Old Dec 06, 2012, 02:42 PM
Tom.in.Maryland's Avatar
Joined Mar 2012
how much throw and how much expo???
Please advise how much throw you have 100% in millimeters from center for your control surfaces I.e. Aileron, Elevator, Rudder???
and how much expo you use for the controls ???
This would be helpful to see how others fly the EasyStar 2.
Tom
Tom.in.Maryland is offline Find More Posts by Tom.in.Maryland
Old Dec 07, 2012, 02:13 AM
mike_o's Avatar
Denmark, Capital Region of Denmark, Charlottenlund
Joined Jan 2012
Tom
Multiplex manual, page 15, p. 38, "Setting the control surface travels":
Elevator +5mm -4mm (up down)
Rudder +-10mm
Ailerons +8mm -4mm
This works very well for me. I don't use any expo - the TS2 is pretty docile.
mike_o is offline Find More Posts by mike_o
Old Dec 08, 2012, 01:06 PM
Unregistered User
Commander Clumsy's Avatar
Belgium, famous for its brushless sprouts
Joined Feb 2007
Who would have thought of that.
Commander Clumsy is offline Find More Posts by Commander Clumsy
Old Dec 20, 2012, 11:43 AM
United States, CA, SF
Joined Feb 2005
Hi all,
Well, no answer over in the Hitec Sky Scout forum so I'll try here since the Sky Scout is an Easy Star II with different decals and Hitec electronics.
Can anyone tell me the O-ring size on the stock prop/spinner?
Thanks much and Happy Holidays!
thumsrus is offline Find More Posts by thumsrus
Old Dec 20, 2012, 01:01 PM
Joined Mar 2012
I broke mine, I use a small rubber band that came from a bag of assorted rubber bands. Go to Staples or Office Depot.
Old Dec 20, 2012, 05:08 PM
Joined Feb 2005
I misplaced mine before I even flew the plane...I'll try the rubber band thing.
Thanks.
Old Jan 01, 2013, 04:00 PM
mike_o's Avatar
Joined Jan 2012
...My controller Tx is 40MHz Graupner MX16S, which is legal in some European countries...
Originally Posted by Colonel Blink View Post
.. but only for ground based vehicles!
England is an exception to the general continental allocation picture.
According to a 2012 Graupner table, the entire 40 MHz band or parts thereof is available for cars, boats, and planes throughout Europe. This applies for:
Germany
Austria
Belgium
Switzerland
Czech Rep
Denmark
Spain
Iceland
Ireland
Latvia
Lithuania
Norway
Holland
Poland
Sweden
Slovenia
and a few more countries
Only in UK and Greece you'll find the entire 40MHz band is reserved for RC cars and boats.
The other major exception is France, where the entire 41MHz band is allocated for RC with the 10 lower channels reserved for planes alone, but the 40MHz band reserved for other purposes.
Old Jan 02, 2013, 02:02 AM
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Wow - I really wasn't aware of that.... I simply assumed that with European harmonisation it would be the same across the EU. Thanks for putting me straight!!!
Learning all the time....
Colonel Blink is online now Find More Posts by Colonel Blink
Last edited by Colonel Blink; Jan 02, 2013 at 06:22 AM. Reason: Correcting an error!
Old Jan 02, 2013, 03:34 PM
United States, WV, Calhoun
Joined Nov 2004
Anyone flying the Easy II with an inrunner?
If so what motor? Thank you. Todd
skyhawk1 is offline Find More Posts by skyhawk1
Old Jan 02, 2013, 05:11 PM
Tom Eutsler's Avatar
Asheville,NC
Joined Jun 2002
Inrunner
I am using one of Daniel's [ gobrushless.com] motors[out runner] and a motor mount from Terry at CNCsmall parts
...te
Tom Eutsler is offline Find More Posts by Tom Eutsler
Old Jan 02, 2013, 07:15 PM
ekotil's Avatar
Athens, Texas, United States
Joined Jul 2004
For what it's worth
I had some EDF housings with motors lying around that I wanted to use so one of the planes I selected with help from Kirk Massey of "New Creations R/C" was the ES II. The motor is a LittleScreamer with a 55MM fan. The motor installation was easy using strapping tape and hot glue. Motor angle was perfect just eye balling it in place on top of the motor mount. The plane is about a 50MPH easy flyer with soaring capability! Vertical performance is about 45 degrees up to soaring height. I wouldn't hesitate giving the controls to a beginner after taking it up to soaring height. It seems to like higher than lower control rates and the landing approach is long and graceful. This conversion worked well!
ekotil is offline Find More Posts by ekotil
Old Jan 02, 2013, 08:21 PM
mutski
Fairbanks, AK
Joined Jan 2011
Tom-in-Maryland - I first flew my EasyStar II (my first plane) this summer after learning on RC helicopters. I used the Dual Rate control to set the control surface travel as specified in the manual, but after some rough landings I added Expo to tame it. My current settings are:
Setting DR Expo
Aile 0 50% 30%
Elev 0 40% 30%
Rud 0 80% Inh
Aile 1 50% 40%
Elev 1 40% 40%
Rud 0 100% Inh
I've been flying with the Ailerons and Elevator in Position 1. I'd actually forgotten I'd changed the Rudder travel. I've been flying the Rudder in Position 0 without realizing I'd reduced its travel until I read your post and went back to check! My goal is stable flight, not acrobatics. I've had no trouble maneuvering in the wind with the settings above.
mutski is offline Find More Posts by mutski
Old Jan 02, 2013, 08:27 PM
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
What 4s bat are you running?
eckace1 is offline Find More Posts by eckace1
Old Jan 02, 2013, 08:52 PM
ekotil's Avatar
Joined Jul 2004
Actually I am running a nano-tech 2.25, 65-130c, 3 cell. This is now my go to lipo for about a dozen or so of my planes that take that size!
Old Jan 02, 2013, 09:10 PM
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
They must be great bats as I have one of the ls motors and with a small wing with a 6x4 prop only got to 50mph.
Mine is a park jet.
Sold Multiplex Easy Star james mack Aircraft - Sailplanes (FS/W) 2 Oct 17, 2011 07:33 AM
Discussion Multiplex EASY STAR rickhensley Electric Sailplanes 92 Oct 13, 2011 02:43 PM
Sold Receiver Ready Brushless Multiplex Easy Star with Lipo, Pen Cam, & More! eagleswings Aircraft - Electric - Airplanes (FS/W) 10 Jul 12, 2011 03:28 PM
For Sale Easy Star Multiplex Brushless Motor Power Pack techcapsule Aircraft - Electric - Airplanes (FS/W) 0 Jul 11, 2011 03:11 PM
