Old Jan 19, 2012, 09:19 AM
LAN is offline
LAN
Find More Posts by LAN
LAN
LAN's Avatar
Sweden, Östergötland, Valdemarsvik
Joined Oct 2003
Thanks for the motor info, Verid, very helpful!
/Leif
LAN is offline Find More Posts by LAN
Old Jan 20, 2012, 01:31 PM
Brian_ is offline
Find More Posts by Brian_
United States, TN, Nashville
Joined Dec 2007
Wonder why they didn't use hatch magnets this time instead of the plastic clips that often end up breaking or not lining up well enough to hold? How many EZ's have you seen when rubber bands or straps around the hatch and fuse.
Originally Posted by eckace1 View Post
I use a 330 watt inrunner larger esc and metal servos plus 7oz of cameras but only use a 3s1p2200 bat for 2 to 3 10 min flying sessions but still under 30oz.
So if by the book the new version weighs over 50oz with my gear No thank you.
But as Verid noted in his preview, the fuse is longer, VS is larger, and empennage is larger (since the EZ's sometimes break here). Probably worth the weight increase.
Brian_ is offline Find More Posts by Brian_
Old Jan 20, 2012, 02:42 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by BrianL View Post
Wonder why they didn't use hatch magnets this time instead of the plastic clips that often end up breaking or not lining up well enough to hold?...
I have a dozen of MPX models using those clips and never had a problem with them. Graupner does not use magnets either on their Elektro Rookie.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jan 20, 2012, 02:49 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
WOW 41 oz thats a heavy bugger I will stay away from this plane as its 2x the weight of the old easy1.
+1. I'll just add ailerons to the original Easy Star. Man, that is a LOT of weight!
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Jan 20, 2012, 04:18 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
Originally Posted by Verid View Post
1160g without FPV equipment.
You sure about that
http://www.multiplex-rc.de/en/produc...wshopitems_pi1
Gerry__ is offline Find More Posts by Gerry__
Old Jan 20, 2012, 05:55 PM
Verid is online now
Find More Posts by Verid
Joined Jan 2009
Originally Posted by Gerry__ View Post
Yes, my manual says same thing. I presume that they get such weight w/o ailerons and with their recommended equipment. Note that I use heavy motor (90g) - similar power outrunner weights 60g, use 3000mAh battery instead of 2000mAh - that's circa 100g, aileron servos are metal gear and elevator and rudder servos are larger than recommended. Same applies to my ESC. If you add extra spar in the tail boom and sum everything up you'll see why it's so heavy. But - it still flies and glides very well.
Verid is online now Find More Posts by Verid
Old Jan 21, 2012, 12:12 AM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
With the horizontal stab removed, will the EZ*2 fit in a 38.5 inch box long?
Is it really 4 inches longer than the original?
I'm wondering if it will fit my old transport box.
Thanks.
scrtsqrl is offline Find More Posts by scrtsqrl
Old Jan 21, 2012, 04:38 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Thanks.
This is what I have done for my No: 3 EZ* for the removable tailplane. It is a couple of inches longer. So I cut a hole in the end and added a small box. So in your case the MK2 should fit in your box.
Flypoppa is offline Find More Posts by Flypoppa
Old Jan 21, 2012, 06:06 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Blimey.. My MK1 EZ* flying weigh is 32.1oz or 920gm, that is with FPV and OSD.
Old Jan 21, 2012, 06:52 AM
Verid is online now
Joined Jan 2009
Then we have 2 possibilities - either my scale is broken and shows garbage or EZ* Mk.II is made (or some parts of it) from that extra dense ELAPOR like FunJet II. I'll try to get another scale and check again....
EDIT - sorry guys.....it seems that I need another scale. Three measures, three different readings....definitely it's broken.
I checked on kitchen scale - 920g. I'll try to find another scale to verify this result...
Old Jan 22, 2012, 05:00 AM
Joined Sep 2000
Obviously the EasyStar II is not as heavy as claimed by the user with the broken scales.
Jürgen
Old Jan 22, 2012, 12:09 PM
Joined Jul 2006
Jürgen
It only became 'obvious' after the user reported his scales were defective...
Old Jan 22, 2012, 12:13 PM
Joined Sep 2000
Anybody who cross-checked the weight with the data given by Multiplex could have spotted the error.
Jürgen
Old Jan 22, 2012, 12:16 PM
Joined Jul 2006
Jürgen
No. They would have spotted an inconsistency, and not necessarily an error...
Old Jan 22, 2012, 01:45 PM
Joined Sep 2000
Call it whatever you want.
When Multiplex writes in the instruction manual, that the EasyStar II weighs approx. 700g, and someone's EasyStar II weighs approx. 1100g, something is definitely not right (even when you consider the slightly heavier motor and the bigger battery).
Jürgen
Sold Multiplex Easy Star james mack Aircraft - Sailplanes (FS/W) 2 Oct 17, 2011 07:33 AM
Discussion Multiplex EASY STAR rickhensley Electric Sailplanes 92 Oct 13, 2011 02:43 PM
Sold Receiver Ready Brushless Multiplex Easy Star with Lipo, Pen Cam, & More! eagleswings Aircraft - Electric - Airplanes (FS/W) 10 Jul 12, 2011 03:28 PM
For Sale Easy Star Multiplex Brushless Motor Power Pack techcapsule Aircraft - Electric - Airplanes (FS/W) 0 Jul 11, 2011 03:11 PM
