Old Jan 06, 2012, 08:12 PM
txipicopter is offline
Find More Posts by txipicopter
txipicopter's Avatar
Joined Oct 2010
F.a.r.m.e.r.,,, repuse el mcpx motor por uno nuevo, el anterior tenía el eje doblado.
Usé el soldador para calentar el piñón e instalarlo, ahora perfecto.
Originally Posted by M3_matt View Post
amare il tuo uomo video! Felice di vederti bloccato in un motore mcpx in là! Quanto è durato il motore scorte?
Matt
Con lipo 240mh 20C de HK, 2:30 a 3:00 minutos haciendo 3D.
txipicopter is offline Find More Posts by txipicopter
Old Jan 06, 2012, 09:28 PM
f.a.r.m.e.r is offline
Find More Posts by f.a.r.m.e.r
Farmer
f.a.r.m.e.r's Avatar
United States, CA
Joined Oct 2011
Originally Posted by Flo38 View Post
Hi Farmer
Could you say me why do you prefer mcpx motor to the brushless (hp03s I suppose) ?
I think with mcpx motor it's heavier than normal brushed Genius... So that you have something like a mcpx...
Its nothing near the mcpx wieght just cause the motor swap, the mcpx (brushed) motor has twice the power of the stock (coreless) gcp motor, and runs alot cooler. And its cheap,
Hp03s bogs like crazy if you dont do any 3D its fine. But if you over gear it the motor will cog bad at startup.
Farmer
f.a.r.m.e.r is offline Find More Posts by f.a.r.m.e.r
Old Jan 06, 2012, 09:31 PM
Farmer
United States, CA
Joined Oct 2011
Como estas amigo?
Old Jan 06, 2012, 09:37 PM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
Originally Posted by f.a.r.m.e.r View Post
Como estas amigo?
I'm so glad you guys are communicating en español. I miss being south of the border here in USA and using what's left of my high school Spanish. It's easy to learn a language in this context of "heli-speak".
¡Continúe el buen trabajo!
shastamike is offline Find More Posts by shastamike
Old Jan 06, 2012, 10:54 PM
benmlee is offline
Find More Posts by benmlee
Los Angeles
Joined Oct 2006
That is perfect benmlee, thats basically how it works on my micro team losi micro stadium truck
I would use a piece of cut rc car fuel tubing as an oring to compress the servo horn around the teeth.
You are very creative, and im very impressed with your idea benmlee, going to do it to all my servos in the morning.
Thanks bud I love it
Farmer
Fuel tubing is a good idea if more tension is needed. Won't roll off like o-ring. Let me know if it works for you.
benmlee is offline Find More Posts by benmlee
Old Jan 06, 2012, 10:57 PM
benmlee is offline
Los Angeles
Joined Oct 2006
Originally Posted by i812 View Post
As usual, good website benmlee.
I liked your "Genius Challenge: Land on This 2.5" Diameter Helipad"
video:
http://www.youtube.com/watch?v=G42gk2KC9Wg
It might be better to have an un-edited "How fast can you land the Genius consecutively three times in a row on a 2.5 inch Diameter Helipad" challenge. This way, it helps reduce recording of any "chance" lucky landings.
It would be a fun competition to see who can land on the pad the fastest. Would be impressive to see someone do it quickly.
Old Jan 06, 2012, 11:14 PM
i812 is offline
Find More Posts by i812
i812's Avatar
Joined Aug 2009
I wasn't so much concerned about speed of landing, but trying conceive a way to "rule" out a rare lucky landing!
I assumed whoever could land 3 times consecutively on that pad in the fastest amount of time probably wasn't "lucky", and had the best skill.
I think it would be nice, if someone/we came up with an international obstacle course that everyone interested around the world could easily reproduce, and compete. Maybe different "categories" of competition: Precision Landings, 3D Routine, etc.
i812 is offline Find More Posts by i812
Old Jan 07, 2012, 01:38 AM
benmlee is offline
Los Angeles
Joined Oct 2006
Originally Posted by benmlee View Post
Dave's servo saver video got me thinking. Why not put a regular servo saver on the servo. They work great on r/c car steering. When the arm overload, the servo saver just give and save the gears. Just need one that is small enough to fit the space. Also need to be simple enough to make yourself. After a false start, finally got it working.
