Old Oct 20, 2011, 08:09 PM
PepeM is offline
Find More Posts by PepeM
Joined May 2011
1/12 Scale RC cars
Hello. I need to find several 1/12 scale RC cars for a project. I need six of seven of them. They should be faithful recreations of their real counterparts, preferably on road race cars. I've been looking and I've found tons of 1/10 scale cars, but I have not been very lucky finding 1/12 scale cars. Any idea where I can find some? Thanks.
PepeM is offline Find More Posts by PepeM
Old Oct 20, 2011, 09:38 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
What kind of cars? It should be pretty easy to find 1/12th scale pan cars, but they won't be overly realistic looking bodies.
wparsons is offline Find More Posts by wparsons
Old Oct 20, 2011, 09:47 PM
PepeM is offline
Joined May 2011
I've seen the pan cars but, as you say, they are not very realistic looking. I'm looking for scale versions of real race cars, no race cars in particular but a Nascar would be nice, maybe a stadium truck as well as some touring cars. It is for creating a wind tunnel lab for a fluid mechanics class.
Old Oct 20, 2011, 11:15 PM
Aethertek is offline
Find More Posts by Aethertek
Creations Aberration
Aethertek's Avatar
United States, OR, Newport
Joined Jan 2004
Well if it's just for FDA you might try some of the Static Scale sites, though you will have better luck at 18th scale, 1/12 will be hard to find & expensive when do.
http://www.buycheapr.com/us/result.j...ecast+car+1+12
http://www.idcow.com/diecast-cars-1-12-scale.html
http://www.diecastmodelswholesale.co...diecast/Detail
http://www.diecastfast.com/
http://www.one18racing.com/links.htm
http://www.google.com/search?q=1%2F1...nt=seamonkey-a
Luck
Kevin~
Aethertek is offline Find More Posts by Aethertek
Old Oct 21, 2011, 06:59 AM
PepeM is offline
Joined May 2011
If no RCs are found then I will consider some static scale cars. The thing is, I need to be able to remove the body from the chassis to be able to put some stuff in there. Thanks for the suggestion.
Old Oct 22, 2011, 02:51 AM
SporadicIdiocy is offline
Find More Posts by SporadicIdiocy
Sakura Ultimate graduate
SporadicIdiocy's Avatar
Richmond B.C. Canada
Joined Oct 2007
Do you want only the bodies or actually 6-7 1/12th rc cars..coz.. if it's for a wind tunnel testing setup, I'd think a mock chassis mounting the bodies would be sufficient.
For bodies, check out the bodies from ABC hobby USA, the mini bodies should be 1/12th scale (or very close) if I'm not mistaken.
http://www.tqrcracing.com/shop/produ...03&s_maker_id=
SporadicIdiocy is offline Find More Posts by SporadicIdiocy
Old Oct 22, 2011, 11:58 AM
PepeM is offline
Joined May 2011
ABC hobby USA seems to have several 1/12 scale cars, thanks a lot for the tip SporadicIdiocy!!!!
I'll also look into smaller scales, what is a common scale? 1/16th, 1/18th?
Old Oct 22, 2011, 03:33 PM
Joined Oct 2007
If you want realistic scale bodies, 1/16 and 1/18 ones aren't going to cut it. The ones I see around look squished and widened to fit the chassis they're on.
You might wanna go even smaller in scale and look into X-Mod or Mini-z bodies, as they are made of hard plastics they can be made with far more realistic details and scale than lexan bodies.
Here's some for Mini-z
http://www.atomicmods.com/Categories...Body-Sets.aspx
Old Oct 22, 2011, 05:17 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Depending on the air speeds you plan to use, lexan bodies might just wobble and distort too much as well.
Cool Pilot Busts 1/8 Scale and 1/12 Scale MPS86 Slope 27 Oct 30, 2015 11:20 AM
Discussion Right Lipo for 1/10 scale Racing RC Cars jaguwar Batteries and Chargers 13 Jun 11, 2015 10:17 PM
Sold 1/6 Scale Pilot 1 PA-12 Super Cruiser New Parts pilot482 Aircraft - Electric - Airplanes (FS/W) 13 Oct 15, 2011 09:10 PM
Question O/T 1/8th scale onroad rc cars electric BACKEMFNRG Motorcycles 2 Aug 18, 2007 03:23 PM
Alert COMMON SENSE RC LiPo’s FOR 1/18th SCALE CARS 20% Off! mikekomm Car Talk 0 Apr 24, 2006 04:16 PM
