Old Nov 24, 2012, 06:57 PM
Tom.in.Maryland is offline
Find More Posts by Tom.in.Maryland
Tom.in.Maryland's Avatar
United States, DC, Washington
Joined Mar 2012
Easystar 2
Is this enough motor for the EasyStar 2?
Turnigy 2826 1240KV
Plush 40A ESC
Corona FASST R8FA
Turnigy Nano-Tech 2.2 3S 35-70C
Futaba S3114
See pic.
Thank You,
Tom
Tom.in.Maryland is offline Find More Posts by Tom.in.Maryland
Old Nov 25, 2012, 03:26 AM
mike_o is offline
Find More Posts by mike_o
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Turnigy 2826 1240KV
Plush 40A ESC
Corona FASST R8FA
Futaba S3114
See pic.
Thank You,
Tom
yes, easily enough. I use a $6, 2826mm, 1000kv motor with the stock prop, and I'd expect you to get 20-30% more power with the higher kv, better quality SK3 motor.
Mine climbs with determination even with FPV gear onboard. Cruises at 40-50% throttle.
mike_o is offline Find More Posts by mike_o
Old Nov 26, 2012, 12:13 AM
henkvdw is offline
Find More Posts by henkvdw
KJ6BFN
henkvdw's Avatar
United States, CA, Fountain Valley
Joined Aug 2008
Turnigy 2826 1240KV
Plush 40A ESC
Corona FASST R8FA
Futaba S3114
See pic.
Thank You,
Tom
What size prop are you planning to use?
With the 1240 kV you may need to use an 8 or 9 inch prop to get the thrust needed.
henkvdw is offline Find More Posts by henkvdw
Old Nov 26, 2012, 03:42 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
His motor will do fine with the stock prop, after all it is a 1240kv motor.
The 40A ESC however is a bit "overkill". A 20A ESC with switching BEC is more than adequate.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Nov 27, 2012, 09:53 AM
Smokescreen38 is offline
Find More Posts by Smokescreen38
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
Jürgen
Have you seen the tiny stock props? I think these motors would be wasted on the stock propellers.
Tom.in.Maryland,
Try APC E 7x5. My guess is that these motors will pull less than 20A each on those props and 3s power.
Keep an eye on your motor temps. If they run hot, prop down a bit.
Wait...does the Easystar II fit a prop with a diameter greater than 6"? I'm only familiar with the old one...so my comment about the stock prop might be off base.
Smokescreen38 is offline Find More Posts by Smokescreen38
Old Nov 27, 2012, 10:10 AM
mike_o is offline
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
Tom.in.Maryland,
The larger, high pitch stock prop of the ES ll is a major difference between the two, so YES, your comment is very off. I suggest you edit/delete it before somebody else not bothering to read through the thread makes a mistake because of it.
MPX recommends a 2830mm 1100kv motor for the stock prop, and a very long list of ES ll owners have verified this on their own planes.
Old Nov 27, 2012, 10:30 AM
Joined Sep 2000
The stock prop provided in the Easy Star II kit is a 7x6" folder.
Jürgen
Old Nov 27, 2012, 04:44 PM
Colonel Blink is online now
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
The stock prop provided in the Easy Star II kit is a 7x6" folder.....
...and it works very well.
Colonel Blink is online now Find More Posts by Colonel Blink
Old Nov 27, 2012, 06:18 PM
bigbro3760 is offline
Find More Posts by bigbro3760
Joined May 2010
planning to put 1800kv & 7x6 prop. any comment?
bigbro3760 is offline Find More Posts by bigbro3760
Old Nov 27, 2012, 07:11 PM
henkvdw is offline
KJ6BFN
henkvdw's Avatar
Joined Aug 2008
What size is the motor?
2836 (~60g) will probably handle it.
Near vertical possible.
Old Nov 27, 2012, 07:53 PM
Joined May 2010
i'll be using a mystery 2212 1800kv
Old Nov 28, 2012, 10:58 AM
henkvdw is offline
KJ6BFN
henkvdw's Avatar
Joined Aug 2008
This one?
http://www.goodluckbuy.com/2208-12-1...lticopter.html
My guess is that it will not handle the stock prop. Probably overheat quickly and let the magic smoke out.
Check it with a motor calculator like e-calc or the likes.
Old Nov 28, 2012, 12:45 PM
mike_o is offline
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
This one?
Henk is right: Too high KV - I can only say "Good luck"
Why won't people read the posts and/or use the search function? There must be 500 qualified posts on suitable motors for the ES1 and 2...
Old Nov 28, 2012, 09:18 PM
Joined May 2010
oh, my bad.
Old Dec 04, 2012, 07:40 PM
l.aluffi is offline
Find More Posts by l.aluffi
Italy, Piedmont, Asti
Joined Jun 2012
Curiosity...
My tailplane broke a wing a couple of times and I glued it, adding some thin tape too.
Then it has been broken harder, the elevator has been ripped away and I had to put a small carbon rod to reinforce and and strong tape to hold everithing better.
I ordered a new one one month ago but it's still travelling around the world.
Now the tailplane is fat and weights 26 grams. How much weights a pristine (or almost so) one?
l.aluffi is offline Find More Posts by l.aluffi
Sold Multiplex Easy Star james mack Aircraft - Sailplanes (FS/W) 2 Oct 17, 2011 07:33 AM
Discussion Multiplex EASY STAR rickhensley Electric Sailplanes 92 Oct 13, 2011 02:43 PM
Sold Receiver Ready Brushless Multiplex Easy Star with Lipo, Pen Cam, & More! eagleswings Aircraft - Electric - Airplanes (FS/W) 10 Jul 12, 2011 03:28 PM
For Sale Easy Star Multiplex Brushless Motor Power Pack techcapsule Aircraft - Electric - Airplanes (FS/W) 0 Jul 11, 2011 03:11 PM