Here is a servo saver for the Genius similar in operation to ones in r/c cars:
http://benmlee.com/Genius_Servo_Saver.htm
Here the video to clarify what I did.
Will have to wait for more crashes to see how well it works in all kinds of crashes
Walkera Genius Helicopter Servo Saver Mod (2 min 59 sec)
Old Jan 07, 2012, 02:48 AM
bytemuncher is offline
Find More Posts by bytemuncher
Tokyo
Joined Jan 2010
Great video, thanks a lot ben. So you don't think it is necessary to use shrink tubing or fuel line for added tension?
bytemuncher is offline Find More Posts by bytemuncher
Old Jan 07, 2012, 02:58 AM
Palle_Plutt is offline
Find More Posts by Palle_Plutt
Kingdom of Sweden, Västra Götaland County, Lindome
Joined Jul 2011
Hi all folks with great knowledge!
I'm a noob of working with brushless motors.
I would like to get some recommendations for a brushless motor for Genius.
Main goal is a motor for back to back flying.
Flying type is hovering and normal flying with perhaps some sport flying.
Perhaps if it's possible longer fly time and lower AUW.
I'm not afraig of soldering so thinking of a "Steve" and a small ESC like benmlee writes on his page but with a smaller motor.
I have read that Bob is using another motor but I haven't figured out what type exactly that is?
Regards
Paul
Palle_Plutt is offline Find More Posts by Palle_Plutt
Old Jan 07, 2012, 04:58 AM
Flo38 is offline
Find More Posts by Flo38
Joined Dec 2011
Hello farmer
Ok but I don't really understand.
What are the weights of genius cp brushed motor and mcpx brushed motor ?
Genius Cp stock is about 41.5g and mcpx about 44.5g. If you add 3g to the Genius, you have a kind of mcpx...
I thought the only one advantage of the Genius was its weight...
Flo38 is offline Find More Posts by Flo38
Old Jan 07, 2012, 07:28 AM
Hellraser is offline
Find More Posts by Hellraser
Hellraser's Avatar
UK
Joined Jul 2007
Hello farmer
No weight is one of a number of advantages the genius has over the MCPX
Regards David
Hellraser is offline Find More Posts by Hellraser
Old Jan 07, 2012, 08:07 AM
Flo38 is offline
Joined Dec 2011
I don't like mcpx servos either.
Have you a list of the other advantages ?
Old Jan 07, 2012, 08:11 AM
scub is offline
Find More Posts by scub
United States, MA, Springfield
Joined Dec 2010
the only advantage the mcpx has is a lot more parts available for modding,etc. other than that it's obsolete with its cheesy linear servos.
scub is offline Find More Posts by scub
Old Jan 07, 2012, 09:26 AM
Flo38 is offline
Joined Dec 2011
I have already waited these fu***** mcpx servos for 2 months
Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX Tom Z Micro Helis 561 Oct 17, 2015 01:50 AM
For Sale Walkera rtf genius cp with devo 8 nib 200.00 shipped (scam?) Hot_Wheels Aircraft - Electric - Helis (FS/W) 46 Oct 16, 2011 05:08 AM
Help! need help on how to press on the stock genius cp pinion onto C05 bl motor f.a.r.m.e.r Micro Helis 12 Oct 13, 2011 10:20 AM
Sold Walkera rtf genius cp with devo 8 nib 200.00 shipped Lbzracing909 Aircraft - Electric - Helis (FS/W) 0 Sep 30, 2011 08:19 PM
Sold Walkera Devo7 with rtf Genius cp.... magic_marty Aircraft - Electric - Helis (FS/W) 1 Sep 23, 2011 12:10 AM
