Joined Dec 2011
Wires are too thin, and bad quality, but I don't understand the link with plugs ? Changing them is not going to preserve wire bending problems... And the efficiency is a multiplicating problems, not a sum... |
I was just out flying the #1 and you know I think it's trying to tell me it wants a new tail motor.. It's making more noise now,, and full left rudder gets about 30 degrees left turn and then it shuts off and I get some really nice fast piro's to the right... ![]() ![]() ![]() Going to switch over to flying the V120D02S and take some video of the tail holding with the adjustable slipper clutch installed.. |
However, I might be able to explain some reasons why many people have had good experiences "blindly" swapping to Micro Deans:
Any wire meant to be moved around will be stranded. Solid wire is not meant to be bent and will break after repeated bending before stranded. The plugs walkera uses today are the same Losi uses on it's mini trucks that pull a lot more amps than this little bird. Your first sign of amp loss will be in the form of heat. If your plugs or connection is not really warm when you unplug it, your plugs are just fine. I can not see this heli pulling more amps than my Trex250 and it comes with jst plugs, but people still change these right away because its a cheap mod not because of a problem and then you have Replacement Theology thinking I made a change and it's much better when in reality it's not and sometimes worse. The old saying don't fix it if it's not broke. You will get 1000's of these stories of that was my problem when in most cases it was not.
I was going to change mine just because of availability, but I found that these plugs are the same as the losi mini and are easily available at my lhs. |
Latest blog entry: Logo build
As I like the better gripping I get with the Deans and that I can bring the wires off them at 90 degrees and that I can use JB Kwik to cover the solder joints while acting as the strain relief, this adds up to a neater looking heli with less wires hanging down in flight.. |
The location of the battery wires suck! you would think they could of found a better location or a little longer wire.
Joined Dec 2007
Only had my GCP for just over a week as well, but this is typical of Walkera. Edit- just found the clip, here; http://www.youtube.com/watch?gl=US&h...&v=GsnTG38-kjg |
Tokyo
Joined Jan 2010
Main differences I noticed:
1) Vertically mounted rx with power and motor plugs on front and servo plugs on rear 2) Mcpx-ish main motor 3) Removable skids with battery tray located under main gear 4) Stock batteries (probably junk) are 240mah 5) Same servos with different mounting (more crowded) around the main shaft I'm thinking you could just buy the main frame, skids, and a new motor if you wanted to convert a gcp to a "mini-cp". |
Yep! You beat me to it! I was just going to post the video link. It looks like they have made some improvements such as the skid now is seperate from the frame, larger Mah battery and higher C rating of 25. Also, it looks a lot like a Mcpx motor is on it as well. I have my CC rdy to buy this baby when it's avail.
Joined Dec 2007
I'll hold back on this mini CP and let the beta testers do their bit as I did with the GCP.
One thing for sure; It's gonna cost a few nicker, what with that Devo 8 with telemetry. Walkera have really come on leaps and bounds and I think we're gonna see some real special stuff this annum. |
I'm sure this doesn't mean anything but my computer crashed while watching the video... Or is this a warning??? |
It looks to be the same size with a smaller canopy and unless they make a really small diameter brushless motor you can say good buy to a conversion unless you plan on cutting a hole in that servo.
| Thread Tools | |
| Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX | Tom Z | Micro Helis | 471 | Apr 26, 2013 05:05 PM |
| For Sale Walkera rtf genius cp with devo 8 nib 200.00 shipped (scam?) | Hot_Wheels | Aircraft - Electric - Helis (FS/W) | 46 | Oct 16, 2011 05:08 AM |
| Help! need help on how to press on the stock genius cp pinion onto C05 bl motor | f.a.r.m.e.r | Micro Helis | 12 | Oct 13, 2011 10:20 AM |
| Sold Walkera rtf genius cp with devo 8 nib 200.00 shipped | Lbzracing909 | Aircraft - Electric - Helis (FS/W) | 0 | Sep 30, 2011 08:19 PM |
| Sold Walkera Devo7 with rtf Genius cp.... | magic_marty | Aircraft - Electric - Helis (FS/W) | 1 | Sep 23, 2011 12:10 AM |
