Old Feb 01, 2013, 10:56 AM
Gregoo is offline
Find More Posts by Gregoo
Désolé pour le français !
Gregoo's Avatar
France, Aquitaine, Saint-Pierre-du-Mont
Joined Jan 2013
Merci!
L'avantage de la roulette est de protéger la partie inférieure du fuselage !!
J'ai jamais fait de piste avec mais si je dois en faire ,je rajouterai 2 petits patins au bout des ailes!
Gregoo is offline Find More Posts by Gregoo
Old Feb 01, 2013, 04:38 PM
Wingwrecker is offline
Find More Posts by Wingwrecker
I buy, I fly, I buy....
Wingwrecker's Avatar
United States, OH, Toledo
Joined Feb 2008
I wish I could read french. I'm interested in knowing how that motor choice is working out for you Gregoo. I'm building my first EZ and want it a bit over powered just to have the extra horses in the stable to call upon when I'm feeling froggy. But is that Turnigy too much motor? Would I have to reinforce the plane?
Also to anyone, is the engine mount removeable in case I want change things out?
Evvy
Wingwrecker is offline Find More Posts by Wingwrecker
Old Feb 01, 2013, 04:57 PM
mnahmia is offline
Find More Posts by mnahmia
mnahmia's Avatar
United States, ID, Meridian
Joined Mar 2007
Evvy
I am building my second Easystar 2 to carry a camera,and the folks over at headsuprc recommended this combination as more power than stock:
Emax BL2220/07 Outrunner
HURC 30Amp ESC
APC 9 x 4.5E Prop
In order to use a larger prop I am using this mount-http://www.headsuprc.com/servlet/the-2422/Easy-Star-II-Adjustable/Detail
I have it on my current Easystar 2 and it works great!
mnahmia is offline Find More Posts by mnahmia
Old Feb 01, 2013, 05:31 PM
Joined Feb 2008
HURC 30Amp ESC
APC 9 x 4.5E Prop
Thanks for the info, mnahmia. The pricing looks good. Still hoping to hear back from Gregoo on his setup too.
Old Feb 01, 2013, 07:18 PM
Karl B² is offline
Find More Posts by Karl B²
29 rods from you in western WI
Karl B²'s Avatar
Joined Jan 2003
Originally Posted by Gregoo View Post
Merci!
[http://translation.babylon.com/french/to-english/:] Thank you! The advantage of the caster is to protect the lower part of the fuselage!! I ever made of track with but if I must make some, I will add 2 small shoes at the end of the wings
I translated Gregoo's earlier post with all the details, and I'm glad I did, because he found the motor I've been looking for. Got one on order.
Karl B² is offline Find More Posts by Karl B²
Old Feb 01, 2013, 08:14 PM
Joined Feb 2008
Gregoo, à quel point font vous aiment le moteur de Turnigy pour votre EZII ? Vole-t-il bien ? Est-ce trop de puissance ? Avez-vous la vidéo de vol avec votre installation curent ?
Thanks, Karl.
Old Feb 02, 2013, 08:00 AM
Gregoo is offline
Gregoo's Avatar
Joined Jan 2013
Je suis désolé de vous répondre en français car je suis vraiment nul en anglais!
Ce moteur le Turnigy est parfait en performance (du couple et une belle vitesse de pointe) équivalent à mon premier ES avec le inrunner 2200 kv !!
Les accus utilisés sont toujours les mêmes 1800 a 2200 mhA 3S!
En tout cas je vous recommande de renforcer les ailes comme je l'ai fait car vu la vitesse qu'il prend (+ 100 km/h) en pointe!!
Super en vol et trés stable!
Non désolé je n'ai pas de vidéo avec ce moteur!
Old Feb 02, 2013, 08:38 PM
Joined Feb 2008
Thanks!
Old Feb 02, 2013, 10:30 PM
Joined Feb 2008
Ordered Gregoo's motor setup.
I've been out of the game for a couple years but I always have been and likely always will be a power junkie when it comes to planes. I started flying in Denver and overpowering was almost a must there due to the thinner air but I think I can keep the throttle in check down here at sea level, at least for the first few flights!
Now to get a Futaba 7c, batts and a charger.. Thank you Tower Hobby 3-pay!
