Old Jan 08, 2012, 03:21 AM
scub is offline
Find More Posts by scub
United States, MA, Springfield
Joined Dec 2010
anyone know the stock genius pinion size, mod 0.5mm bore 1.0mm ?
walkera doesn't package pinions?
scub is offline Find More Posts by scub
Old Jan 08, 2012, 03:47 AM
jasonjetski is offline
Find More Posts by jasonjetski
Micro-Heli-Concepts
jasonjetski's Avatar
Australia, NSW, Blacktown
Joined Dec 2006
1mm hole M0.5 I think
jasonjetski is offline Find More Posts by jasonjetski
Old Jan 08, 2012, 07:07 AM
bobepine is online now
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
Originally Posted by livonia bob View Post
The mCPX needs them to try and get it to fly right where the Genius flies fine out of the box.. No mods need,, but them some hot glue here and there and some tape doesn't hurt..
Right out of the box:
Genius CP- Stock Out of the Box (2 min 55 sec)
Best,
Chris
bobepine is online now Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Jan 08, 2012, 07:29 AM
Flo38 is offline
Find More Posts by Flo38
Joined Dec 2011
Stock with microdeans !
How many people did change walkera plugs ?
Flo38 is offline Find More Posts by Flo38
Old Jan 08, 2012, 07:45 AM
Macias is offline
Find More Posts by Macias
Joined Aug 2011
Most of us DID, all of us WILL.
Macias is offline Find More Posts by Macias
Old Jan 08, 2012, 07:59 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
good to hear. walkera should just recall this RX and give us new ones (i know, wishful thinking).. so far there are two known problem.. 1) weak connection wire 2) left rudder/tail drift (actually 3 if you count the fubared 6 axis but that isn't a big deal for most).
im suffering from huge power loss (heli wont' stay up in the air) but it could be a bad motor as well, but i did ordered a much better soldering iron and magnifying glass that will help me redo the wiring but it's a PITA for people with no tools or much soldering skills to have to inevitably fix the wiring.
Start with rewiring the heli from the Deans to the RX,, I'm saying use new wire 24g, micro Deans, bring the new wires up from the bottom of the board through the board and leave about 3/16" sticking above the board for later use if going to brushless motor,, you will solder the ESC on here..
Now I have done all this to mine with the C03 HK 7500KV motor which used to fly nice but has now lost power, I replaced this with a C05 HK motor and still not good power, replaced this with a stock motor still not good power.. So what am I looking for power wise,,, I just want it to fly like it did before, and/or as good as my #2 Genius flies... What is the problem,, I don't know yet.. If you figure it out let me know.. But mine might be a simple time to replace the head dampers, new blades, new tail motor etc.. But as it's still flyable I'm still flying it..
livonia bob is offline Find More Posts by livonia bob
Old Jan 08, 2012, 08:02 AM
Heli collector
Joined Apr 2009
All the smart ones..
Old Jan 08, 2012, 08:41 AM
bytemuncher is offline
Find More Posts by bytemuncher
Tokyo
Joined Jan 2010
Have you tried swapping the rx's? Would be interesting to see if the power issue follows the rx or stays with genius #1. If it stays with genius #1 then I would suspect a bad tail motor.
bytemuncher is offline Find More Posts by bytemuncher
Old Jan 08, 2012, 09:01 AM
Heli collector
Joined Apr 2009
I lot easier to swap tail's than RX's... And as it's the stock tail I'm sure it's about time for a new one anyways but this one is still hold good.. But this might be due to the reduced power of the main.... Right now we are having some really great weather for Michigan in January so I'll keep flying it,, the #3 should show up this week.. I'm betting the same day the weather returns to normal..
Old Jan 08, 2012, 09:39 AM
Flo38 is offline
Joined Dec 2011
Smart ones probably did some measures to prove the existence of a fundamental difference between micro deans and walkera plugs ?
Moreover, you need to consider the efficiency of the...
I don't know how you say... You use an electric warming machine, on a certain metal, tu 'glue" the connector to the wire...
Because all of us haven't the same material and skill to do this as efficiently as needed...
Old Jan 08, 2012, 10:19 AM
Heli collector
Joined Apr 2009
I'm sure if you go back a few years and read the old Walkera 4#3 threads about the problems with the stock connectors and the testing done back then.. And that while we talk about changing over to the Deans what we are really saying is the the wires at the Walkera connector start fraying inside at the crimp and are breaking causing to much electrical resistance and this is dropping the power.. and the easiest way of fixing this is to install the Deans,,, Knowing that the wires will still fray and need to be redone now and then.. as well the connection at the board.. So spending the ten bucks to get the proper metal gluing tools and supplies is money well spent..
Old Jan 08, 2012, 10:39 AM
Flo38 is offline
Joined Dec 2011
Hi
Even if the shape is the same, connectors may have evolved since 4g3...
But I didn't understand the problem (because of terms)
"Walkera connector start fraying inside at the crimp and are breaking"
Could you explain it more easily for me ?
Old Jan 08, 2012, 10:53 AM
Username> is offline
Find More Posts by Username>
Joined Dec 2007
Hi
The Walkera lipo power wires use cheap thin stranded wire as opposed to solid core wire or thicker stranded wire.
As these stranded wires are so thin, once they repeatedly get bent and pulled the single strands are going to break. There are probably about 15-20 strands of wire which are about the same thickness as Human hair so you can probably appreciate that it's pretty weak.
I can't think of any other explanation.
Within the next week or so, I intend to change the lipo wires to a thicker stranded wire, or I might even use a solid core wire. Either way, both of these changes will be better than using the thin stock stuff.
Btw.. The first thing I did when I got my GCP was to change to genuine micro Deans. I flew it once with the stock connector just to test it.
All my sub-micro birds use micro deans, too.
Username> is offline Find More Posts by Username>
Reply With Quote  (Disabled)
Old Jan 08, 2012, 11:01 AM
Palle_Plutt is offline
Find More Posts by Palle_Plutt
Kingdom of Sweden, Västra Götaland County, Lindome
Joined Jul 2011
Originally Posted by damo666 View Post
The Walkera lipo power wires use cheap thin stranded wire as opposed to solid core wire.
It's the stranded wire that makes it soft.
One solid core wire is stiff and not that flexible.
I think walkera saved some bucks on the copper quality in the wire therefore it's brittle.
Then amount of force when crimping is affecting same as how the wires are soldered and can create brittleness.
Palle_Plutt is offline Find More Posts by Palle_Plutt
Old Jan 08, 2012, 11:19 AM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
Here in N. Cal. we have the warmest, driest winter in 90 yrs. I'm thinking about getting a V120D01S. Maybe we'll get our snow back (this is a ski town).
shastamike is offline Find More Posts by shastamike
Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX Tom Z Micro Helis 561 Oct 17, 2015 01:50 AM
For Sale Walkera rtf genius cp with devo 8 nib 200.00 shipped (scam?) Hot_Wheels Aircraft - Electric - Helis (FS/W) 46 Oct 16, 2011 05:08 AM
Help! need help on how to press on the stock genius cp pinion onto C05 bl motor f.a.r.m.e.r Micro Helis 12 Oct 13, 2011 10:20 AM
Sold Walkera rtf genius cp with devo 8 nib 200.00 shipped Lbzracing909 Aircraft - Electric - Helis (FS/W) 0 Sep 30, 2011 08:19 PM
Sold Walkera Devo7 with rtf Genius cp.... magic_marty Aircraft - Electric - Helis (FS/W) 1 Sep 23, 2011 12:10 AM
