Joined Aug 2011
Its this cable: http://www.xtreme-production.com/xtr...mart&Itemid=31
You can get it in almost every heli store. It needs resoldering to microdeans. |
Joined Jun 2011
You can charge multiple batteries with the stock charger but you need a parallel charging harness. The problem with using the stock charger is that the more batteries you harness on it, the slower it charges the batteries so you don't really get the batteries sooner. With a balance charger, you can program different charge rates. A lot of folks use the iMax B6. I use the iMax B6AC and it's great. It's among the more affordable ones, too. ![]() It does require a fair bit of soldering to set everything up but it's worth it. Best, Chris |
Joined Dec 2007
To change to 6 axis (red led), you would flick the right hand dip switch the opposite way. Leave the first switch set to " Wk " and not to " adj ". I don't have my Genius in front of me, so can't tell you if position 1 or 2 is 3x or 6x, but somebody will chime in. |
Joined Jun 2011
Mine also came in 3 axis. Best, Chris |
Hey guys,
Im having a problem on my genius of ever decreasing pitch. When i got it 0% pitch was 0 pitch now 0% is very negative. I fixed it once by extending the linkage rods but I think they are about as far as they can go right now. Any ideas to fix this? Its to the point now where I cant even take off anymore. Thanks! Edit: My pitch curves are set like normal for stunt 100% negative and 100% positive so Im pretty sure the problem isnt there. Also all of the servos are centered at 0 pitch |
Mike |
| Thread Tools | |
| Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX | Tom Z | Micro Helis | 471 | Apr 26, 2013 05:05 PM |
| For Sale Walkera rtf genius cp with devo 8 nib 200.00 shipped (scam?) | Hot_Wheels | Aircraft - Electric - Helis (FS/W) | 46 | Oct 16, 2011 05:08 AM |
| Help! need help on how to press on the stock genius cp pinion onto C05 bl motor | f.a.r.m.e.r | Micro Helis | 12 | Oct 13, 2011 10:20 AM |
| Sold Walkera rtf genius cp with devo 8 nib 200.00 shipped | Lbzracing909 | Aircraft - Electric - Helis (FS/W) | 0 | Sep 30, 2011 08:19 PM |
| Sold Walkera Devo7 with rtf Genius cp.... | magic_marty | Aircraft - Electric - Helis (FS/W) | 1 | Sep 23, 2011 12:10 AM |