Old Feb 02, 2013, 11:45 PM
mutski is offline
Find More Posts by mutski
mutski
United States, AK, Fairbanks
Joined Jan 2011
New Propeller?
What's a good replacement propeller for the ESII? I'm not looking for more power, just something to perform like the original. I dinged the original and the vibrations now show up on my keychain camera videos.
PS - Can somebody explain the lingo APC, GWS, Slow-Fly? Which for ESII?
mutski is offline Find More Posts by mutski
Old Feb 03, 2013, 04:24 AM
mike_o is offline
Find More Posts by mike_o
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
APC (Advanced Precision Composites) and GWS are company names. As far as I can tell, GWS seem to be focusing on smaller, low cost props (some of them are quite well performing, though) for lighter A/Cs. APC have a broader range of props, many available as paired pusher/tractor (CW/CCW) types.
SF, or (generic) slow flyer propellers are generally intended for lower rpms (say <100000rpms/diameter).
The APC "TE" (thin electric) are designed for higher rpms, in application like the FunJet.
I'm not certain, but it seems that Aeronaut folding props are the best alternative to the stock prop, but they are usually even more expensive.
All in all, I'd go for an original set of replacement blades. Don't be tempted to go for a fixed prop, exept for using while waiting for the original to arrive.
mike_o is offline Find More Posts by mike_o
Old Feb 03, 2013, 06:26 AM
Gregoo is offline
Gregoo's Avatar
Joined Jan 2013
De simples APC suffisent,elles ont un bon rendements en général!!
Old Feb 03, 2013, 07:17 AM
mike_o is offline
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Dune du Pyla
Salut Gregoo,
vous habitez loin de Pyla? J'ai passé quelque journees de mes vacances 2012 a Cap Ferret, et pendant monter la dune, je regretterai de pas apporter ma EasyStar. Avez vous penser du faire un vol lá-bas?
Cordialment
I visited this place during my vacation last year, and I was cursing myself for not bringing my FPV EasyStar.
Old Feb 03, 2013, 03:07 PM
Gregoo is offline
Gregoo's Avatar
Joined Jan 2013
Originally Posted by mike_o View Post
Salut Gregoo,
Cordialment
Génial, oui j'y vais souvent en vacance car je suis pas loin (1h30 de chez moi) c'est un coin super et je n'ai toujours pas testé avec l'ES !!
Old Feb 04, 2013, 02:32 AM
mutski is offline
mutski
Joined Jan 2011
Mnamia - On the EasyStar II, the top of the motor pod comes off with three screws. You can remove the screws that hold the motor to the rear wall of the pod and pull it out through the top, easy as pie as long as you can unplug from the ESC.
I'm using a Turnigy 2836-1200 motor http://www.hobbyking.com/hobbyking/s...idProduct=7992
Turnigy Plush 25A speed controller
http://www.hobbyking.com/hobbyking/s...idProduct=2163
Programmed with a Turnigy BESC programmer (WELL worth the $!)
http://www.hobbyking.com/hobbyking/s...idProduct=2169
I'm carrying a keychain camera 808#16, G-OSD with GPS module, DORA board to convert Spektrum receiver data into analog signal strength, Immersion 600mw 5.8ghz video transmitter, Spironet antenna, and a Pixim Seawolf video camera (like a brick, 52 grams!).
I don't do vertical climbs and acrobatics, but I've got all the power I need with the equipment above and the stock folding propeller. I fly at half throttle and easily achieve 30-40 miles per hour.
Sold Multiplex Easy Star james mack Aircraft - Sailplanes (FS/W) 2 Oct 17, 2011 07:33 AM
Discussion Multiplex EASY STAR rickhensley Electric Sailplanes 92 Oct 13, 2011 02:43 PM
Sold Receiver Ready Brushless Multiplex Easy Star with Lipo, Pen Cam, & More! eagleswings Aircraft - Electric - Airplanes (FS/W) 10 Jul 12, 2011 03:28 PM
For Sale Easy Star Multiplex Brushless Motor Power Pack techcapsule Aircraft - Electric - Airplanes (FS/W) 0 Jul 11, 2011 03:11 PM
