against?
Username> is offline Find More Posts by Username>
Reply With Quote  (Disabled)
Old Jan 16, 2012, 08:18 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
I used the fold the blades both back over the boom and look at them way.. I guess you could even do it this way.. Just measure the spread of the blades and figure it out for sure.
Blade length = 105 mm
1 ° 3.7 mm
2 ° 7.3 mm
3 ° 11 mm
4 ° 14.6 mm
5 ° 18.2 mm
6 ° 21.8 mm
7 ° 25.4 mm
8 ° 28.9 mm
9 ° 32.4 mm
10 ° 35.9 mm
11 ° 39.3 mm
12 ° 42.7 mm
13 ° 46 mm
14 ° 49.3 mm
15 ° 52.5 mm
l = mm
http://www.icer.ch/cms/Unternehmen/f...erechnung.html
livonia bob is offline Find More Posts by livonia bob
Old Jan 16, 2012, 08:27 AM
pmerritt is offline
Find More Posts by pmerritt
Joined Oct 2010
Originally Posted by livonia bob View Post
I used the fold the blades both back over the boom and look at them way.. I guess you could even do it this way and figure it out for sure.
i actially have a similar app on my android phone and it actually works extremely well for setting up blade pitch...even on a micro such as the genius.
pmerritt is offline Find More Posts by pmerritt
Old Jan 16, 2012, 09:17 AM
txipicopter is offline
Find More Posts by txipicopter
txipicopter's Avatar
Joined Oct 2010
Hola.
Aquí les dejo un vídeo de el genius_CP con motor blade_mcpX y nanotech 300mha 35C.
F.a.r.m.e.r.... ¿Como estás amigo?... ¿Todo bien?...
Saludos.
Todos los dias sale el sol txipiron (4 min 50 sec)
txipicopter is offline Find More Posts by txipicopter
Old Jan 16, 2012, 09:31 AM
Joined Dec 2007
1 ° 3.7 mm
2 ° 7.3 mm
3 ° 11 mm
4 ° 14.6 mm
5 ° 18.2 mm
6 ° 21.8 mm
7 ° 25.4 mm
8 ° 28.9 mm
9 ° 32.4 mm
10 ° 35.9 mm
11 ° 39.3 mm
12 ° 42.7 mm
13 ° 46 mm
14 ° 49.3 mm
15 ° 52.5 mm
l = mm
Nice find.
I presume the h parameter means the distance between both blades folded over each other at the widest point?
Old Jan 16, 2012, 09:51 AM
pmerritt is offline
Joined Oct 2010
RC-Heli Pitch is the program on the Android market that does this. Works really well...if you have an android phone you definitely should give it a try.
Old Jan 16, 2012, 10:03 AM
Heli collector
Joined Apr 2009
Nice find.
Yes you just measure the distance between the blades at the tips look at the chart and you have the pitch..
Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX Tom Z Micro Helis 561 Oct 17, 2015 01:50 AM
For Sale Walkera rtf genius cp with devo 8 nib 200.00 shipped (scam?) Hot_Wheels Aircraft - Electric - Helis (FS/W) 46 Oct 16, 2011 05:08 AM
Help! need help on how to press on the stock genius cp pinion onto C05 bl motor f.a.r.m.e.r Micro Helis 12 Oct 13, 2011 10:20 AM
Sold Walkera rtf genius cp with devo 8 nib 200.00 shipped Lbzracing909 Aircraft - Electric - Helis (FS/W) 0 Sep 30, 2011 08:19 PM
Sold Walkera Devo7 with rtf Genius cp.... magic_marty Aircraft - Electric - Helis (FS/W) 1 Sep 23, 2011 12:10 AM
